Go Back   MP3Car.com > Mp3Car Technical > Linux
Old 06-09-2009, 10:36 AM   #1
licensed to kill
kev000's Avatar
kev000 will become famous soon enough
wifiproximity - generic AP based events processor
This is a generic daemon (GPL) I wrote that will integrate with NetworkManager and perform a number of actions when pre-defined wifi access points are within range of the system.
This is useful for doing things like automatic synchronization with home PC's when you arrive home. It can also perform these events after the access point goes out of range as well.
It's really rough right now, but it's a good start. This won't be a part of the OpenICE 1.0 platform, but hopefully it will be accepted in 2.0 as it matures.
If anyone is willing to make a simple event editor GUI, that would be awesome!
Here is an example "event" that will create a file, and issue an rsync command in my home dir:
Code:
<event ssid="linksys" trigger="OnAdded" strengthMin="20" connect="true"> <command type="system" bin="/usr/bin/touch" > <arg>/home/kev/rsync/linksys-was-in-range.txt</arg> </command> <command type="system" bin="/usr/bin/rsync"> <arg>-arvuz</arg> <arg>/home/kev/rsync/</arg> <arg>/home/kev/rsync-dest</arg> </command> </event>
Hope it comes in handy! The source is in the linuxice repo: https://linuxice.svn.sourceforge.net.../wifiproximity
LinuxICE2 beta2 is released!!! get it now!
OpenICE - The Free infotainment platform.
Follow OpenICE development
kev000 is offline   Reply With Quote
Old 06-09-2009, 11:17 AM   #2
cgalpin is an unknown quantity at this point
Dude, you are a madman! I'll put this in my top 10 of useful tools for a carputer so look forward to checking it out.
cgalpin is offline   Reply With Quote
Old 06-20-2009, 08:41 AM   #3
licensed to kill
kev000's Avatar
UPDATE:
I just added a couple new features and fixed some bugs:
* use "Auto" device to have wifiproximity use the first managed wifi device
* use "HwAddr" in addition to "Ssid" for access point identification (in case there are many "linksys" access points out there, and you don't want to connect to all of them heaven forbid...)
* wifiproximity will not longer connect to the AP, if a connection has already been made (in the case of networkmanager auto connecting before wifiproximity does).
* -D switch to run in daemon mode, or regular mode (default).
I just realized this, and it could be a cool feature in the future: You could run multiple instances of wifiproximity with different devices and have them do different things based upon what they see... WarDriving ftw? I'll have to add the -e [/path/to/eventfile] option.
Old 07-12-2009, 01:14 AM   #4
nottastocker's Avatar
nottastocker is on a distinguished road
I like the idea you have here. I am working on a configuration gui for this app, but I was hoping you could give me a breakdown of what tag has what attributes, what sub tags it can have, etc.
Mozilla Search Plugin
nottastocker is offline   Reply With Quote
Old 07-12-2009, 06:21 AM   #5
licensed to kill
kev000's Avatar
Awesome!
Here's a more full example:
https://linuxice.svn.sourceforge.net...src/events.xml
All possible attributes and nodes are in that example.
In an event there are only two types of triggers "OnAdded" and "OnRemoved". Obviously, strengthMin and connect attributes don't apply to an event with an OnRemoved trigger.
Right now, the only valid children for an event are <command> nodes. Also, the "type" attribute on the <command> node is ignored right now. Everything is treated as a system command.
<arg> has no attributes.
Let me know if you have any other questions. I'm looking forward to seeing the GUI in action.
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
RR 01/2009 ... Plenty of news.. guino Road Runner 165 03-03-2009 01:21 PM
Triggering events based on GPS location electron GPS 5 09-16-2004 12:57 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
