Go Back   MP3Car.com > Mp3Car Technical > Linux
Old 01-02-2009, 08:50 PM   #1
yam125's Avatar
yam125 is an unknown quantity at this point
Automating GPS device in linux
before i use any gps app i have to run
Code:
sudo rfcomm release 4 rfcomm connect 4 gpsd -n /dev/rfcomm4
what can i do to automate this?
yam125 is offline   Reply With Quote
Old 01-02-2009, 08:59 PM   #2
strandtc
Do you have a start script for gpsd? Just add those lines to your start script, and you're done. You can either create a shell script to start gpsd, or better yet, have gpsd start in a boot script.
Look up info on init scripts. You can usually copy one for a different service, and modify it for your own needs.
-Chris
strandtc is offline   Reply With Quote
Old 01-02-2009, 10:16 PM   #3
yam125's Avatar
is the sudo in the release command going to work?
Old 01-02-2009, 11:00 PM   #4
Sicarius is on a distinguished road
If you're putting those in an init script, it will be run as root anyway and you can remove the "sudo" from that line.
Sicarius is offline   Reply With Quote
Old 01-03-2009, 01:11 AM   #5
yam125's Avatar
here is my /etc/init.d/gpssamp.sh
Code:
#!/bin/sh rfcomm release 4 rfcomm connect 4 gpsd -n /dev/rfcomm4
to put it there i used
Code:
cd /etc/init.d/ sudo gedit gpssamp.sh sudo update-rc.d gpssamp.sh defaults update-rc.d: warning: /etc/init.d/gpssamp.sh missing LSB style header System startup links for /etc/init.d/gpssamp.sh already exist. sudo chmod +x gpssamp.sh
works just fine when manually started but wont do it on start
Code:
sudo /etc/init.d/gpssamp.sh [sudo] password : Connected /dev/rfcomm4 to 00:12:0E:80:D8:xx on channel 1 Press CTRL-C for hangup
then close terminal(bc i dont have a control key)
then i can run roadnav and it picks the reciver up
Old 01-08-2009, 12:49 AM   #6
yam125's Avatar
help?
Old 01-27-2009, 12:07 PM   #7
licensed to kill
kev000's Avatar
kev000 will become famous soon enough
have a look at /etc/init.d/skeleton for a proper init script. That should give you a base to start from when creating your script.
LinuxICE - because my car already has enough windows (and because I like speed).
LinuxICE2 beta2 is released!!! get it now!
Follow OpenICE development
kev000 is online now   Reply With Quote
Old 01-29-2009, 11:41 AM   #8
yam125's Avatar
the skeleton file looks really scary, after some searching I found a Start up script generator:
http://rob.pectol.com/content/view/17/33/
Also can I link to the script file from the sessions (System \ Preferences\ Sessions \ Startup Programs) menu?
Old 01-30-2009, 12:06 AM   #9
licensed to kill
kev000's Avatar
yep, that's easy enough
How to Embed any GPS program into Road Runner jonessc RR FAQ 52 10-28-2009 12:10 PM
How to setup iGuidance GPS for RoadRunner MatrixPC RR FAQ 31 05-22-2009 09:29 AM
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
GPS device diagnostic lastberserker GPS 12 05-12-2005 02:15 PM
Can a GPS antenea be recognized as a Serial and a USB device? Skipjacks GPS 6 01-21-2005 03:12 PM
