The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Linux
Thread Tools Display Modes
Old 04-13-2008, 04:34 PM   #1
My Photos: (0)
Liliput 8" touchscreen XY flip
I have installed LinuxICE on a computer with an attached an 8" touch screen. It appears as though the touch screen drivers are working as the touch screen does respond. However, the X and Y axis are switched. As motion occurs across the screen in the X direction, the cursor moves in the Y direction. I have also installed Gentoo and Ubuntu successfully and installed the e-galax drivers. They also give the same result. Has anyone else run into this issue? Any help would be appreciated. Thanks!
- bobtheduck
http://bobtheduck.com
bobtheduck32 is offline   Reply With Quote
Sponsored Links
Old 04-13-2008, 06:48 PM   #2
kev000's CarPC Specs
kev000's Avatar
Vehicle: 2008 Chevy Impala SS 5.3 V8
My Photos: (0)
providing you've run the calibrator (icetouch) under LinuxICE and you still have a swapped X and Y axis, you can add the following to xorg.conf evtouch device options:
Code:
option 'rotate' 'ccw'
This will rotate the screen counter-clockwise and un-swap the X and Y.
Hope this helps.
BTW, if you've been able to get evtouch working in gentoo, could you mind giving kantlivelong a hand. He can't get the touchscreen to work at-all using gentoo (http://www.mp3car.com/vbulletin/linu...00-gentoo.html).
nGhost - "The Evolution of Car Entertainment"
Not just software: LinuxICE -- The Car Entertainment Platform"
LinuxICE IRC chatroom: #linuxice irc.freenode.com
kev000 is offline   Reply With Quote
Old 04-13-2008, 08:46 PM   #3
My Photos: (0)
I just managed to get that line added to my xorg.conf file and it's working now. The calibrator application didn't quite set the max and min's properly. I had to manually set those and play around a bit until it cooperated. I am having a bit of another problem though. It seems to assume that I always want to double click when I press on the screen and single click when I hold down for more than half a second. Is there any way I can reverse those, or at least turn off the double click? Thanks again!
- bobtheduck
Old 04-14-2008, 12:46 AM   #4
kev000's Avatar
My Photos: (0)
can you post your xorg.conf? It'll help me not to make irrelevant suggestions if I can see what you have in there currently.
thanks
Old 04-14-2008, 04:05 PM   #5
My Photos: (0)
Here's my xorg.conf file.
Code:
Section "Files" FontPath "/usr/share/fonts/X11/misc" FontPath "/usr/share/fonts/X11/cyrillic" FontPath "/usr/share/fonts/X11/100dpi/:unscaled" FontPath "/usr/share/fonts/X11/75dpi/:unscaled" FontPath "/usr/share/fonts/X11/Type1" FontPath "/usr/share/fonts/X11/100dpi" FontPath "/usr/share/fonts/X11/75dpi" # path to defoma fonts FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" EndSection Section "Module" Load "i2c" Load "bitmap" Load "ddc" Load "dri" Load "extmod" Load "freetype" Load "glx" Load "int10" Load "vbe" EndSection Section "InputDevice" Identifier "Generic Keyboard" Driver "kbd" Option "CoreKeyboard" Option "XkbRules" "xorg" Option "XkbModel" "pc105" Option "XkbLayout" "us" EndSection Section "InputDevice" Identifier "Configured Mouse" Driver "mouse" Option "CorePointer" Option "Device" "/dev/input/mice" Option "Protocol" "ImPS/2" Option "ZAxisMapping" "4 5" Option "Emulate3Buttons" "true" EndSection Section "InputDevice" Identifier "Synaptics Touchpad" Driver "synaptics" Option "SendCoreEvents" "true" Option "Device" "/dev/psaux" Option "Protocol" "auto-dev" Option "HorizScrollDelta" "0" EndSection Section "InputDevice" Driver "wacom" Identifier "stylus" Option "Device" "/dev/input/wacom" Option "Type" "stylus" Option "ForceDevice" "ISDV4" # Tablet PC ONLY EndSection Section "InputDevice" Driver "wacom" Identifier "eraser" Option "Device" "/dev/input/wacom" Option "Type" "eraser" Option "ForceDevice" "ISDV4" # Tablet PC ONLY EndSection Section "InputDevice" Driver "wacom" Identifier "cursor" Option "Device" "/dev/input/wacom" Option "Type" "cursor" Option "ForceDevice" "ISDV4" # Tablet PC ONLY EndSection Section "Device" Identifier "ATI Technologies Inc Radeon Mobility M6 LY" Driver "ati" BusID "PCI:1:0:0" EndSection Section "Monitor" Identifier "Generic Monitor" Option "DPMS" EndSection Section "Screen" Identifier "Default Screen" Device "ATI Technologies Inc Radeon Mobility M6 LY" Monitor "Generic Monitor" DefaultDepth 24 SubSection "Display" Depth 24 Modes "800x600" EndSubSection EndSection Section "ServerLayout" InputDevice "touchscreen" "SendCoreEvents" InputDevice "dummy" Identifier "Default Layout" Screen "Default Screen" InputDevice "Generic Keyboard" InputDevice "Configured Mouse" InputDevice "stylus" "SendCoreEvents" InputDevice "cursor" "SendCoreEvents" InputDevice "eraser" "SendCoreEvents" InputDevice "Synaptics Touchpad" EndSection Section "DRI" Mode 0666 EndSection Section "InputDevice" Identifier "dummy" Driver "void" Option "Device" "/dev/input/mice" EndSection Section "InputDevice" Identifier "touchscreen" Driver "evtouch" Option "Device" "/dev/input/touchscreen" Option "DeviceName" "touchscreen" Option "MinX" "100" Option "MinY" "0" Option "MaxX" "1900" Option "MaxY" "2000" Option "SwapY" "0" Option "SwapX" "0" Option "maybetapped_action" "down" Option "maybetapped_button" "1" Option "longtouch_action" "click" Option "longtouch_button" "1" Option "ReportingMode" "Raw" Option "Emulate3Buttons" Option "Emulate3Timeout" "50" Option "SendCoreEvents" Option "rotate" "ccw" EndSection
Thanks!
- bobtheduck
Old 04-15-2008, 02:59 PM   #6
kev000's Avatar
My Photos: (0)
change your mouse line to /dev/input/mouse0 instead of mice. That should help there.
Sponsored Links
vB code is On
Trackbacks are Off
will a 7" touchscreen work with 8" lcd and controller? bgreen02 LCD/Display 2 08-30-2007 08:00 AM
Hardware Review : Dynamix 805 8" 4:3 TouchScreen Review (Pics : 56K Friendly) Ruffy The Review Palace 14 04-13-2007 01:23 PM
lilliput 8" touchscreen LCD Moel LCD/Display 3 11-21-2006 02:14 PM
FS: 8" LCD Touchscreen - Brand NEW!!! mmdb Classified Archive 8 11-21-2005 09:05 PM
Replacement glass for liliput 7" touchscreen Stoney LCD/Display 5 12-30-2003 10:49 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
