Go Back   MP3Car.com > Mp3Car Technical > Linux
Old 01-07-2009, 01:27 AM   #1
mrgts4 is on a distinguished road
Linux Distro thats boots to Clutter UI
have been looking around at some of the linux distro for the MID units and liked the Ubuntu Mobile edition but wanted the Clutter ui to use it as the carpc frontend.. does anyone know of any images (live cd's, whatever they are called) that are like this? or can you make this yourself?
i want it to run on a atom processor (x86) with touchscreen ability.
can anyone shed any light on the subject??
thanks
curt
mrgts4 is offline   Reply With Quote
Old 01-07-2009, 09:45 AM   #2
FunkyStickman's Avatar
FunkyStickman is an unknown quantity at this point
The Ubuntu MID image is already compiled for Atom processors, so it would make sense to try that first, it may suit your needs with no modifications.
If not, then your next shot would be to run a regular distro of Ubuntu/whatever and add the Hildon GUI to it and use that.
FunkyStickman on Youtube
PoshBoxMods.com (my computer blog)
FunkyStickman is offline   Reply With Quote
Old 01-07-2009, 10:11 AM   #3
natedawgg's Avatar
natedawgg is an unknown quantity at this point
you should be able to install the hildon desktop and then install clutter on top of that, from there you can launch the clutter desktop. i have been looking for a way to get it to boot straight into the clutter desktop, but i am still to new to linux and don't know all the ins and outs. Please let me know if you figure this out
Check out the new version of NAS, a cross platform music frontend here
natedawgg is offline   Reply With Quote
Old 01-08-2009, 04:20 AM   #4
could you use like puppy linux as a base and build on that?? just because its a small footprint and maybe be good for running off a cf card too. as far as linux goes i know how to use a live cd and thats about it!! lol
Old 01-09-2009, 04:33 PM   #5
natedawgg's Avatar
ok i figured out how to get the clutter UI to run on boot. i guess there is actually two different ways to get this to work. at the moment i have only tested this on Ubuntu 8.04
first and foremost you should have the basic ubuntu-mobile packages installed. a good guide that i have used and seen great success is found here. in these instructions i chose to ignore the section about rolling back the drivers (not really relevant in most cases)
1. in the normal gnome session. just go to the sessions manager (System -> Preferences -> Sessions) and in the command line just enter desktop-launcher.
this should cause the clutter UI to launch on boot. i dont think this would be the best option however due to the fact that this UI seems somewhat unstable and may not want to be 'stuck' using it.
2.(better option) create a separate session that will boot into the clutter UI. this will give you the option of booting into the Cutter desktop or the typical Gnome desktop. to do this you should have followed the instructions in the link above, including the final command "sudo apt-get install moblin-clutter-home". if you have then follow these commands to get the new clutter desktop setup:
1. create a new desktop file named clutter:
sudo nano /usr/share/xsessions/clutter.desktop
2. enter the following into this new file:
[Desktop Entry]
Encoding=UTF-8
Name=Hildon
Exec=/usr/local/bin/desktop-launcher
Type=Application
3. save the file
4. now copy the clutter script:
sudo cp `which desktop-launcher` /usr/local/bin/desktop-launcher
check and make sure the file copied correctly and then you should be good to go. in your login screen you should be able to select a session named clutter and you should boot into it.
enjoy!
Old 01-09-2009, 04:53 PM   #6
I'm almost done getting Ubuntu installed on the CarPC, going to give this a try. Thanks!
Old 01-09-2009, 11:39 PM   #7
cool, i'll have to try this at home tonight. more questions.... could i run this sort of thing off a 2gb compact flash card?? also is there a way on boot to choose from gnome or clutter like you do for different users on windows xp?
Old 01-10-2009, 12:17 AM   #8
Well I got Ubuntu-Mobile installed, but the clutter desktop automatically runs a program called "devilspie" that maximizes and removes decoration for all windows... wasn't expecting that. Took me a while to figure out what what causing this, so I may try it again... or I may stick with custom panels in Gnome... haven't decided yet.
But the project is well underway.
Old 01-15-2009, 01:42 AM   #9
yam125's Avatar
yam125 is an unknown quantity at this point
devils pie is actually a part of Ubuntu Mobile itself.
i dont remember how to do it but it is easily killed in the terminal
I am currently using Ubuntu Mobile.
I love the look of the Clutter UI
I also love how it appears in ALL the promotions and stuff for Ubuntu Mobile but is not actually installed and doesn't reappear in the Wiki. Im glad you found it and Im excited to try it out now
Last edited by yam125; 01-19-2009 at 11:20 PM. Reason: did not mean to sound sarcastic
yam125 is offline   Reply With Quote
Old 01-15-2009, 10:38 AM   #10
natedawgg's Avatar
yeah let me know how it works out for you guys. i have it installed on my machine but it runs like crap. the screen just flashes to white on and off, and is essentially unusable. it is fine if i boot into the hildon desktop and then launch desktop-launcher from the command line. i don't know of any thing that could be done to fix it. by the way i am running this on a 1.66 mac mini
Old 01-19-2009, 11:18 PM   #11
yam125's Avatar
i tried your instructions.. the name you have for the package did not come up.
also is your last step even a valid command?
Old 01-20-2009, 10:49 AM   #12
natedawgg's Avatar
what version of linux are you using? i have only tried these instructions in Ubuntu 8.04. i did try it in 8.10 and that package did not show up. it seems that particular one has not been released for 8.10 or at least is not in the repositories. as for the last command, it is valid i copied those lines verbatim as i did them during the install. the key thing to know i guess is that those are not single quotes surrounding
the correct symbol is found on the same key as the Tilda ( ~ ) just don't hit shift (sorry i don't know the correct name for that symbol).
im no linux super user or anything but from what i can tell that is giving a relative path to that particular script.
sorry if that is a bit confusing, but that is all i got.
Old 01-26-2009, 09:40 AM   #13
danmiddle2 is an unknown quantity at this point
What the "which xxx" command does is it shows you the full path to a given command that Linux has found by looking in certain pre-configured locations.
A simple example to test this would be the command "ping". typing "ping 192.168.1.1" will work from any folder without entering the fully qualified path to the ping executable.
If you type "which ping" it will show you the path that ping is stored in. Depending on the distro, this could be in a number of different locations.
The backquote symbol allows you to embed the output from certain commands in the middle of a different command from a shell (unlike pipe '|' which lets you string commands together one after the other). So, when I write instructions I would use the `which xxx` instead of the path that file occupies on my system so that if there is any variation in the location of particular files, the instructions will still work on other systems.
I hope that helps.
danmiddle2 is offline   Reply With Quote
Old 10-20-2009, 09:12 PM   #14
wuyu is an unknown quantity at this point
I have the same problem. Have you solved this ploblem?
wuyu is offline   Reply With Quote
Old 10-20-2009, 09:14 PM   #15
Does it sucess in the Wiki ? which version do you setup ?
Help...
Linux distro as fe! vip3r87 Other Cool Front Ends 0 09-24-2008 01:16 AM
Another Linux distro for car PC? COST Linux Linux 12 06-14-2005 03:24 PM
Possible EPIA distro for Linux, Can we make one? adamis Software & Software Development 15 02-23-2005 06:50 PM
The LOW Risk Linux Adventure... grepzen Software & Software Development 13 11-08-2004 10:12 PM
linux carPC distro ? MetalDwarf Software & Software Development 1 09-11-2004 05:27 AM
