Go Back   MP3Car.com > Mp3Car Technical > Linux
Old 05-12-2009, 11:08 AM   #1
Sureshot324 is an unknown quantity at this point
Getting ODB2 (OBD-II) scanner working in Linux
I have a cheap USB ODB2 scanner that I got off ebay straight from Hong Kong. I has no brand or any other info, so I'm not sure what kind of chip it has. Do nghost and other Linux OBD2 software usually have the drivers for most OBD2 scanners included, or do you need to get them separate? If they're separate, how would I go about finding the drivers for my scanner?
Sureshot324 is offline   Reply With Quote
Old 05-12-2009, 08:18 PM   #2
tdb30_'s Avatar
tdb30_ is on a distinguished road
I might be mistaken, but I think the chips that linux needs to deal with isn't the obd-II chips, but rather the serial port chip or serial to usb chip.
How does your scanner hook up to your computer, is it usb or serial?
chances are pretty good if it is usb you should get a /dev/ttyUSBx where x is generally 0 but could be another number if you have other usb serial devices like gps.
My carputer project
tdb30_ is offline   Reply With Quote
Old 05-12-2009, 09:47 PM   #3
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
I think most of the inexpensive OBD cables will be ELM knockoffs. They will usually need a USB to serial port driver. Not really sure which one that is, though. Maybe FTDI?
Then, they appear as a device on the com port.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 05-12-2009, 10:21 PM   #4
It's USB and when I plug it in, a device gets added:
/dev/ttyUSB0
So how would I install this USB to serial driver?
Slightly off topic question: What are considered to be the best OBD2 software packages in Linux these days?
Old 05-13-2009, 01:18 AM   #5
Bugbyte's Avatar
Oops, I was thinking of windows. If it shows up in the /dev folder, then I believe it is recognized. You'll just have to point the software to it.
Want to:
-Where is the iBug?
Old 05-13-2009, 05:45 PM   #6
tdb30_'s Avatar
Yeah if it created the /dev/ttyUSB file then your drivers are already installed. As the poster above pointed out, you just need to point your software to /dev/ttyUSB0
My carputer project
New Frontend for Windows and Linux gbr Other Cool Front Ends 68 01-21-2009 09:55 PM
Wiring in OBD II Scantool HisSketchiness Engine Management, OBD-II, Engine Diagnostics, etc. 1 04-20-2008 01:27 PM
OBD II and Citroen Xsara ThePohorc Engine Management, OBD-II, Engine Diagnostics, etc. 9 04-02-2008 09:41 AM
OBD Port on Cavalier not Working! rogergolf Engine Management, OBD-II, Engine Diagnostics, etc. 1 05-01-2007 10:31 AM
OBD II software for bmw kostsour Engine Management, OBD-II, Engine Diagnostics, etc. 5 11-05-2006 01:50 PM
