Old 03-03-2007, 11:59 PM   #1
Ineffigy is on a distinguished road
2nd Dead Lilliput
I am currently using an 8 inch lilliput which was working great. I put it in the closet as I have it fabricated into my center console and I wanted to put the radio back in as I wait for a new motherboard to come in. I just started reinstalling the system and now my lilliput is dead, just like the last one. Very mysterious. The first thing I hooked up was the monitor. I checked the power line and I'm getting a nice 12.8v. Its running through the fuse that came with the monitor and its not blown. One day it was working and it was dead the next.
I'm getting sick of dumping so much money into this project. And now I'm looking at buying a 3rd Lilliput. Unfortunatly since the front of the Lilliput is fabricated into the dash, I have no other choices.
Anyone know if I can use a Xenarc with my Lilliput front?
Ineffigy is offline   Reply With Quote
Old 03-04-2007, 01:46 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
No.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 03-04-2007, 02:46 AM   #3
LiftedLimo's Avatar
LiftedLimo is an unknown quantity at this point
Your alternator might be going bad, producing stray AC voltage that wrecks havoc on the electrical system. At work is happens alot. You check it with a AC voltmeter. Google it.
120" Strech Limousine on 40's
http://www.liftedlimo.com
Cummins 5.9, tube chassis, 4-links, dana 60's, divored np205, 30 inch travel airbag suspension , POS hydrostatic steering, blah blah blah... I just need to finish it... www.myspace.com/liftedlimo
LiftedLimo is offline   Reply With Quote
Old 03-04-2007, 03:11 AM   #4
I didn't think f this earlier...
Are you providing regulated power to the Lilliput (via the PC's PSU or the egg-shaped regulator that comes with the Lilliput) or are you drawing directly from the car's 12v?
If you're not regulating the 12v to the Lilliput (which I don't believe you are), that's likely the reason you keep destroying them.
Old 03-04-2007, 05:13 PM   #5
I'm using the fuse (egg thing) that came with the monitor. That should regulate the power. I already have checked the voltage and I'm getting exactly the amount of volatge that is required. Though I have not checked the amperage. I read that maybe I have the smaller ribbon not set correctly, but I've reset the damn thing at least 3 times.
I may just end up getting the transreflective 8 inch lilliput and popping that in the car. As long as I don't mess with it alot, the Lilliputs seem to work.
Old 03-04-2007, 05:30 PM   #6
The egg isn't a fuse. It's a power regulator. But you're using it properly, nonetheless.
Sorry your experience has sucked so....
Old 03-04-2007, 06:21 PM   #7
Yeah, I just called it that cause it has a fuse in it. Anyways, I'll just put the dead one up for sale. Its probably good, just something I'm missing.
reversed polarity == Kentucky Fried Lilliput? hud LCD/Display 6 11-09-2005 08:39 AM
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 07:26 PM
WTB: BROKEN Lilliput 619! masch Classified Archive 7 12-14-2004 04:58 AM
Lilliput Dimensions? I want to put one in my Acura Legend... Matt Whelan LCD/Display 2 06-20-2004 12:10 AM
Xenarc Touch Panel on Lilliput Controller badandy4you LCD/Display 5 06-04-2004 01:54 PM
