Go Back   MP3Car.com > Mp3Car Technical > Linux
Old 06-09-2009, 04:56 PM   #1
hdhouse3rd is an unknown quantity at this point
Lilliput 7" TS with Debian Install
Hope someone with experience in this can offer some advice. I am running Debian Lenny, kernel 2.6.29.4 and trying to install the Lilliput drivers for the 7" touchscreen.
Keep getting an error running make for Makefile 1249, which appears to be in the xf86drv directory running that makefile. The line in that makefile reads:
InstallLinkKitLibrary(xf86,$(LINKKITDIR)/lib86)
Is there a file that I am missing to install or do I have a bad link setup? The Makefile under this directory was Makefile~ which I renamed to Makefile.
Thanks in advance for your help.
Henry
hdhouse3rd is offline   Reply With Quote
Old 06-09-2009, 07:57 PM   #2
licensed to kill
kev000's Avatar
kev000 will become famous soon enough
Henry
What drivers are you trying to install? THe ones that came with your lilliput? Are they TouchKit/Egalax drivers? Are they evtouch drivers?
I personally use the Egalax/TouchKit drivers with all my TSs (lilliput and xenarc). There's a bunch of threads in this forum on how to get it installed, it's pretty simple.
LinuxICE2 beta2 is released!!! get it now!
OpenICE - The Free infotainment platform.
Follow OpenICE development
kev000 is offline   Reply With Quote
Old 06-10-2009, 03:39 PM   #3
I am using the factory disc. Also I have tried downloading directly from http://www.lilliput.com.cn/en/service02.php and end up with the same result.
I will look through the board again. The system is a bare bone Lenny install, so there may be a package dependency we are missing the install does not show the dependency. I have discovered a number of people who ran into the same error and eventually got it to work but they never posted the missing piece.
I appreciate whatever help you may provide.
Old 06-10-2009, 04:40 PM   #4
I used the drivers both supplied in the box and from the lilliput website. Both produced the problem mentioned. I had looked through the forums and unfortunately did not find a solution yet. Also spent sometime looking online, will this problem is referenced and ultimately they got it working but never mentioned the steps to get it going.
I am working from a barebone Lenny install with an upgraded kernel with a fluxbox frontend. So there may be a package missing but the error does not provide insight as to the problem.
Thanks again if you can possibly have any suggestions.
Old 06-10-2009, 05:53 PM   #5
unsungboxer is an unknown quantity at this point
Henry
im using the eby701 lilliput 7" and ubuntu. unfortunately im replying from my cell phone. im not sure you got the right drivers. search google for egalax drivers and select the result for the eeti website. then go to support and drivers. dl the linux one for ur kernal. the just extract and do your sh command.
i can get u better instructions later
unsungboxer is offline   Reply With Quote
Old 06-10-2009, 08:19 PM   #6
licensed to kill
kev000's Avatar
I agree with unsungboxer, use the drivers from the eeti website: http://home.eeti.com.tw/web20/eGalax...inuxDriver.htm
The stable will support xserver version up to 1.5. and the beta will support 1.6. to find out which version you have:
Code:
dpkg -l | grep xserver-xorg
Once you download:
Code:
tar xzf eGalaxblahblahblah.tar.gz cd eGalax... sudo sh ./setup.sh (follow the onscreen instructions...) sudo reboot (when it comes up again:) sudo TouchKit (run the 4 point calibration under "tools")
Good luck.
Old 06-10-2009, 09:39 PM   #7
Okay guys, thanks a bunch, will report back. I will give a try tomorrow morning. As it is sitting on my desk at work.
Thanks,
Henry
Old 06-12-2009, 01:09 AM   #8
I am trying out Ubuntu 9.04 (UNR), and the beta egalax drivers. The mouse is really jumpy. Anyone find a fix for this?
Old 06-12-2009, 02:49 AM   #9
licensed to kill
kev000's Avatar
I"m currently having some troubles as well. However, my experience is tied generally to multi-touchscreen setup. Maybe try the Option "Rotation" "0" in the egalax section of your xorg.conf? I'm beta testing a pre-release on my setup. There are still bugs...
Old 06-25-2009, 10:11 AM   #10
Wanted to say thanks to everyone for the advice. I ended up using as advised by several the Eeti website drivers.
As a cross reference it was a minimal install of Debian Lenny 2.6.26 w/o Desktop programs on the MP3 fleet spec computer with Toshiba 40gb hd. We later added in via apt-get apache, mysql-server, python, gcc, php5, x-windows-system, xfce4 and jdm. This gave the minimalist approach for the project I am working on.
Since it is backed up now I will be installing the other pieces to get this little box going.
Old 06-25-2009, 06:01 PM   #11
licensed to kill
kev000's Avatar
Mmmmm... Sounds almost like a base LinuxICE2 install (minus xfce4, gcc and such). Keep up the good work!
Old 06-25-2009, 06:27 PM   #12
Well the build is for a fleet deployment, hopefully. To be used by our truck drivers when they pickup and deliver loads. Plan on using a touchscreen through a web browser for them to input their data.
And yes I had given serious consideration to LinuxICE2. However, when Always Innovating confirmed that they will be using XFCE as their desktop and we have a couple Touchbooks on order for another part of the project it will it on the same platform.
We will have various other pieces completing the puzzle: WiFi Router, GPS, Cell Modem, and printer. The printer will be the next major challenge, in a week or two. Currently, putting some other software into deployment. Creating a button to give signal status through router and push data to the server. Also need to add a navigation feature, though haven't researched it in about a year. Completed a new mail server/IM server so we can reach people outside of office quickly. One more button to add to the computer. Maybe by end of July I can green light production.
Old 07-04-2009, 03:11 PM   #13
I have tried numerous different things without any luck. Anyone else have any luck getting the Beta drivers to work properly with Ubunt 9.04? When I softly touch the screen it follows my finger, but it bounces to the top left corner of the screen as I release causing me to click the wrong icons.
I have even emailed the EETI guys, but am awaiting a response. Any ideas?
Old 07-05-2009, 10:23 PM   #14
tdb30_'s Avatar
tdb30_ is on a distinguished road
Unsungboxer: check and make sure the touch screen isn't pinched. It sounds like there is pressure on the touchscreen causing it to jump. I don't think this is a driver issue.
My carputer project
tdb30_ is offline   Reply With Quote
Old 07-05-2009, 10:33 PM   #15
The screen works fine w/ Ubuntu 8.10 and WindowsXP. I believe it is the driver specifically for the new Linux Kernel. Is anyone successfully using the Egalax Drivers w/ Ubuntu 9.04?
lilliput 7" driver not recognize katuga23 Input Devices 19 06-28-2006 04:42 PM
Lilliput 7" VGA touch screen cables jeeve76 LCD/Display 4 03-03-2005 02:11 AM
Lilliput 619GL-70NP Touchkit XP Home Install Windchsr LCD/Display 2 04-25-2004 08:23 AM
In-Dash 7" MOTOR TFT or Lilliput 7" Touch Screen JonX69 LCD/Display 2 03-06-2004 02:22 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
