radio/hdradio/obdII testing in nghost
I'm putting in some skin settings that should enable radio playback in nghost. It uses mplayer's "radio://[channel]" feature. If anyone has a radio that is linux compatible, would you mind testing this out?
Also, the hdradio plugin needs more testing and tweaking. If you have one of those fancy visteon HDRadios, nGhost needs you!
Last of all, I have only tested nGhost's OBD-II plugin in simulation. It needs to be tested on a real scan tool before release. If you have a OBD-II scantool, nGhost once again, needs you!
If you don't have any of the above hardware and are looking for the excuse, here is your chance. Tell the wife that "nGhost needs you!".
LinuxICE - because my car already has enough windows (and because I like speed).
LinuxICE2 beta2 is released!!! get it now!
Follow OpenICE development
