Go Back   MP3Car.com > Mp3Car Technical > MacCar
Old 04-03-2007, 07:42 PM   #16
trafnar is an unknown quantity at this point
I posted this in the other thread:
for what its worth, I bought an appletv yesterday and hooked it up to a DVI computer monitor with an HDMI>DVI adapter.
I'm planning on installing it in a car, I too am wondering what LCD will work
trafnar is offline   Reply With Quote
Old 04-04-2007, 04:03 AM   #17
krburrell is an unknown quantity at this point
I'm planning on installing the apple tv in my car and I took a few photos of it hooked up to my navi screen. You can see the rest by clicking on My Photos.
krburrell is offline   Reply With Quote
Old 04-04-2007, 10:59 AM   #18
Omarvelous is an unknown quantity at this point
Wow! what did u use???
I'm a little confused..... ur planning on installing? or did u already?
Omarvelous is offline   Reply With Quote
Old 04-04-2007, 11:05 AM   #19
I just hooked it up to see if it would work and to see how it looked. It's not installed.
I used the Audio Authority 9A65 Component Video to RGB Converter to hook it up to the screen.
Old 04-04-2007, 11:22 AM   #20
Gotcha!
ur the man! looks like $180, which isn't toooo bad.... Wish these things were cheaper!!
The Component to Composite is near $500.
$200 for the HDMI to DVI-I....
What screen is that ur using also?
Old 04-04-2007, 11:27 AM   #21
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Quote: Originally Posted by nickmgray View Post
^ it would be great to have more USB posts on the ATV, but from the sounds of it, to hack it to boot from USB device you also need a keyboard
"Booting from USB requires booting the Apple TV as nromal then holding ‘menu’ and ‘-’ keys on the remote to initiate a restore boot. From there it takes a bit of timing, Turbo explains, “If I hold down menu and - from poweron until the first screen flash, I believe that it does the equivalent of cmd-opt-p-r. I only got it to boot from USB by releasing it at that point, then hitting it again just before the screen flashes on the second reset.”
The way I read that, you hold down those keys on the remote that comes with the AppleTV, not on a keyboard.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 04-04-2007, 11:44 AM   #22
I 2nd that.
For those looking to use AppleTV solely for media purposes in car, just a FYI...
Can get this http://www.alpine-usa.com/US-en/prod...model=KCE-415i
And use with VideoIPod.
Does anyone know of a USB hub that has it's own power input? That could relieve some of the power/usb hub issues.... haven't heard of one.
Old 04-04-2007, 11:54 AM   #23
CarFrontEnd Creator
iamgnat's Avatar
iamgnat is on a distinguished road
Cool. Good to see something that works, how is the resolution on it?
Ouch, that is a hefty price tag though (though it is better than the dvi->ldvs option I tought about)
There are a bunch out there. The trick is that many will still use power off the bus if their external power is disconnected. Mike has a thread about it on the Carnetix forums.
The problems with these "bi-mode" hubs is that A) they continue to drain your battery and B) would still allow devices connected to it to wake your Mini when you don't want it woken up.
-dave
EDIT: Look. If I wanted it to be one post, i'd make it one post....What is up with this "Automerged Doublepost" stuff???
My pathetic worklog.
CarFrontEnd (now it's own sub-forum!!!!)
Last edited by iamgnat; 04-04-2007 at 11:55 AM.. Reason: It's not a double post damnit!!!
iamgnat is offline   Reply With Quote
Old 04-07-2007, 12:20 AM   #24
CArringt is on a distinguished road
WOW... the text looks really hard to read. have you thought about using your nav video input? there's some way to hack it to have a RGB input
CArringt is offline   Reply With Quote
Old 04-07-2007, 11:36 AM   #25
raxy is on a distinguished road
fo those looking for a DVI input TFT, you could try this kit
for HDMI, there is another one
raxy is offline   Reply With Quote
Old 04-07-2007, 12:49 PM   #26
What is this? I can't get it to show english
Old 04-07-2007, 02:09 PM   #27
these are controller boards with hdmi or dvi input (among other inputs).
They do drive the accompanying TFTs as well as many other ones.
These kits could be put to use in a car, they just need regulated 12V power supply.
Resolutions (1024 for the 7", 1280 for the 10.4") are higher than current 7" liliput or hamis
Old 04-07-2007, 02:20 PM   #28
You have to remember that you are taking something that was meant for a wide screen and shrinking it down to a small screen (7" in my case). The text is not hard to read except for the song time and number of songs which are displayed in a very small font size. I think it's more of the quality of my pics. I took them at night in my garge.
I think the nav video input would give a worse picture quality since it is a composite signal. In my nav system that are RGB signals going from the nav ecu to the nav screen. You can hack the RGB input between the two with a 4PDT relay.
Old 04-07-2007, 03:14 PM   #29
From what i've read, the rgb nav hack is the highest resolution that you can get on a screen with out a vga or other type of input. They say it's just as good as vga. You can check t out on the mac prius site
Old 04-07-2007, 03:25 PM   #30
i can't use a screen like this a have to use an in-dash because of the way my hac controls are setup. I still don't really understand what this does. It just converts an hdmi or dvi signal?
Official 7th Gen Civic Thread Maheriano General MP3Car Discussion 28 04-24-2007 06:51 PM
Freeway (CCFR) Official Thread oeri Freeway 586 08-29-2006 11:24 PM
HaveThread tools, etc, at the bottom of thread Rafster Mp3car Forum Suggestions/Comments 3 05-12-2006 08:04 AM
Official requests thread coyote MediaCar 224 11-05-2004 01:09 AM
Official Suck Up to Coyote Thread SjLucky MediaCar 2 11-18-2003 03:21 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
