The MP3car.com Store
Thread Tools Display Modes
Old 03-24-2007, 01:05 PM   #1
My Photos: (0)
best route for dual screen 2nd graphic card or LVDS
hello,
i want to run dual touch screen for my setup
i have a via EN mobo, which have a LVDS expansion port
can i order a DVI or VGA LVDS expansion card and have the ability to run dual screen?
if so which LVDS card will work? i look up the VIA website
"1 LVDS/TTL/DVI module connector (an add-on card is required)"
VIA LVDS-07G 24-Bit or a 18-bit card
will that work with liliput screens?
I see a DVI expansion card that use the LVDS port but doesn't see where it say for EN series mobo.
or i have to get a pci raiser card for a 2nd graphic card with dual screen output?
i'm really hoping for the first route
please help this is the only problem so far with my setup.
thanks
3square is offline   Reply With Quote
Sponsored Links
Old 03-24-2007, 11:36 PM   #2
Banned
Motorcity's Avatar
My Photos: (0)
The LVDS port supports 3 different types of add on cards.
RGB, LVDS and DVI.
The first 2 are for driving LCD panels directly, the 3rd is for use with a DVI input monitor.
None of the 3 will run a Lilliput monitor. THey are ment for custom display type setups.
This is the DVI card: Logic Supply - VIA DVI Module & Cable for VIA EPIA EN
and is for a monitor with DVI input.
This one is for 18 bit LVDS LCD panels:
Logic Supply - VIA LVDS-07 Module for VIA EPIA Mainboards
This one is for 24 bit LVDS panels:
The 2 LVDS add on cards let you connect a custom made cable to an LVDS type LCD panel. This can be a great feature if you have an LVDS LCD panel, and just want to buy the add on card ad have a custom cable made, or if you want to use a specific LCD panel for a custom application, or as you indicated, dual screen. But, if you use the LVDS port, with either the LVDS or DVI cards, you can only run the displays as Extended Desktop, or Clone modes. They will not act as independent seperate displays. You can use the LVDS port alone though, as the VGA port does not have to be used in order for the LVDS to work.
Motorcity is offline   Reply With Quote
Old 03-25-2007, 11:14 AM   #3
My Photos: (0)
"This is the DVI card: Logic Supply - VIA DVI Module & Cable for VIA EPIA EN
and is for a monitor with DVI input."
so with that add on card and that cable all i need is a lcd panel that support DVI
connection ? i'm fine with extended desktop.
Old 03-25-2007, 11:16 AM   #4
My Photos: (0)
so with that setup with the addon card and the cable, it should be fine as long as i can find a monitor that support DVI connection? or couldn't i find a VGA to DVI converter?
Old 03-25-2007, 01:47 PM   #5
MobiTekLink's CarPC Specs
MobiTekLink's Avatar
Vehicle: 2008 Lincoln Navigator
My Photos: (1)
Quote: Originally Posted by 3square View Post
hello,
thanks
Just get a DVI to VGA adaptor ($5)...
There's no difference in brightness but there is a crispness and sharpness loss from DVI to VGA. But we're in a car, so who cares? And if you have a Lilliput youre not paying for high quality. If you want quality get a ELO or a Norul monitor, they have native DVI support with 12V input.
Touch Screen Monitors : 15 " LCD Touchscreen Monitor - NuRolPOS G15
2004 GMC Yukon Denali
www.myspace.com/mobitekny
http://www.flickr.com/photos/bustadreamz
MobiTekLink is offline   Reply With Quote
Old 03-25-2007, 05:38 PM   #6
Banned
Motorcity's Avatar
My Photos: (0)
You can try it, but not all DVI out cards will work if you use a DVI to VGA adapter.
If you are going to use a DVI monitor anyway, I guess it wouldn't hurt to spend a few extra $$ to buy the adapter and give it the ol' college try.
Old 03-26-2007, 01:49 AM   #7
My Photos: (0)
hi thanks for the response.
just to clarify before i order the part
the LVDS addon card mentioned above does work but i will need the DVI-VGA converter.
or perhaps i saw there was a LVDS add on that give you a VGA connector, but wasn't for the EN series. anything about that?
Old 03-26-2007, 02:09 PM   #8
Banned
Motorcity's Avatar
My Photos: (0)
If it is not specifically for the EN board, it will not work.
Sponsored Links
Trackbacks are Off
any feedback info. on Dynamix 7" VGA Touch Screen TFT ??? xtreamvette LCD/Display 29 04-22-2007 03:19 PM
Cheap working 9.6"Monochrome 640x480 VGA LCD screen & ISA controller card with cables Frank Grayson General Hardware Discussion 14 12-09-2005 03:03 PM
Auto Screen Dim with I/O Card dan__wright General MP3Car Discussion 0 06-17-2005 10:40 AM
how do u connect lcd screen to computer video card? lex4style Newbie 6 09-16-2003 01:32 PM
latop lcd screen with controller card? schrodos General Hardware Discussion 3 11-20-2000 10:34 AM
Sponsored Links
Ad Management by RedTyger
