04-14-2006, 10:31 AM
#1
iguidance linux
Hi,
I have installed iguidance on my gentoo linux with crossover office 4.
It runs perfectly, but it cannot find the gps reciever?
how can I set the com4 port on /dev/tty0?
thanks
04-14-2006, 11:53 AM
#2
Quote: Originally Posted by sarasini
Hi,
thanks
How exactly would it run perfectly if it couldn't find the GPS receiver?
EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
04-14-2006, 01:16 PM
#3
can you help me, or not?
04-14-2006, 02:27 PM
#4
IIRC, you set up a symbolic link in ~/.wine/dosdevices called 'com4' and point it to /dev/tty0. You should probably check the docs though, as there may have been a double colon or a config file needed. Hopefully the problems with mapping com ports in WINE (what Cross Over Office is based on) have been fixed, as that was broken in a few versions.
04-14-2006, 02:48 PM
#5
The latest version of Wine indeed maps COM ports correctly.
04-14-2006, 03:02 PM
#6
now when I do "gps auto detec" the program crash.
if I set the port manually it do non tell me anything but the
gps doesn't work...
04-16-2006, 07:58 AM
#7
anyone is using iguidance on linux?
04-16-2006, 01:04 PM
#8
Raw Wave
I'm going to be trying it soon. I'll let you know if I get any further.
04-16-2006, 01:26 PM
#9
thanks
04-16-2006, 09:01 PM
#10
Does your version of crossover office use the symlinks-in-$WINEPREFIX/dosdevices way of configuring it or are the serial port mappings stored in the config file?
I've had mixed success getting iguidance to run. Under Cedega 5.1 the navigation program itself runs and is able to read data from the GPS, but the map loader refuses to start. Under an older, free winehq version of Wine dated 20050211 both the map loader and the navigation program run fine, but the navigation program fails to read any data from the GPS.
One thing that got me at first, the permissions on /dev/ttyUSB0 were too restrictive and prevented the unprivileged wine process from opening the GPS receiver.
04-17-2006, 05:54 AM
#11
use the simlinks
how do you set the gps port in cedega???
thanks
04-17-2006, 06:48 AM
#12
how do you change the permissions on /dev/ttyUSB0?
| Thread Tools |
| Display Modes |
Linear Mode
