Go Back   MP3Car.com > Mp3Car Technical > Linux
Old 02-02-2009, 07:20 PM   #1
natedawgg's Avatar
natedawgg is an unknown quantity at this point
Ubuntu on Mac Mini (sleep issues)
ok so i am somewhat torn on what forum to post this in so i am going to post in both. i am running an intel mac mini and have been experimenting with linux. i am running the ubuntu mobile package on Ubuntu 8.04. i have been able to load and run Ubuntu without any problems as the primary OS. the problem that i am having is getting the mini to go to sleep when i turn off the car. i have a carnetix p1900 and it is set to make the mini sleep. i don't know if there is just a setting somewhere or what but any help would be awesome. thank you all in advance
Check out the new version of NAS, a cross platform music frontend here
natedawgg is offline   Reply With Quote
Old 02-03-2009, 01:07 PM   #2
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
Have you tested standby/sleep outside of the car? Seems you'd want to eliminate any other problems by testing on a bench or something first. Also, ubuntu and linux in general sucks as far as standby and hibernation. Out of all the machines I have it loaded on, I think I have ONE that sleeps and hibernates correctly. All the others typically lock up or just don't ever make it.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 02-03-2009, 02:05 PM   #3
natedawgg's Avatar
i did somewhat try outside of the car but i didn't test that much. in the car ubuntu just ignores the button press (simulated by the p1900) and then is just shut down when the p1900 cuts the power. this results in having to reboot (obivously) the next time i start the car, and cause ubuntu to want to try and check all the disks for errors (which takes a loooong time). well that sucks to hear that ubuntu is so bad at sleeping/hibernating, what is everybody else doing that is running linux in the car? how are you all getting around this?
Old 02-04-2009, 12:02 AM   #4
yam125's Avatar
yam125 is an unknown quantity at this point
mine sleeps/hibernates just fine, i don't have it automated through my M3 yt but manually it does it just fine.
the check disk happens on boot up once and a while but i am patient.
i am not sure how the mac mini is set up, do you have the switch emulator on the MB? is so what happens when you do it manually
yam125 is offline   Reply With Quote
Old 02-04-2009, 12:31 AM   #5
Tidder's Avatar
There are a couple of different hibernation/standby programs out there that I've had success with after adding to ubuntu. Ubuntu out of the box just sucks. I don't know if I just have a vast assortment of unsupported machines or what. I'll find what the package was called that I installed, it seems to work about everytime.
Tidder
Try RevFE
Best Quote EVER!!
Old 02-04-2009, 10:10 PM   #6
licensed to kill
kev000's Avatar
kev000 will become famous soon enough
tuxonice (aka suspend2)
LinuxICE - because my car already has enough windows (and because I like speed).
LinuxICE2 beta2 is released!!! get it now!
Follow OpenICE development
kev000 is online now   Reply With Quote
Old 02-05-2009, 11:32 AM   #7
Tidder's Avatar
Indeed.
Tidder
Try RevFE
Best Quote EVER!!
Old 02-06-2009, 02:28 PM   #8
natedawgg's Avatar
Awesome. thank you all for your help. i am going to try and see if i can get this all up and running now.
Mini Mac 4 Porsche 944 4thChild MacCar 14 03-13-2009 11:16 PM
2008 Volkswagen Jetta SLE + Apple Mac Mini Clownzer Worklogs 8 08-17-2008 07:33 PM
Mac Mini in colder seasons? Isthan MacCar 6 08-07-2008 10:30 AM
Mac-centric links kandyman676 MacCar 24 04-16-2007 11:46 PM
