Go Back   MP3Car.com > Mp3Car Technical > Linux
Old 08-21-2009, 08:10 PM   #1
eurocarpc's Avatar
eurocarpc is on a distinguished road
The things I want in my Linux CarPC...
... and are not "standard" in my Ubuntu 9.04 .
These are all small ideas for scripts that shouldn't be more than a few lines in bash, but could be very useful for me.
I'm not talking about any specific distro fixes, these are things you would like to see in any Linux distro for the CarPC.
If anyone reading this codes at least one of them, I'll do another.
1. The screen goes black after 10min. Fixme
2. Filesystem integrity check loaded less often, only if stopped.
3. Small script to de-activate unnecessary services in the CarPC environment, like printing, and anything related to multiuser.
4. No ttys besides the graphical terminal are needed. Maybe one or two, just in case, not more.
5. Is there a program to modify the bootsplash image with the car brand logo?
eurocarpc is offline   Reply With Quote
Old 08-21-2009, 08:44 PM   #2
licensed to kill
kev000's Avatar
kev000 will become famous soon enough
Have you tried LinuxICE? It covers about everything except #2. Did I mention it's based on 9.04? For #5, take a look at "splashy" in the ubuntu repo. It's even got a UI to create the splash screen from any png. It's pretty cool.
LinuxICE - because my car already has enough windows (and because I like speed).
LinuxICE2 beta2 is released!!! get it now!
Follow OpenICE development
kev000 is offline   Reply With Quote
Old 08-21-2009, 11:00 PM   #3
eurocarpc's Avatar
I've downloaded the image but I haven't tried it yet.
The thing is, Kev that I would like to stick to a "standard-as-possible" ubuntu distro, and patch it using small scripts. So far, all the projects that I've seen split from the main distro end up failing because they can't keep up with the speed of updating and I wouldn't like to end up in that situation.
I may be wrong. Having an Ubuntu 9.04 base, maybe it is exactly what I need. I'll give it a go as soon as I find a few hours. (It's 4:55 AM over here )
P.D. : splashy conflicts with ubuntu-desktop and usplash-theme-ubuntu. Should I accept removing those two?
P.D.2 : I wanted to try nGhost; I downloaded the packages but couldn't install it. I'm a computer engineering student. I am not the smartest kid in class, nor a BOFH but... come on! You have to lower the entry barrier for all of these things you are creating and distributing. Make an effort to document and produce good, easy, understandable, step by step howtos! You are doing an excellent job, but if we don't manage to create the critical mass of users around them they won't succeed!
Thanks!
My project: double indash, Golf IV
http://www.mp3car.com/vbulletin/showthread.php?p=841754
Old 08-21-2009, 11:27 PM   #4
eurocarpc's Avatar
I've just run LinuxICE from the Alpha 1.0, in VirtualBox OSE. The install option doesn't show up in the apps->setup menu. In a few minutes, I had to reboot the virtual machine something like three times because the buttons in the lower part of the screen wouldn't do anything. Click on DVD, then DVD again... crash. Click on radio... crash. Navit at least run fine.
Old 08-24-2009, 02:57 PM   #5
licensed to kill
kev000's Avatar
why couldn't you install nghost from the package? If you got it from the sf.net page, it won't work with 8.10+. When the linuxice.openice.org server comes back online, i recommend getting your package from there.
for 9.04 you'll want to get a bugfixed version of splashy found in a ppa. After you get the 3rd pary repo, it's pretty easy.
Old 08-24-2009, 08:36 PM   #6
eurocarpc's Avatar
Yup, got it from SF. So, what is keeping your server offline?
Would you like me to host some stuff in my Uni. server? It's not very reliable, as we are having some connectivity issues in the last few weeks, but when it's working, it goes pretty fast.
Old 08-25-2009, 06:11 PM   #7
licensed to kill
kev000's Avatar
Power supply blew up. It's back up now though. We have a mirror, but when the main server goes down, there's nothing that will redirect you to the mirror :P.
-kev
Old 08-28-2009, 09:19 AM   #8
eurocarpc's Avatar
Kev000, could you please tell how does LinuxICE do 1, 3, 4 and 5?
Old 08-28-2009, 12:51 PM   #9
licensed to kill
kev000's Avatar
3 is accomplished by the simple fact that LinuxICE was built from the ground up with only the packages that are needed and nothing more.
see http://wiki.openice.org/index.php?title=Linuxice2 for how linuxice is built.
4, In LinuxICE, tty1 actually autologs the user in and .bash-profile starts X. I think the other tty's still exist. (I don't remember actually deleting them). At any rate, other tty's running have no effect on performance of boot or actual running.
5, LinuxICE uses splashy from a bugfix repo. The default package suffers from this bug. I fixed version can be found here.
Old 08-28-2009, 03:03 PM   #10
eurocarpc's Avatar
Anything about #1?
I've gone through the scripts to build the image. They don't seem to be too complex. I like that.
I'm actually creating a new image and reading the scripts as it works.
Old 08-28-2009, 06:50 PM   #11
licensed to kill
kev000's Avatar
Anything about #1?
#1, i'm not sure. It's an X11 setting I think. usually a tap on the sreen wakes it up. at least for me it does. LinuxICE doesn't have gnome-power-manager, so it doesn't put the monitor to sleep/turn it off.
Old 09-01-2009, 09:18 PM   #12
eurocarpc's Avatar
Yes, a tap on the screen will wake it up; the question is if LinuxICE already handles this, and how =)
Old 09-01-2009, 09:50 PM   #13
licensed to kill
kev000's Avatar
probably gnome-power-manager? I'm not doing anything special.
Old 09-02-2009, 02:10 PM   #14
Ribs is an unknown quantity at this point
Stopping the screen from blanking is easy:
xset s off
And you're done
Ribs is offline   Reply With Quote
Old 09-02-2009, 04:41 PM   #15
eurocarpc's Avatar
xset s off
And you're done
Yeah! That's the kind of answer I wanted! Thanks!
Tags
tweaks bash settings
Linux help needed - make fun of the N00b Bugbyte Linux 117 11-12-2009 07:46 PM
2008 Evolution X MR CarPC Project smanders Worklogs 7 11-07-2009 01:04 AM
OpenICE, Linux and Why pyr0 Linux 7 06-28-2009 05:29 AM
Carpc or Carputer Complete Guide smhussain Newbie 16 04-21-2009 06:58 AM
How can I use a laptop as a carpc? turbocad6 Laptops, Netbooks, Tablets, UMPCs, etc. 0 07-11-2007 01:55 AM
