Go Back   MP3Car.com > Mp3Car Technical > Linux
Old 05-26-2009, 09:11 PM   #1
ThePistonDoctor is an unknown quantity at this point
Xenarc 705TSV + Ubuntu 9.0.4
Hi all,
One other question. I am just about ready to install everything. I've got nGhost installed and running, wireless keyboard and mouse working, air card for internet access working, but unfortunately (stupidly) I rand the VGA cable for the touchscreen already in my car and it's under the carpet along the center console which means if I want it back I have to gut the whole car (again).
Is there anything I can do to minimize the chances of my touchscreen not working at least enough so I can get it calibrated once I install the PC this weekend? It's the last piece to get working before it's functional and I can actually start having some fun!
I REALLLLLLY don't want to take the whole car apart again, and yes I will have to because I gutted it ALL to run the wiring for the computer, two amps, a sub, and a front component set.
ThePistonDoctor is offline   Reply With Quote
Old 05-27-2009, 08:47 PM   #2
Anyone got any advice on this? I don't have drivers for Ubuntu nor do I have a CD ROM so I'd like to install whatever's needed before I disconnect from my test bench where I have internet access.
Old 05-28-2009, 08:19 AM   #3
licensed to kill
kev000's Avatar
kev000 will become famous soon enough
I don't understand, the screen doesn't work? Does it turn on? Or does it just require calibration?
If it just requires calibration, download the TouchKit driver for egalax based touchscreens: http://home.eeti.com.tw/web20/eGalax...inuxDriver.htm extract, run sudo setup.sh, restart, run sudo TouchKit, and do the 4 point calibration.
LinuxICE2 beta2 is released!!! get it now!
OpenICE - The Free infotainment platform.
Follow OpenICE development
kev000 is offline   Reply With Quote
Old 05-28-2009, 11:50 AM   #4
Maheriano will become famous soon enoughMaheriano will become famous soon enough
You say you have a VGA cable for touchscreen but touchscreen commands can't run though a VGA cable.....doesn't make sense.
You said you ran your VGA cable under the carpet but this is bad because........doesn't make sense.
I can't figure out what it is you're doing.
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 05-28-2009, 01:33 PM   #5
Sorry for the confusion guys. What I was trying to say is I have already installed the touchscreen in the car but the PC is still on my workbench hooked up to a regular VGA monitor. The cable for the touchscreen is in the car, under the carpet so that all I have to do is plug it into the PC and go when I install the PC.
If I install the PC this weekend and hook it up to the screen and it doesn't work, I will have no screen to be able to troubleshoot it unless I take the PC out and go back inside to my workbench.
Since the driver CD I got with the Xenarc didn't come with drivers specifically for Ubuntu, I haven't installed anything for the touchscreen or tested it at all. I am relying on the hope that it will "just work" when I plug everything in. But, it looks like Kev posted what I need, so I will have to download and install the packages he suggested and then when I get the computer booted up in the car just run the touchkit app and calibrate it in the car.
I just wanted to make sure I wasn't going to end up hooking everything up and not have a display in the car because I hadn't installed something that I needed.
Thanks!
Xenarc touchscreen drivers on Ubuntu jsd8cc Linux 3 09-09-2008 03:31 PM
Replacement touchscreen panel for Xenarc 705tsv? Kangox LCD/Display 2 04-28-2008 06:36 PM
Help with extending internal xenarc 705tsv cables jjakes24 LCD/Display 8 04-10-2008 10:08 AM
MON-053 - XENARC 705TSV 7" TFT LCD Touchscreen Monitor w/ VGA & AV inputs RedGTiVR6 Monitors 0 02-05-2008 12:45 PM
Xenarc 705TSV Review with **PICS** kilimats LCD/Display 13 01-23-2008 02:39 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
