Go Back   MP3Car.com > Mp3Car Technical > Linux
Old 10-25-2009, 02:01 PM   #1
North of the land of Hey Huns
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
RevFE - Linux style!
RevFE now officially supports all you linux folks! Well... at least the ones running ubuntu. Attached is a .deb installer for ubuntu 9.04, but it may work for other versions. Unzip and Install it using your favourite Debian installer. The default music directory is ~/.revfe/Music as set in /usr/share/revfe/settings.xml so put your music in there, or change settings.xml to match where your music is. Once you install it, run RevFE by typing RevFE in any terminal window.
A word of warning, RevFE is a bit dep-heavy, due it it's using phonon and Qt. You may also need to install gstreamer's good bad and ugly plugins to play mp3's if you do not have an appropriate codec on your system already.
Edit 11/10/09:
Removed link, see RevFE forum for latest linux version.
Edit 11/1/09:
Added some 0.43 changes, and fixed minor bugs that linux causes
Edit 10/28/09:
Fixed the crashing issue, as well as added the two taglib libraries to the dep list. Also added a feature where settings.xml defaults the music directory to ~/Music and the musicdir variable accepts ~ and replaces it with the users home directory.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 10-25-2009, 02:27 PM   #2
unsungboxer is an unknown quantity at this point
Sounds cool. how do you start it? I can't find the launcher, and running it in terminal as RevFE gives me a segmentation fault
unsungboxer is offline   Reply With Quote
Old 10-25-2009, 02:31 PM   #3
It seems I forgot something, you need libtaglib. on ubuntu the packages are:
libtag1c2a and libtagc0
I'll add them to the deb dependencies for the next version
Old 10-25-2009, 02:49 PM   #4
I ran:
Quote:
sudo apt-get install libtag1c2a
sudo apt-get install libtagc0
They are both already installed.
Here is the output I get when I try to run RevFE from terminal:
Quote:
QPixmap: It is not safe to use pixmaps outside the GUI thread
QThread: Destroyed while thread is still running
QMutex::lock: mutex lock failure:
QMutex::lock: mutex unlock failure:
Segmentation fault
Old 10-25-2009, 03:07 PM   #5
Try editing /usr/share/revfe/settings.xml to point the musicdir to ~/.revfe/Music
Its currently set to point to the executable directory, yet another mistake in my packaging. Sorry this is my first attempt at making a deb file
Old 10-25-2009, 03:58 PM   #6
I ran:
Quote:
sudo gedit /usr/share/revfe/settings.xml
I changed the last line to:
Quote:
<plugin name="MediaLibrary">
<setting musicdir="~/.revfe/Music"/>
</plugin>
Then I execute (because there is no launcher yet):
Quote:
RevFE
It runs! I am not sure if the GUI looks as intended though?
Old 10-25-2009, 04:11 PM   #7
It's a rather simplistic gui.. I'm no artist . Upon starting you should see something similar to this: http://www.mp3car.com/vbulletin/revf...-frontend.html
As soon as I can figure out how to have it install a launcher in the menu i'll do that.
Old 10-25-2009, 04:13 PM   #8
I will keep playing with it. It is not currently loading the media.
Does this work with the openport USB cable?
By the way, great work!!! I am excited to see this front end come to ubuntu.
Old 10-25-2009, 04:23 PM   #9
Not sure what you mean by the openport USB cable?
Media should be in the following format for it to be read initially:
MusicDir/Album/Mp3File.mp3
etc etc.
Though you can edit and save new playlists at any time, adding media from anywhere on your hard drive.
Old 10-25-2009, 04:49 PM   #10
etc etc.
- By OpenPort, I am referring to this OBD2 usb cable (Commonly used by mitsu/suby/nissan tuners):
http://www.tactrix.com/product_info.php?products_id=49
-After reviewing your link, the gui still doesn't appear properly. Here is a screenshot:
http://farm3.static.flickr.com/2677/...f9f904b7_b.jpg
(dont worry about the transparancey, that is just a compiz effect).
-Also, I have loaded the music as you suggested, but it does not appear in the GUI.
I hope you dont mind the feedback, Thanks again for your hard work!
Old 10-25-2009, 04:57 PM   #11
I really do appreciate the feedback in getting this working. The GUI is showing up correctly, and I've managed to duplicate the media not showing up issue. I'll work on it and let you know
As for the OBD cable, there is an OBD2 plugin, which is compatable with ELM327 devices, but it's not currently released.
Old 10-25-2009, 05:06 PM   #12
It seems you can't use ~ for the musicdir, you have to use the absolute path. In my case it is /home/michael/.revfe/Music (which is what ~/.revfe/Music expands out to)
Old 10-25-2009, 05:20 PM   #13
Changed line to:
Quote:
/home/myusername/Music/
Media scanning finished. Total playlists found: 2
Starting to scan id3 tags
Segmentation fault
UPDATE:
Ran RevFE, went to Media Library and clicked some buttons. Now all my music shows up in Audio Player. Seems like the media library function has to be performed?
Old 10-25-2009, 05:28 PM   #14
Try running it again. I've noticed a bug where it sometimes crashes in that fashion, I'm looking into it.
Old 10-28-2009, 09:42 PM   #15
I've updated the first post with a new deb file which fixes the crashes, and also allows ~ symbols to be put in the musicdir.
You have to select a playlist from the media library before it shows up in the playlist, yes. It does not load any playlist when you first run it by default.
New Frontend for Windows and Linux gbr Other Cool Front Ends 68 01-21-2009 09:55 PM
Linux duck duck goose! rocken Linux 11 03-12-2006 12:15 PM
The LOW Risk Linux Adventure... grepzen Software & Software Development 13 11-08-2004 10:12 PM
