The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 04-09-2007, 01:54 AM   #31
My Photos: (0)
VGA input TFT compatible with car usage (in term of size) are very rare:
lilliput and hami are the most known.
DVI input or HDMI input small screen (10" or less) are *NON*existent on the market, period.
Except those only two items i've linked to.
As ATV ca do HD, I think using a screen capable of HD is very logical,
do not use an composite input screen please (as most of japanese top brand moniceiver propose)
raxy is offline   Reply With Quote
Sponsored Links
Old 04-21-2007, 09:34 AM   #32
My Photos: (0)
How about this guys....
http://www.x2vga.com/
with
http://www.xenarc.com/product/700y.html
Or any other VGA enabled set?
Omarvelous is offline   Reply With Quote
Old 04-21-2007, 09:38 AM   #33
My Photos: (0)
or this
http://www.play-asia.com/paOS-13-71-...n-70-1d2s.html
Old 04-30-2007, 05:49 PM   #34
My Photos: (0)
I purchased an AppleTv and installed OS X the next day (it took about 8 hours to make a backup image of the hard drive). Anyhow, it was extremely easy to do, with only a few minor annoyances. For example, the ethernet port wasn't working, and it took me about an hour to figure that out. As far as the usb goes, it is flawless with multiple devices plugged in through a belkin 4 port hub (powered). So, with that I've got the bluetooth hooked up (for the mighty mouse) an external hard drive (powered) a jump drive and a keyboard. The boot process is a trifle slow, though not unbearably so. And once the os is up, the computer is fairly quick and responsive. As an aside, the processor turns out to be 1.5Ghz, not 1Ghz. Everything was smooth an easy and I'm typing on my AppleTV right now. At the moment, this is the word processor for my house, but I for one believe this thing is more than adequate for carputer applications and I'll be installing it in my car as soon as I have a replacement.
HOWEVER, it is important to note that there has been no luck with the audio card under full OS X. So, until this issue is resolved by better minds, an appleTV with OS X is entirely useless for media purposes.
RadioC1ash is offline   Reply With Quote
Old 11-04-2007, 10:26 PM   #35
Vehicle: 2003 Ford Expedition
My Photos: (0)
I have installed the AppleTV in my Expedition using a 15″ overhead screen for the kids in the back and a Panasonic head unit with screen for the front. I can use the steering wheel buttons to control the Apple TV using PAC’s universal steering wheel control interface. Works great. I use an inverter and video converter from svideo.com to convert component video to composite video. It is also AC so requires the inverter. I am in the process of adding a smart DC power supply with 12v/9v/5v to get rid of the inverter and to allow the Apple TV to stay on for syncing without draining the battery. The best thing about the Apple TV over the Mini for the car is it doesn’t require any maintenance, it’s auto syncing, and no keyboard or mouse is required. I will add a rear view camera so I can see behind when the 15″ screen is down.
A note to Carnetix. I took the power supply out of the Apple TV and the specs say it is a 5 volt switching power supply. It would be great if they could provide DC-DC 12v to 5V supply that fits inside.
duckjibe is offline   Reply With Quote
Old 11-14-2007, 11:45 PM   #36
My Photos: (0)
Can i not just use it normally
Hey, can I just use the ATV without hacking it. I just want it to be a media storage system. I will hook my GPS up to the other RCA jacks and then just hit the AV button on my LCD. However, i will have the audio coming form the ATV so it will not affect my music I am listening to now right? Or should i just get a mac mini and hook up the gps to that and get somekind of radio app too. I'm really lost here and i need to buy this crap and know exactly what to buy. I just want to get a media server with a radio and gps in my car. I also don't know what the best front-end app is. Can someone help. thanks
Caleb211 is offline   Reply With Quote
Old 12-28-2007, 02:25 PM   #37
My Photos: (0)
If you're still curious, yes, you could just use it without hacking it and it would make a pretty good music server. The simple remote system lends itself well to car audio use. The really neat thing, I think, is that whenever you park the car at your house and you're in range of your wifi, your play-lists and podcasts will automatically be updated. Just use a head unit with an aux input, no problem.
Old 02-10-2008, 02:55 AM   #38
nottastocker's Avatar
Vehicle: 1996 Chevy Corsica -- I miss my RWD
My Photos: (0)
correct me if i'm wrong, but can't you just use a component to vga adapter for the video? its all analog, and i've seen the cables
Mozilla Search Plugin
nottastocker is offline   Reply With Quote
Old 02-22-2008, 09:47 AM   #39
My Photos: (0)
Component cable
You cannot use just a cable to convert component video to VGA. These cables are "for connecting Projectors or other devices that accept Component Video (Y-Pr-Pb) into their VGA connector. This cable does not convert Component Video to RGB, for that you need a Component Video to RGB converter. You also cannot convert RGB/HV to Component Video with a simple cable, you need a converter for this". Hence the need for svideo's component video to composite converter. Someday it won't be needed when car screens go HD.
Old 03-02-2008, 03:47 PM   #40
My Photos: (0)
Would this help you guys out?
Full colour 480i with just 1 yellow composite cable plugged into the green composite connector on the AppleTV.
http://forum.awkwardtv.org/viewtopic...omposite#p3644
ScrotumC is offline   Reply With Quote
Sponsored Links
Old 03-14-2008, 12:41 PM   #41
Vehicle: 95 Suzuki x90
My Photos: (0)
that will still only be composite low res output. If you want to try it without hacking or adapters, plug your composite screen into the green component connector on the ATV for a monochrome picture, and see how readable it is.
I just got one of those cheap component to VGA adapters made for video games. I'll let you all know how well it works.
gadgetjon is offline   Reply With Quote
Old 03-19-2008, 12:53 PM   #42
My Photos: (0)
OK, I tried my cheapo component-vga converter on three different LCD displays and only got it to work well on one of them. I still have to drag this out to the car to try it on my dash display, but I'm not encouraged by my findings. I was only able to get it to display at 480p, but it may be a function of this converter, which is made for video games, not computers. I only paid about $30 for it, so it wouldn't surprise me if a better converter and/or better display did a better job with this.
Sponsored Links
vB code is On
Trackbacks are Off
Official 7th Gen Civic Thread Maheriano General MP3Car Discussion 28 04-24-2007 05:51 PM
Freeway (CCFR) Official Thread oeri Freeway 586 08-29-2006 10:24 PM
HaveThread tools, etc, at the bottom of thread Rafster Suggestions/Comments 3 05-12-2006 07:04 AM
Official requests thread coyote MediaCar 224 11-05-2004 12:09 AM
Official Suck Up to Coyote Thread SjLucky MediaCar 2 11-18-2003 02:21 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
