Go Back   MP3Car.com > Mp3Car Technical > Linux
Old 06-05-2009, 01:08 AM   #1
Sureshot324 is an unknown quantity at this point
List of OBD2/OBDII software that works on Linux, native or with Wine
What are all the OBD2 programs that are known to work in Linux? The ones I know of are freediag and nghost. Will Carman work on a Linux laptop or only a Nokia tablet? Are there any good Windows ones that run on Wine?
Sureshot324 is offline   Reply With Quote
Old 06-05-2009, 06:30 AM   #2
licensed to kill
kev000's Avatar
kev000 will become famous soon enough
scantool.net has been reported to work, although i don't have experience with it. Also obdgpslogger claims to support linux.
LinuxICE2 beta2 is released!!! get it now!
OpenICE - The Free infotainment platform.
Follow OpenICE development
kev000 is offline   Reply With Quote
Old 06-05-2009, 10:10 AM   #3
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Psst, Kev,if you are going to reply to a bright yellow post, at least approve it first
Enforcer is offline   Reply With Quote
Old 06-05-2009, 10:29 AM   #4
licensed to kill
kev000's Avatar
I'm sure there's probably a button to do that somewhere eh?
Old 06-05-2009, 12:53 PM   #5
Confusion Master
Enforcer's Avatar
Do you not have a drop down menu to the bottom right of the last post which says Moderation?
NB this will only appear in forums you are a moderator of.
Old 06-08-2009, 11:18 PM   #6
unsungboxer is an unknown quantity at this point
^^^^ silly moderators ^^^^
Anyways, to add to the list:
Native:
Jdash - Native Linux - kinda works for subarus
Carman - Linux Maemo - sounds like it works well, too bad not for us.
Magden - Linux based, but sold with hardware.
WINE
Tuner Pro - Opens in WINE - (wine lacks USB support)
Zietronix - Opens in WINE then crashs.
EcuFlash - Opens in WINE (wine lacks USB support)
EvoScan - Fails to load in WINE, even with Winetricks + dotnetfx 2.0
Windows Based, but untested in WINE:
LearningView [Merchgod / romraider.com] - realtime display of Subaru learning parameters
EcuExplorer [Calvin Cestari / tari.co.za] - logs from almost all modern Subarus
MitsuLogger [MalibuJack] - logs from Mitsubishis
EvoScan [Hamish Ahern] - logs from Mitsubishs and Subarus (not free)
RomRaider [Jared / romraider.com] - logs from Subarus
LogWorks 2.0 [Innovate Motorsports] - logs from Innovate WBO2 and other sensors - now has EcuFlash support
more info: www.openecu.org
unsungboxer is offline   Reply With Quote
Old 07-03-2009, 01:34 AM   #7
boltun is an unknown quantity at this point
Python based OBDII app
There is nice open source python based application that could be easily used in linux.
http://www.cs.unm.edu/~donour/cars/pyobd/
I think it was originally written for Mac, so I had to change it to make it work on my Ubuntu laptop. I also changed the port to /dev/ttyUSB0 since I am using a USB device for communication (obddiag.net). The archive contains the script with my changes. I was able to read the DTC and display some sensor data for my Tercel.
boltun is offline   Reply With Quote
Old 07-04-2009, 12:38 AM   #8
Mod - OBDII GPS Logger forum
chunkyks is on a distinguished road
Hahahah "claims". I've probably done 75% of its development under Linux :-)
Gary (-;
chunkyks is offline   Reply With Quote
Old 07-04-2009, 07:32 AM   #9
rogerdugans is an unknown quantity at this point
I have only messed with ODB2 stuff a small amount and tested little- just accessport stuff.
But a note: USB support under wine DOES work just fine with a small amount of manual config: creation of a symlink in ~.wine/dosdevices/yournamehere
This does NOT mean the Windows software will work however: some windows USB devices use a USB software stack that does not work in linux yet, and apparently is difficult to reverse engineer.
My Cobb Accessport is one of these devices so I have to run a virtual machine (VirtualBox) to use Accessport Manager or Tuner.
rogerdugans is offline   Reply With Quote
Old 10-25-2009, 01:57 PM   #10
Added: TouchScan
Trial Version: http://www.obdsoftware.net/TrialVersion.aspx
Native: Windows
Wine: with dotnet 1.0 and 2.0 (through winetrix)
notes: installs successfully, will not open.
Errors: An error has occurred causing this application to terminate. Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
New Frontend for Windows and Linux gbr Other Cool Front Ends 68 01-21-2009 09:55 PM
Linux duck duck goose! rocken Linux 11 03-12-2006 12:15 PM
what software works good meeki GPS 5 10-07-2005 08:08 AM
An update on the software in the works... CarComp ME Archive 6 07-03-2003 01:41 PM
Software Hibernation for Linux tbdombrosky Software & Software Development 0 06-22-2002 03:27 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
