The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Linux
Thread Tools Search this Thread Display Modes
Old 06-05-2006, 11:13 PM   #1
My Photos: (0)
Quicker boot times?
What would you guys suggest to streamline the boot process?
Are there any specific distros you would suggest?
I think I'm going to go with Ubuntu as a base install, then recompile the kernel to be lean, and install something like XFCE for a quick windowmanager.
My '94 C1500 truck.
jon_k is offline   Reply With Quote
Sponsored Links
Old 06-06-2006, 10:57 AM   #2
Change's CarPC Specs
Change's Avatar
Vehicle: 03 Honda Civic sedan
My Photos: (0)
Check out XUbuntu, it's Ubuntu with XFCE instead of Gnome. Saves you a bit of trouble in removing unnecessary Gnome stuff and getting XFCE installed.
http://www.xubuntu.org
System status: in progress
Change is offline   Reply With Quote
Old 06-06-2006, 11:23 AM   #3
f1vlad's CarPC Specs
f1vlad's Avatar
Vehicle: 06 WRX TeaR
My Photos: (0)
I'll try this tonight too, last night installed FEDORA CORE, it's too slow bootup compared to Windows XP
f1vlad.com/wrxtear/carputer
■■■■■■■■■■■■■■■■■■■■■ 80% progress ¤
New England carputer meet. Click here.
f1vlad is offline   Reply With Quote
Old 06-07-2006, 10:47 AM   #4
Vehicle: 2000/Volkswagen/Jetta
My Photos: (0)
Make sure you turn off all unnecessary services. Do a
Code:
chkconfig --list | grep 3:on
to see which services are started at boot time. You can get rid of a whole bunch of 'em, especially in a car environment.
sumit_b is offline   Reply With Quote
Old 06-11-2006, 04:19 PM   #5
blk
blk's Avatar
Vehicle: 1996 VW Golf III Variant
My Photos: (0)
initng
check out initng, it's quite a boost for me, have a running myth frontend (on ratpoison-wm, so quite minimal) in about 30sec from grub.
what it does is basically heavily parallelize the boot process, to not idle around
blk is offline   Reply With Quote
Old 06-12-2006, 02:20 AM   #6
My Photos: (0)
Thanks for the comments. The chkconfig or other proprietary redhat-only commands wont work as I'm on debian.
I've basically parallized the booting process, and stripped all unneeded init scripts.
Seems to work.
My '94 C1500 truck.
Old 07-17-2006, 11:51 AM   #7
Banned
My Photos: (0)
Wouldn't using a flash drive for the booting system really speed up the process?
Kinda make an embedded Linux, using the HD only for data storage.
bugmenot13 is offline   Reply With Quote
Old 07-17-2006, 12:00 PM   #8
shotgunefx's Avatar
Vehicle: 2002 Chrysler Sebring Coupe LXI
My Photos: (33)
Seems to work.
I've found some aspects a real PITA with Debian. Some things are not as transparent as they could be. Like, how the hell do I stop modules from being loaded? They're are multiple places to blacklist them and none seem to work.
For instance, I have firewire, but no desire to use it or load it, figure I might be able to shave off a second or so taking out all the related modules, but for the life of me, I can't make it do it outside of renaming the modules. /etc/modutils/aliases is not cutting it.
You might want to look at bootchart, it's in apt for testing (don't think it's in stable, but not sure), it's a good tool for timing boots and showing what's taking up all the time.
What is everyone else getting for boot time? I'm at 35 seconds. Not bad, not great.
OTOH, suspend/resume is taking almost the same amount of time as a boot. I'd really like to hear some tips in that department.
shotgunefx is offline   Reply With Quote
Old 07-17-2006, 01:01 PM   #9
Change's Avatar
My Photos: (0)
Bootchart is in testing and unstable, if you're running stable you can get the bootchart source package and compile it for your system.
See here: http://lyre.mit.edu/~powell/debian-h...ld-source.html
(an easy way to make sure all dependencies are met for the source package is apt-get build-dep packagename)
Old 07-17-2006, 01:41 PM   #10
shotgunefx's Avatar
My Photos: (33)
Any thoughts on preventing the xx1394 modules loading? Is it hotplug doing it?
I keep cutting services and what not but I can't get past 33 seconds. I think most of it is hotplug. (Not sure if I'm reading the bootchart correctly)
Sponsored Links
Old 07-18-2006, 01:01 PM   #11
Change's Avatar
My Photos: (0)
Hm. List of Hotplug-related files here: http://www.die.net/doc/linux/man/man8/hotplug.8.html
More documentation here: http://linux-hotplug.sourceforge.net/
Aha, there's an /etc/hotplug/blacklist file that can be used to specify modules you never want loaded: http://www.bangmoney.org/presentations/hotplug/
Old 07-18-2006, 01:21 PM   #12
My Photos: (0)
Cool fedora: early-login
Fedora's early-login for gdm works well, its much faster than a full boot up to login. This is one of the reasons I use fedora, and I ditched debian b/c the bootup is too long and no way around it.
rocken is offline   Reply With Quote
Old 07-18-2006, 01:43 PM   #13
Change's Avatar
My Photos: (0)
runit is another init replacement, and there's even a Debian package for it: http://www.debian-administration.org/articles/199
(Downside to runit is that it seems to work quite differently than init/initng, but initng is currently only in Debian experimental)
Old 07-18-2006, 05:28 PM   #14
shotgunefx's Avatar
My Photos: (33)
Thanks, it gets confusing with the various subsystems. modutils/udev/hotplug.
I think I'll have to read up a bit more on coldplug too.
Don't know if I mentioned it or not, but I fixed my sound getting borked on resume. I had ampd and acpi both running. Getting rid of ampd fixed it.
Old 07-19-2006, 03:17 PM   #15
Change's Avatar
My Photos: (0)
Let me know what you find about hotplug. My system appears to be loading modules from /etc/modules and then hotplug loads and attempts to load the same modules all over again...time to get to the module tweaking!
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Boot times 84RegalRider Linux 50 07-23-2007 02:58 PM
Help! Monitor (PC to Avic-N1 via RCA) won't display anything after boot up screen! lil' is 300 General Hardware Discussion 6 04-09-2006 02:23 PM
boot times with XP Alives General Hardware Discussion 2 11-15-2001 12:42 PM
boot times pinkysqueaks General MP3Car Discussion 39 08-31-2001 06:30 PM
boot times for mp3 players alany General Hardware Discussion 4 12-16-1999 12:09 AM
Sponsored Links
Ad Management by RedTyger
