Go Back   MP3Car.com > Mp3Car Technical > Linux
Old 09-07-2008, 09:48 PM   #1
jsd8cc is an unknown quantity at this point
Xenarc touchscreen drivers on Ubuntu
Has anyone successfully installed the Xenarc drivers on Ubuntu? If so, could you post a step-by-step instruction?
I have a Xenarc 700TSV and I'm using Ubuntu 8.04. I downloaded the 2.6 kernel drivers from here http://www.xenarc.com/driver-touch1.html and I tried following the instructions no to avail. I'm not quite sure which method to use.
I know the touchscreen works because I can click/double click but it only does it where the mouse pointer is.
Part of my xorg.conf:
Code:
Section "InputDevice" Identifier "EETI" Driver "egalax" Option "Device" "/dev/input/event4" Option "Parameters" "/var/lib/egalax.cal" Option "ScreenNo" "0" EndSection ... Section "ServerLayout" Identifier "Default Layout" Screen "Default Screen" InputDevice "EETI" "SendCoreEvents" EndSection
Like I said, I've tried several different options in the Option "Device"... /dev/usb/hiddev0, /dev/input/mouse1, etc. None seem to work.
Here's the relevant info in /proc/bus/input/devices:
Code:
I: Bus=0003 Vendor=0eef Product=0001 Version=0112 N: Name="eGalax Inc. Touch" P: Phys=usb-0000:00:1d.1-2/input0 S: Sysfs=/devices/pci0000:00/0000:00:1d.1/usb2/2-2/2-2:1.0/input/input4 U: Uniq= H: Handlers=mouse1 event4 B: EV=1b B: KEY=401 30000 0 0 0 0 B: ABS=f B: MSC=10
Also, when I run the Touchkit Screen Utility I only get the "About" tab.
Thanks for the help.
jsd8cc is offline   Reply With Quote
Old 09-08-2008, 09:05 AM   #2
kantlivelong is an unknown quantity at this point
First of all.. Make sure you have the egalax 2.x drivers direct from the EETI website..
secondly, use HIDDEV(IMO the best option) for the device section just type hiddevs
ex
Option "Device" "hiddevs"
I have never gotten TkUSB nor event interface working on a Xenarc :|
kantlivelong is offline   Reply With Quote
Old 09-08-2008, 10:33 PM   #3
ex
Thanks kant, I downloaded the 2.03 drivers from here: http://home.eeti.com.tw/web20/TouchK...inuxDriver.htm
And ran the setup.sh file and it works now!
Old 09-09-2008, 03:31 PM   #4
no prob
"SUPER" (Xenarc repackage) touch screen- can not get the touch drivers working HACKTHS Input Devices 8 05-21-2006 04:00 AM
"SUPER" (Xenarc repackage) touch screen- can not get the touch drivers working HACKTHS LCD/Display 5 03-25-2006 11:24 PM
FS 7" Touchscreen Like Xenarc sebcorazon Classified Archive 0 04-06-2005 02:57 AM
Xenarc Touchscreen powerfeed. Converting to selfpowered? live2themaxuk LCD/Display 9 01-08-2005 12:08 PM
Xenarc, Lilliput, touchscreen, no touch, fixability, etc xdigitalchaosx LCD/Display 0 02-17-2004 12:18 PM
