Go Back   MP3Car.com > Mp3Car Technical > Linux
Old 04-24-2008, 05:57 PM   #1
2L_SS is an unknown quantity at this point
Steering wheel controls and Linux
What is the best option for interfacing steering wheel controls in Linux ICE/ Nghost? The fusion brain looks like the way to go but is there a plugin for it? Or would I be better off with a hacked up gamepad or joystick?
"Who run Barter Town?"
2L_SS is offline   Reply With Quote
Old 04-25-2008, 03:15 AM   #2
Fusion Brain Creator
greenman100 is on a distinguished road
There is currently no support for the fusion brain outside of Windows.
greenman100 is offline   Reply With Quote
Old 04-25-2008, 05:25 PM   #3
licensed to kill
kev000's Avatar
kev000 will become famous soon enough
why not? seems like a good idea since the whole universe (including aliens and robots) is moving to Linux.
Are there at least docs on interfacing with the device that are available if someone wants to "support" it?
LinuxICE - because my car already has enough windows (and because I like speed).
LinuxICE2 beta2 is released!!! get it now!
Follow OpenICE development
kev000 is online now   Reply With Quote
Old 04-25-2008, 05:34 PM   #4
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Anyone wanting to program something for it that can run in the linux/mac environment, let me know.
We are not opposed to it at all, just dont have the time to devote to something like that.
I can try and point you in the right direction such as the "linusb" libraries. They should be able to read and write to the Fusion Brain.
We have documentation on the low level protocol back and forth between the PC and the FB, so it is just a matter of getting a USB connection going and formatting a 64 byte array correctly back and forth.
Old 04-25-2008, 06:47 PM   #5
wirelessdreamer is an unknown quantity at this point
a joystick would be your best bet, i'm almost done with the joystick input plugin for nghost right now, it should be out within the next month or so.
wirelessdreamer is offline   Reply With Quote
Old 04-26-2008, 03:45 PM   #6
Is this joystick mod for the resistor network type steering wheel controls? If so how many inputs can it handle? Also will it be compatible with nghost 2 whan it comes out?
Old 05-04-2008, 09:43 AM   #7
to use a joystick for input all you need to be able to do is short 2 points together, you could most likely bypass most of the internal controls and wire it up directly to the buttons. If you don't want to modify the hardware I'd need to see schematics of how they're wired up, and I could give you some other ideas.
Yes Nghost will support joystick input, I have a few more features to add to the plugin and it will be committed to the main source tree to be packaged for release.
Is Linux better off than OS X for in car support? iamgnat Linux 5 02-27-2006 08:05 PM
ALCAS (A Linux Car Audio System) jospfh Show off your project 13 08-06-2003 07:02 PM
