Go Back   MP3Car.com > Mp3Car Technical > Linux
Old 02-06-2007, 09:45 PM   #1
spuzzdawg is on a distinguished road
Installing nGhost
I'm having significant difficulties installing nGhost 0.94.4 on opensuse 10.2 x86_64.
I first attempted to install from source following the instructions that came with it, installing all of the dependencies. At first it would not configure but I managed to fix that. Make dies a horribly painful death giving errors left right and center.
I then decided to run the executable from the command line because it gives a more decipherable error message than make. What I don't understand is that the executable was giving errors for libraries or shared somethings that it couldn't find - even though they were installed. Updating the library to the same version that was already installed made the error message go away and I could move on to the next one until i got to "error while loading shared libraries: libSDL_image-1.2.so.0: cannot open shared object file: No such file or directory" reinstalling the package SDL-image did not fix the error - i'm certain that this file is installed however.
I'm at a loss of how to install this. All the dependencies have different names are not quite equivalent under openSUSE so the dependency list is not 100% correct for me. I fixed most things by installing every relevant development package.
Spuzzdawg
spuzzdawg is offline   Reply With Quote
Old 02-06-2007, 11:38 PM   #2
licensed to kill
kev000's Avatar
kev000 will become famous soon enough
You might have already tried this, when compiling make sure you have the dev libraries installed for sdl (libsdl-dev, libsdl-image-dev, libtag-dev, and libsdl-ttf-dev). what versions of SDL to you have installed?
run an ldd and list the output:
Code:
ldd nghost
I'm no expert at suse so maybe someone else can jump in...
*update* I'm downloading opensuse so I'll soon find out exactly how to get it installed...
LinuxICE - because my car already has enough windows (and because I like speed).
LinuxICE2 beta2 is released!!! get it now!
Follow OpenICE development
kev000 is offline   Reply With Quote
Old 02-07-2007, 09:28 AM   #3
I ran the command in the folder containing the precompiled nGhost and got:
linux-gate.so.1 => (0xffffe000)
libtag.so.1 => /usr/lib/libtag.so.1 (0xf7ed7000)
libmysqlclient.so.15 => /usr/lib/libmysqlclient.so.15 (0xf7d96000)
libSDL_image-1.2.so.0 => not found
libSDL_ttf-2.0.so.0 => not found
libSDL-1.2.so.0 => not found
libcrypt.so.1 => /lib/libcrypt.so.1 (0xf7d35000)
libnsl.so.1 => /lib/libnsl.so.1 (0xf7d1f000)
libpng12.so.0 => /usr/lib/libpng12.so.0 (0xf7cfb000)
libaudio.so.2 => not found
libXt.so.6 => /usr/lib/libXt.so.6 (0xf7caa000)
libXext.so.6 => /usr/lib/libXext.so.6 (0xf7c9b000)
librt.so.1 => /lib/librt.so.1 (0xf7c92000)
libz.so.1 => /usr/lib/libz.so.1 (0xf7c7f000)
libdl.so.2 => /lib/libdl.so.2 (0xf7c7b000)
libncurses.so.5 => /lib/libncurses.so.5 (0xf7c34000)
libslang.so.2 => not found
libX11.so.6 => /usr/lib/libX11.so.6 (0xf7b16000)
libpthread.so.0 => /lib/libpthread.so.0 (0xf7afe000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0xf7a1a000)
libm.so.6 => /lib/libm.so.6 (0xf79f4000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xf79e7000)
libc.so.6 => /lib/libc.so.6 (0xf78b9000)
libSM.so.6 => /usr/lib/libSM.so.6 (0xf78af000)
libICE.so.6 => /usr/lib/libICE.so.6 (0xf7896000)
libXau.so.6 => /usr/lib/libXau.so.6 (0xf7892000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0xf788b000)
/lib/ld-linux.so.2 (0xf7f23000)
Searching for a package in Yast the provides the missing libraries above i get:
libSDL_image-1.2.so.0 provided by SDL_image (i have version 1.2.5-24 installed)
libSDL_ttf-2.0.so.0 provided by SDL_ttf (i have version 2.0.8-25 installed)
libSDL-1.2.so.0 provided by SDL and SDL-32bit (i have SDL 1.2.11-22 installed)
libaudio.so.2 provided by libaudio (not installed - going to install version 1.8-0.pm.1)
libslang.so.2 provided by slang and slang-32bit (slang 2.0.5-32 installed)
I attempted to compile again after installing libaudio - no luck. I tried running the precompiled binary after installing available 32bit version - also no luck.
Spuzzdawg
Old 02-08-2007, 12:36 AM   #4
licensed to kill
kev000's Avatar
I would try maybe creating symbolic links for the libraries that you are missing and put them in /usr/lib with the others.
Old 02-11-2007, 08:56 AM   #5
blk
blk's Avatar
blk is on a distinguished road
we shouldn't ship pre-compiled binaries..and if they should statically be linked.
could these problems result from us having both debian systems on our dev-boxes which sometimes have a seperate subfolder for the libs? (mysql/mysql.h instead of mysql.h, same with libtag)
i suggest all people switch to debian-based systems :P
blk is offline   Reply With Quote
Old 02-12-2007, 05:49 PM   #6
licensed to kill
kev000's Avatar
my vision of the perfect world would involve everyone running a debian based system. But you can't expect everyone to be perfect
nGhost Media Center Beta kev000 LinuxICE 62 03-05-2008 12:24 AM
nGhost Media Center Linux Front-end kev000 Other Cool Front Ends 8 05-15-2007 08:45 PM
I need help installing a CD/MP3 deck on my 97 Neon Mic4 Car Audio 15 04-30-2006 01:30 AM
Installing car PC in 1996 Honda Civic PredatorCoder Newbie 8 08-18-2005 08:58 AM
installing video card w/ onboard video hannibal Newbie 9 12-18-2004 01:18 AM
