The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Linux
Thread Tools Display Modes
Old 03-20-2006, 07:54 AM   #1
reece146's Avatar
Vehicle: 2000 Honda S2000, 2001 Jeep Cherokee
My Photos: (0)
Multiple consoles in one vehicle
I'm toying with the design of my next project. It will have four to five different consoles, one for the driver using my existing prototyped environment and the rest will be "general purpose" workstations for doing pretty much anything that the passenger desires. It will be based upon the prototype though so that is the default mode (headphones for passenger specific AV playback, button to toggle to "desktop").
What I'm trying to decide at this point is what hardware model to follow.
Do I use one big SMP mobo or multiple, separate systems?
I'm keen on something like a single dual Xeon (w/ HT) mainboard (or AMD equiv) but I am worried about latency caused by system load affecting the driver's console. Couldn't care about the other users being affected.
In the one mainboard model each user gets their own dedicated X-Window server while using dual head display cards to reduce the number of display cards required. That's at least 1 ACP and 2 PCI display cards for 5 seats so that dictates at least one mainboard feature. I may have to remove one console (four seats total).
Is there an operating system level virtualization/partitioning engine for Linux that can be used to guarantee OS partition performance and/or soft real-time performance?
I'm not terribly keen on separate systems per console, or even one dedicated to the driver if I can avoid it. Separate systems will be more expensive, occupy more space, etc., etc. X-terms might reduce some of the complexity in multiple systems but it is still a distinct hardware footprint per seat (dollars and space). I'll listen to good debate.
Heat and noise are an issue. I haven't turned my attention to quieting the dual Xeon board I have now but surely there must be a quieter fan for Xeons other than what ships from Intel? It's quite noisy.
What say you?
TIA
reece146 is offline   Reply With Quote
Sponsored Links
Old 03-20-2006, 09:14 AM   #2
Zimans's Avatar
Vehicle: 2004 Mazda 6s
My Photos: (0)
If you get a MB with on-board video than you only need 1 AGP and 1 PCI for 5 seats.
What software do you intend on running on these terminals?
--ZIms
Now, Where are my Pants?
Zimans is offline   Reply With Quote
Old 03-20-2006, 09:24 AM   #3
reece146's Avatar
My Photos: (0)
Very good point, my brain is on standby I guess.
Pretty much anything that suits the passenger. The primary purpose is AV entertainment and I'd use a modified version of my front end for that. I'd like to make other applications for general purposes available for long distance travelling. Might be a good time to write a letter, do pet projects, that kind of thing.
Old 03-20-2006, 02:06 PM   #4
intuitionsys's Avatar
Vehicle: 2005 Ford Freestar Limited
My Photos: (0)
Just be aware that some motherboards share the AGP slot with the onboard video so adding an AGP card on those boards would just replace what you already have rather than add to it.
Silverwolf 2.0 Progress: 100% (alpha)
Alpha Release Date: June 28, 2007
intuitionsys is offline   Reply With Quote
Old 03-20-2006, 03:31 PM   #5
reece146's Avatar
My Photos: (0)
Good point.
Old 03-20-2006, 07:31 PM   #6
TheLlama's Avatar
Vehicle: 2001 Paper Airplane Standard Edition
My Photos: (0)
you can also make it so that the driver's programs have a lower nice value (higher priority). This way, if the other users really are hogging cpu, they won't take it from you. I think there is a daemon somewhere that will renice processes based on the uid or process name. If not, it shouldn't be too difficult to write one.
Edit: Dur, I just remembered. Just start all the passenger's consoles (or frontends, whatever) with a lower priority than the driver's console. Every program started from the passenger's consoles will have the priority of the process that spawned it (the shell or the frontend)
TheLlama is offline   Reply With Quote
Old 03-21-2006, 09:29 AM   #7
reece146's Avatar
My Photos: (0)
Thanks for the input guys.
I'm trying to get my head wrapped around how much "horsepower" will be required. I'm doing a little prototyping of the environment in the lab but am uncertain were to go from the uni-proc 1.7GHz P4 I am playing with.
iBase has a new-ish Mini-ITX board that uses the Intel Duo <http://www.ibase-i.com.tw/mb899.htm>. Adding a backplane would allow two PCI display cards with dual DB15 ports. This would give a small footprint and a SMP base but I'm not sure if that is the way to go. Enough horsepower? The onboard video is lack luster but only basic 2D window manager type functions are needed on the driver's console... any form of 3D in gpsdrive is at least a major release or two away if ever.
I was doing a little schematic of all the devices this setup would require - a nutty total of ~24 USB devices depending on how it gets finalized. I guess powered USB hubs will be required.
Tyan has some way cool 4 way Opteron boards that support the dual core CPUs (8 Way!). That would be fun but be like dropping dynamite in a bait bucket and calling it fishing. It's also large scale gear with all the inherent noise, space, and $$ problems.
Anyone have first hand impressions with the Intel Duos yet? Impressions? Low power draw P4 by another name?
Old 03-21-2006, 12:01 PM   #8
My Photos: (0)
I don't have any direct experience with the Intel Duos but just from technical research I've been doing for a replacement computer for my studio, the dual core AMD processors appear to have a price/performance edge and much higher FSB speeds, which is probably what is more important for what you're doing. Even the Sempron CPUs are $$$ though
Old 03-21-2006, 01:09 PM   #9
TheLlama's Avatar
My Photos: (0)
I've been an AMD advocate since the K6. AMD has gotten much better over the years and the Athlon64 and Opteron chips pack much more performance for the price as compared to their Intel counter-parts. AMD also has some really good stuff brewing for 4th quarter this year.
So, the moral of the story: I would recommend AMD as well, simply because I don't like Intel's desktop chips (or their server chips for that matter).
Old 03-21-2006, 01:20 PM   #10
reece146's Avatar
My Photos: (0)
I'm more of an Intel fan than a AMD fan but am fairly agnostic in general.
I haven't touched AMD since the 386-40 days.
Sponsored Links
vB code is On
Trackbacks are Off
California Carputer Legality? agentloveless General MP3Car Discussion 34 11-10-2005 03:29 PM
Welsh Man Arrested, Fined for Modifying Xbox Consoles tj!2k4 Off Topic 5 09-02-2005 09:40 AM
Article: Privacy of vehicle information being debated VanMan69 General MP3Car Discussion 10 03-15-2005 02:59 AM
Mobile video in California dacndar LCD/Display 45 11-30-2004 02:36 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
