Go Back   MP3Car.com > Mp3Car Technical > Linux
Old 05-10-2007, 01:26 PM   #1
reece146's Avatar
reece146 is on a distinguished road
PCI Dual VGA w/ HW MPEG
I am looking for an additional display card to go into my EPIA (M10k-N) carputers.
Currently the onboard display chipset on the EPIA is used for displaying the cockpit GPS/Music/Mixer/Diagnostics interface and it works fine for this.
However, the system is going to be expanded to add headrest VGA displays for rear seat passengers to watch movies (independently).
We all know that the CPU performance on the EPIAs is, umm, limited.
The thought was that if there was a decent dual PCI display card that had hardware MPEG-2 decoding then the EPIA would not be too terribly burdened while playing two MPEG streams (i.e. DVDs) while running the normal cockpit console stuff.
Can anyone recommend a decent PCI card that is dual out and has hardware MPEG decode and is decently supported under Linux? I'd prefer to stick with NVIDIA based cards if possible.
reece146 is offline   Reply With Quote
Old 05-11-2007, 10:26 AM   #2
reece146's Avatar
I'm surprised no one had any suggestions about this...
After doing some more searching around I'm going to order this card I think:
PNY Verto GeForce FX 5200 / 256MB DDR / PCI / Dual VGA / TV Out / Video Card
Seems decent... dual RAMDAC and no heat sink, HW MPEG decode. Who knows, maybe the boys will be able to play Vdrift head to head on this card (yeah, right).
Should be fun configuring xorg.
Old 05-12-2007, 05:34 PM   #3
reborg is an unknown quantity at this point
You have a 250W PSU in an EPIA setup?
reborg is offline   Reply With Quote
Old 05-12-2007, 07:39 PM   #4
reece146's Avatar
You think that card pulls 250W all on it's own? It's marketroid/conservative crap content in the specs I figure.
I forget what my setup is... something like 160-180W I think. I remember overspec'ing for EPIA because I was going to pull the board since the CPU sucked so much. In real usage it works fine so I haven't bothered.
Old 05-14-2007, 04:41 AM   #5
DeltaFX's Avatar
DeltaFX is on a distinguished road
Even an AGP8x Geforce4 ti 4800SE draws 35Watt....
Now Galileo is real. Muhahahahaha :p
DeltaFX is offline   Reply With Quote
Old 05-15-2007, 06:20 PM   #6
tigergibb's Avatar
tigergibb is an unknown quantity at this point
Minimum 250W PSU.. I'm sure that's if you're running a full size mobo/cpu set up. The EPIA draws a lot less power. I'm sure it wouldn't hurt to ask nvidia how much power it actually draws, or look for some spec sheets.
Is there such thing as something like this that runs on USB? My PCI port is blocked and I may intend to do the same thing later. I know there are some USB graphics cards.. but I would also need one that can decode MPEG-2. Or maybe it would be easier to see if I can fit a PCI riser that will make the card go sideways first?
2003 Nissan Xterra Worklog
Total amount spent so far: $1196.64
You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
2003 Nissan Xterra - Modifications
tigergibb is offline   Reply With Quote
Old 05-16-2007, 12:53 AM   #7
licensed to kill
kev000's Avatar
kev000 will become famous soon enough
The USB bus probably isn't fast enough for any decent graphics esp with any mpeg2 decoding. A pci riser card would be your best bet IMHO.
LinuxICE - because my car already has enough windows (and because I like speed).
LinuxICE2 beta2 is released!!! get it now!
Follow OpenICE development
kev000 is offline   Reply With Quote
Old 05-17-2007, 06:21 AM   #8
tigergibb's Avatar
I have two questions:
a) Wouldn't one with TV Out(Yellow RCA Jack) be easier? You could then buy cheaper non-vga monitors.
b) Did you find out how much power it draws?
Old 05-17-2007, 08:19 AM   #9
reece146's Avatar
The problem with TV Out is the quality (i.e. there is none). I was running an EPIA box in my living room as a MythTV client for a while and the image quality wasn't very good (IMO).
Still no idea on power. I've run the power simulator at mini-box.com with 2 "high end video cards" added to the matrix and it is still within the limits of my power supply. IIRC they estimate 45 W each.
I received the cards yesterday and have started working up a new configuration on one of the boxes. The base operating system is installed so far. My install image is a few years old so I'm taking the opportunity to start from scratch and document it at the same time. I won't know how it will work until I get multi-user X-Window w/ fvwm configured and am able to run the additional MPEG-2 streams simultaneously.
Old 05-18-2007, 08:12 PM   #10
Sounds about right if it's being pushed. I was making the previous comment tongue-in-cheek, but forgot the smiley.
FAQ: VGA vs. Composite (Video) Screens cproaudio The FAQ Emporium 2 12-28-2007 12:45 PM
FS/FT Matrox G450 DualHead PCI VGA Card Multi Monitor Suport!!! Twizted Classified Archive 0 01-18-2004 01:49 PM
FS/FT Matrox G450 DualHead PCI VGA Card Twizted Classified Archive 18 01-16-2004 02:05 PM
VGA upgrade for TM-701L digitalww LCD/Display 90 08-01-2003 10:01 AM
MPEG Decoder Card Question grandamp3 General Hardware Discussion 1 11-28-2000 05:55 PM
