10-09-2005, 01:11 PM
#1
lirc
Just wanted to see who has used lirc before. I haven't, but I plan to.
10-09-2005, 03:45 PM
#2
me - a while ago...
10-09-2005, 04:38 PM
#3
Thats cool. I was looking at the schematic and it looks like they do alot of crazy stuff to get power to the actual IR Reciever. I don't see why one couldn't just supply it with +5vdc.
10-10-2005, 04:04 AM
#4
I'm not sure what receiver you are looking at but if i remember correctly I only used 5 components for mine, and ther was nothing crazy about. I thought it was very elegant and simple.
Caputer Mk. II
'02 VX Holden Commodore Series II Executive
MII12000, 512MB RAM, 60GB HDD (5400rpm), 16X DVD, TS200V
Morex 60W DC-DC, Custom S/SDC
OS/Software: Developing...
10-10-2005, 09:17 AM
#5
http://www.lirc.org/receivers.html
Scroll about 2/3rds down the page. It looks to me like the whole circuit is designed to power pin 2 of the receiver from the serial port's RTS signal. I guess the software will turn RTS high while the receiver is in use. I think this is just so no external power is required.
Mine will be mounted inside of my case, so +5V is readily available
I'd like to know if I can just eliminate the regulator; creating a circuit like:
Code:
IC1 = TSOP 1738
+-----------------------+ 3 R1 (4k7)
| data -> +--------------------------------+--------o DCD
| ______________ | | |
| ( | 2 | | + | |
| \______________ + +----+ ----- +----+--------o VCC
| | 1 |
| - +----------+------------------------------o GND
+-----------------------+ C1 (4.7µF)
10-10-2005, 12:02 PM
#6
A little under that schematic on the lirc page, it says:
Quote:
Instead of pulling the power supply from the serial port you can also use a different source like e.g. the USB port or the internal 5V line to power the circuit. Then you won't need a voltage regulator at all.
So, looks like you can definately get away with a different power source.
10-10-2005, 01:22 PM
#7
OK, I was just making sure I wasn't omitting any important parts. I almost leftout R1. However, R1 is a pull-up resistor, so it is essencial for a clean output.
10-10-2005, 05:03 PM
#8
as a side note, since its relevant to linux and lirc:
some sound cards have builtin ir ports. if you're using say the audigy nx, like me, or some other external usb cards, you can actually use alsa to configure the ir port. this is relatively new, so you may have to use the cvs versions of lirc and the latest version of alsa. it takes a bit to configure it, but it works quite well.
10-10-2005, 05:10 PM
#9
Thanks, that is good to know.
10-10-2005, 09:47 PM
#10
I've built two IR receivers for use with LIRC (actually taught 13-16 year olds to build one of the simpler ones from the LIRC site), and I can tell you that for the parts costs, it's simpler to just find a cheap remote / serial port receiver combo that you don't have to worry about damaging.
I found a source on Ebay a couple years ago for old HP serial port receivers and remotes. They were something like $5 US, and everything is nicely encased and semi-water tight, so the receivers are quite durable. The remotes turned out to be not too shabby as well and worked famously with LIRC. I used to use my PC to control everything (TV-out to the TV, receiver always on the PC input at mid-volume), and this worked pretty flawlessly after being set up.
No matter which way you go for the receiver, you can't go wrong with LIRC. There are so many apps now with LIRC plugins.
10-11-2005, 03:28 PM
#11
I've built several of the serial IR receivers for my home theater PC. They are easy and cheap and work wonderfully. I never found anything even remotely close pricewise that was available for sale. I had never really soldered before either.
LIRC is great software. Once you get your remote set up properly it works like a charm. I've been running it for over a year with no problems at all.
| Thread Tools |
| Display Modes |
Linear Mode
