Go Back   MP3Car.com > Mp3Car Technical > Linux
Old 02-28-2007, 07:08 PM   #1
Too Lazy To Search
Vagabond's Avatar
Myth: install
I am having a hard time with my MYTH 2.0 install. I am running Ubuntu 6.06 on a Via M12000 512 megs.... (should I upgrade to 6.10? i am DL'n it now)
I got the repositories open and installed Myth. but i cant get the shell to work properly or connect to my backend at all when i log in as mythtv user. I've gone thorugh a bunch of tutorials. This is the one i found to be the clearesr so far, but i am having no luck.
http://www.parker1.co.uk/mythtv_ubuntu.php
Is there another options for a easy install frontend. I do intend to us Myth at some point but I have a whole list of other things to work out with Linux also.
Well, I decided to start over rather than go back and fix all the changes I made.
Maybe by installing edgy I will have better luck.
Thats only half true...
Vagabond is offline   Reply With Quote
Old 03-02-2007, 04:18 PM   #2
Try KnoppMyth, particularly if all this computer is going to run is MythTV: http://www.mysettopbox.tv/knoppmyth.html
tom61 is offline   Reply With Quote
Lilliput 619 USB/Driver Problems? Let's research this... (unknown device) akula169 LCD/Display 10 11-20-2006 05:14 PM
Jagputer Install and story log JagPuter Show off your project 19 08-02-2006 08:48 PM
Tinyxp vs nlite vs sensible install geeky_hawkes WinNT Based 5 06-15-2006 03:55 PM
Starting MM trys to install IntelPROset software? sturmovik Map Monkey 1 06-03-2006 02:20 PM
windows xp install Moneyfink WinNT Based 17 03-09-2005 12:05 AM
