The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Linux
Thread Tools Display Modes
Old 08-24-2006, 05:42 PM   #1
My Photos: (0)
Question xenarc touchscreen(usb) not detected on startup -CentOS4
Hi,
I have a xenarc 1020 tsv touchscreen, with CentOS 4. The touchscreen is caliberated and it works fine, when the touchscreen is connected after the OS boots. (the hotplug works)
For some reason, the touchscreen is not detected if it is connected before I start the computer.
cat /proc/bus/input/devices does not list the device.
lsusb does not show any usb device connected.
The weird part is, if I connect a USB mouse and the touchscreen before startup, then both these devices are detected. If only the USB mouse is connected before startup, then that is detected too.(hence I can say that coldplug works)
any pointers?
Thanks.
mclarenfan is offline   Reply With Quote
Sponsored Links
Old 08-27-2006, 08:42 PM   #2
Vehicle: 2006 Subaru STI
My Photos: (0)
This happened to me as well in gentoo. If the touchscreen is showing up in dmesg after bootup then reinstall/rebuild coldplug and hotplug. I got info from here: http://groups.google.com/group/fa.linux.kernel/browse_thread/thread/b89783a1e2682771/6b5222475d5c5c2f?lnk=st&q=linux+usb+mouse&rnum=2&h l=en#6b5222475d5c5c2f
2006 Subaru STI
Voom2PC with CN700 Lilliput 7" Digimoto mOByDic
Sirius-SR1 BU-355 - EWF/Roadrunner/LSX
saverio911 is offline   Reply With Quote
Old 08-28-2006, 03:16 PM   #3
My Photos: (0)
Thanks for the reply!
The touchscreen does not show up in dmesg...
Even when I disconnect the USB to connect it again, dmesg shows nothing. It does show up a entry when I reconnect the USB.
I am using the following udev rule: (I read about it here: http://www.mp3car.com/vbulletin/linux/55727-touchscreen-changing-usb-event-device-power-off.html)
BUS="usb",KERNEL="event*",SYSFS{manufacturer}="eGa lax Inc.",SYMLINK="touchscreen"
does this look right? because now even the usb mouse is not detected (when USB mouse is the only device connected)
Old 08-29-2006, 03:16 PM   #4
My Photos: (0)
If you get no listing in dmesg you aren't going to get anywhere.
When you hot plug the device after bootup do you get any new messages added to the bottom of /var/log/messages or dmesg or wherever you configured you box to send them?
I would remove the UDEV rule just to see if coldplug works again. If it does then the UDEV rule is the most likely culprit. For me, at least, UDEV has a steep learning curve. Every UDEV rule I have made from scratch needs 4 or 5 iterations to work right.
Oh yeah - shouldn't it be SYMLINK="input/touchscreen" instead of just SYMLINK="touchscreen" so you get /dev/input/touchscreen?
2006 Subaru STI
Old 08-31-2006, 02:08 PM   #5
My Photos: (0)
when I hotplug the touchscreen, this is what dmesg gives:
usb 2-2: new low speed USB device using address 2
input: eGalax Inc. USB TouchController on usb-0000:00:10.0-2
usbcore: registered new driver touchkitusb
I removed the udev rule, but no luck, device still not detected at boot.
Old 08-31-2006, 04:36 PM   #6
My Photos: (0)
Which version of UDEV tools are you using? If it is not current or you rebuilt it from source I would do a refresh. According to rpmfind the current version for RHEL (which I use the srpm to build with) is 039-10.8. I wish I could be more helpful but I am only using CentOS for my servers and not my carpc.
2006 Subaru STI
Sponsored Links
Trackbacks are Off
Survey: Startup times and methods gnomad General MP3Car Discussion 56 01-02-2007 11:55 AM
Auto startup and shutdown of Xenarc 700idt JimmyCoke LCD/Display 0 07-31-2006 06:32 PM
Xenarc touchscreen - recalibrate on startup? -zerodb Input Devices 3 09-22-2005 08:00 AM
Startup controller and Xenarc TSV nsmoller Power Supplies 4 01-20-2005 09:05 PM
xenarc controller not being detected fallnangel LCD/Display 5 01-18-2005 10:55 PM
Sponsored Links
Ad Management by RedTyger
