Go Back   MP3Car.com > Mp3Car Technical > Linux
Old 11-06-2006, 07:51 PM   #1
monkeyBox's Avatar
monkeyBox is on a distinguished road
Lightbulb Custom carpc distro
Hi all, I was thinking about starting a new project, similar to minimyth, that will aim to be a carpc-specific linux distro that would have a relatively small footprint. It will also be fine-tuned to support the features available in the VIA EPIA series motherboards. The minimyth project already has most of the difficult stuff in place (ie, getting all of the epia-specific drivers working, getting X to work, etc..). The idea would be to take minimyth and strip out the mythtv-specific stuff, and add in a carpc frontend w/ all the necessary linux apps installed (mplayer/xine, roadster, etc..). Among other things, I could add-in support for various touchscreens, support for "plug-n-play" devices such as iPod and other music players, etc... Unfortunately, right now I have no idea what carpc frontend to use. All the ones I've seen seem fairly "blah" compared to the different windows offerings. I don't feel like building my own, but who knows, it may come down to that :P
Anyways, I just wanted to post here to see if there would be any interest in such a thing.
monkeyBox is offline   Reply With Quote
Advertisement Sponsored links
Old 11-06-2006, 09:42 PM   #2
BarryWoods's Avatar
BarryWoods is on a distinguished road
Wasn't this already suggested?? It would be cool, but you'd have to specify the hardware supported.
Failure is not an option....
It's installed by default on every version of Windows.
BarryWoods is offline   Reply With Quote
Old 11-06-2006, 10:46 PM   #3
licensed to kill
kev000's Avatar
kev000 will become famous soon enough
Go for it man!! There are already several of us working on front-ends. A car specific distro for those would be good. Also making suggestions on how to improve the already written and in-progress front-ends would probably help. I'm sure the authors are willing to listen to requests and suggestions.
kev000 is offline   Reply With Quote
Old 11-07-2006, 09:02 AM   #4
the_crowbar is an unknown quantity at this point
I say go for it as well. I would be willing to help in whatever way I can. Right now I run Gentoo but cross compile it from my main desktop. A fully loaded Gentoo setup takes ~550MB once the portage tree and source code directories are removed. I don't see why a EPIA specific distro should not easily fit on a 256MB flash drive.
There is no reason why we could not make an image that could easily fit on a 256MB flash drive. If it was as easy as writing out the image and setting the BIOS to boot from USB I could see many people trying out Linux in their car. I have been playing around with Gentoo on a flash drive for testing in my car.
I think SilverWolf 2.0 is coming along. Nanonymous, that Kev000 is writing, also looks promising. I am not much of a coder, but I do have quite a bit of experience in Linux admin and Perl/PHP scripting.
Cheers,
James
the_crowbar is offline   Reply With Quote
Old 11-07-2006, 09:22 AM   #5
monkeyBox's Avatar
The hardware supported (as mentioned in the original post) would be the EPIA-M series motherboards (namely right now the M10k, as that's the only one I have), and the embedded audio/video on that board.
Old 11-07-2006, 09:34 AM   #6
monkeyBox's Avatar
It's good to see that some people are interested in it. My plan is to kick-start the project in the hopes that others will take it and run with it, as I don't have all the time in the world to spend in front of a computer. My initial to-do list is:
1) Copy over the minimyth GAR repository to SVN
2) Get the GAR build system working on my local box
3) Strip out any mythtv-specific stuff
4) Decide on a frontend
5) Get the frontend built in the GAR system
6) Start a website for the project...
Old 11-07-2006, 09:49 AM   #7
reborg is an unknown quantity at this point
I'd offer to get involved too, but unfortunately I don't have time at this point.
I can however offer to donate web hosting and if you want to house a CVS repo there that is fine too. There is also a (as yet unused ) Vbulletin on my host with which you could run a support/info/request forum.
reborg is offline   Reply With Quote
Old 11-07-2006, 01:13 PM   #8
blk
blk's Avatar
blk is on a distinguished road
i like the idea and i might get involved too but i think we should spend more time into planning than just rushing into one thing - it may be a dead end.. what i had in mind was an arch-linux as setup which is quite slick, but since i haven't ever used it i can say much about up/down-sides from a practical point of view... i also had gentoo running but didn't really see a big performance improvement (especially when considering the time spent compiling)
i could setup a wiki where we could propose and discuss different aspects/wishes.
what would definately be cool is a modular design where you can choose between different frontends/features/etc. depending on what hardware you might have.. i have a touchscreen,an epia MII-10k and a lot of experience using linux (mainly debian based distros (debian, ubuntu) but also some rpm-based (suse) and gentoo) i am a bit of a programmer but usually i do Perl,PHP or shell-script
as a frontend i'm currently using myth-svn with a working cle266 acceleration. maybe we could also investigate using framebuffers since we wouldn't need an X-server for this (although i don't know about touchscreen support there...with GPM?) what about a reduced-Xserver?
an alternative frontend possibility is the window-manager (WM) based one (there's a about this somewhere here) which i found quite cool too.
boot speed is also a very important aspect and currently i get mythfrontend up in about 20s from POST, im using initng on ubuntu (for testing, i intended to switch to arch-linux once i knew what i wanted)
..someone for a wiki?
[update]
having seed miniMyth: it does sound like a good starting point..but i would keep in sync with them and not completely branch off.. or sync back from time to time (like ubuntu does with debian after nearly every release)
blk is offline   Reply With Quote
Old 11-07-2006, 04:38 PM   #9
licensed to kill
kev000's Avatar
If we can get some good organization here I'm also willing to help out where I can. My c++ skills are at your disposal.
We can plan out the features using launchpads feature blueprint system: https://features.launchpad.net/
Old 11-07-2006, 07:42 PM   #10
monkeyBox's Avatar
Minimyth has built in functionality/scripts for enabling/disabling certain options. Furthermore, with the GAR build system (as I understand) you can enable/disable certain features at build-time. For example, if we wanted to offer a build of the distro that's just intended for use with character LCD's we could do that quite easily.
We would definately want to keep watch on any improvements to minimyth that could improve this distro, but it will still be mostly a branch of minimyth due to the change in general purpose of the distro.
Old 11-07-2006, 07:53 PM   #11
monkeyBox's Avatar
One thing to decide on is a name... Lincar? Carnix? MiniCar?
Old 11-08-2006, 09:43 AM   #12
licensed to kill
kev000's Avatar
I think you should call it monkeybox.
Old 11-09-2006, 08:47 AM   #13
monkeyBox's Avatar
hehe.. It has a ring to it, doesn't it! I just might call it that... I've basically used this nick since I was in high-scool, maybe it was meant to be
Old 11-12-2006, 08:06 PM   #14
licensed to kill
kev000's Avatar
I really think this is a great idea. With microsoft entering the playing field with an automotive specific operating system I think it's only fair that Linux push out some competition for it.
Old 11-13-2006, 10:30 AM   #15
rocken is an unknown quantity at this point
Lets Get'R'Done!
I am up for this, I've toyed with the same idea (that mythtv has kind of solved) , porting a lite mythtv.
Shall we setup a sourceforge site?
I've even got the same hardware, yeh. I agree lets keep the hardware spec'd and really not stray too far off from that, focus on the features.
rocken is offline   Reply With Quote
PT Cruiser 7 touchscreen monitors, high end CarPC Vinister Show off your project 74 10-20-2009 11:43 AM
About to take on a crazy interior overhaul for my custom bmw showcar. Some ?’s & pics BEHMER General Hardware Discussion 35 07-11-2006 07:07 PM
FS: full carPC package(in a bmw e46) CynicalWry Classified Archive 6 10-30-2005 04:14 PM
FS: Custom built desktop pc!!!!! Great for carpc! Badjack10 Classified Archive 22 10-21-2005 01:29 PM
Audi A6 custom install carpc with fingerprint recognition ejdeleon Show off your project 26 07-07-2004 04:25 PM
