Go Back   MP3Car.com > Mp3Car Technical > Linux
Old 07-10-2006, 03:54 AM   #1
Raw Wave
shotgunefx's Avatar
Tips if your running Debian unstable
Never, ever upgrade *****ING anything.
This should have been a post about all the little custom tweaks, scripts, etc to get everything just so.
But like an *******, before I threw it back in, I upgraded udev. Now I have an unbootable system. (Took 10 hours to notice due to restore )
Restoring from my tar of the filesystem, it's still unbootable, still hangs with "- waiting for root fs"
I'm just about done. I'm seriously considering just quitting and throwing my headunit back in. If I have to redo the system, it will be the third time in two weeks. **** this. Sick of spending tens of hours at a time getting everything right just to get it trashed.
Sorry for the rant, but I'm just so ****ed off.
shotgunefx is offline   Reply With Quote
Old 07-10-2006, 05:03 AM   #2
Ummm, yeah, so do you need help? Give me a PM with your screen name (if you have one) and I'll walk you through getting your system back up (I'm constantly installing debian on just about everything for my friend in Florida, so I've gotten quite good at it.)
Zakabog is offline   Reply With Quote
Old 07-10-2006, 11:42 AM   #3
intuitionsys's Avatar
...or you could switch to Gentoo
Silverwolf 2.0 Progress: 100% (alpha)
Alpha Release Date: June 28, 2007
intuitionsys is offline   Reply With Quote
Old 07-10-2006, 12:39 PM   #4
Raw Wave
shotgunefx's Avatar
Thanks for the offer. I think the answer is here. I just really needed to vent. This install has been fighting me tooth and nail.
Might be something to do with the pc/car or something totally irrelavent, but it's always something. Whenever I make some headway, another damn problem comes up.
I really wanted to finish it up this weekend while I had use of some private parking.
Old 07-10-2006, 12:41 PM   #5
Raw Wave
shotgunefx's Avatar
I just might give it a try.
Old 07-10-2006, 05:53 PM   #6
Change's Avatar
I ran some systems unstable for a while, then when unstable transitioned to a new gcc that broke all my kernel compiles, I decided it was time to stick with stable. Now I just have deb-src entries for testing and unstable so I can backport any packages I desperately need the new version of without breaking everything else. It works out fine for me.
System status: in progress
Change is offline   Reply With Quote
Old 07-10-2006, 11:57 PM   #7
Raw Wave
shotgunefx's Avatar
Most of the machines I've set up over the years were all source installs (all servers)
I need to get a better feel for the different management systems of the various distros.
Anyway, booted in rescue mode, installed udev and that fixed it. Had to reinstall nvidia & googlearth for them to work again, but all in all, easy.
Old 07-11-2006, 02:22 AM   #8
Change's Avatar
Ooh...if you want a good story, I screwed up a system so thoroughly trying to downgrade from unstable to stable that dpkg wouldn't work. That was fun
Old 07-13-2006, 06:26 AM   #9
Raw Wave
shotgunefx's Avatar
Sounds like fun.
The only thing really left I would like to do is get Suspend2 working. Though the thought of trashing my system yet again is making me hesitant to build a kernel.
Old 07-22-2006, 11:51 AM   #10
blk
blk's Avatar
building a kernel never trashed a system, just boot from the old kernel if something doesn't work (switch at boot prompt)
blk is offline   Reply With Quote
Old 07-22-2006, 12:08 PM   #11
Raw Wave
shotgunefx's Avatar
It wasn't the kernel build that killed it. Something happend when it tried to upgrade x.org, but seeing how often I'm hitting walls, I'm afraid to tempt fate.
update
But I did temp fate last week and get suspend2 going, though doesn't seem worth it. It was a PITA too. Options missing out of menuconfig, etc.
Old 07-22-2006, 12:40 PM   #12
blk
blk's Avatar
had things like these on ubuntu unstable, was mostly because of new directory locations, the right symlinks made it work again (took some hours to figure out those though, as i first had to diagnose the problem)
good luck with sw.susp2, never tried it myself, all i do is boot optimizing (initng, least deamons possible, maybe i'll try linuxbios (risky as i don't have a replacement in case i brick it))
power problems while car is running.. TimW General Hardware Discussion 28 03-18-2006 09:11 PM
Debian Linux Questions Scorpion1985 Software & Software Development 6 09-04-2004 11:04 AM
How to keep the comp running when starting engine the_spy_guy Power Supplies 7 09-03-2002 06:33 PM
error on running cobra player noproblem Software & Software Development 0 08-07-2000 10:19 AM
Finnaly up and running, but buzzing mp3stealth General Hardware Discussion 2 05-17-2000 09:19 PM
