The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Search this Thread Display Modes
Old 04-26-2007, 01:13 PM   #1
My Photos: (0)
CarMac Process... Needs Guide Lines!
Hi! I've been reading this forum for the past year or so, and decided it is time for me to get into action! So I wanted to create a thread to take pictures of the process and also to ask you the professionals if I come across any questions or uncertainties. Thank you!
This is what I have so far:
iBook G3 600MHz PowerPC / 384MB SDRAM - $150.00
Lilliput EBY701 7" Touchscreen LCD - $190.00
The next thing I need is a *good* and stable DC/DC power adapter for the iBook G3. I've looked around almost everywhere, and this is the only product I've found:
http://www.akumen.com/product/92/
My question is... is that product good? Which DC/DC adapter would you recommand? Or should I go with the DC/AC Inverter, and then simply use my stock AC/DC adatper that comes with the iBook? Or... don't plug it in, when I get back home just take the laptop out and plug it into the wall..?
Thank you!
tomazws is offline   Reply With Quote
Sponsored Links
Old 04-26-2007, 01:32 PM   #2
My Photos: (0)
Have you considered the Carnetix 2140? Not sure if it puts out a high enough voltage - 20 V max I think. But, you're probably going to need power for other things and this is a very nice unit.
timeshifter is offline   Reply With Quote
Old 04-26-2007, 01:38 PM   #3
My Photos: (0)
The iBook requires 24V / 1.875A (45W?). I'm not sure if the Carnetix would be compatible.
If the device requires 24V and 1.875A = 45W,
can i use adapters that output 12V and 3.75A = 45W?
Or that's a big NO NO?
Old 04-26-2007, 01:51 PM   #4
My Photos: (0)
Try posting over at the forums on carnetix.com. I've gotten lots of good help there. Very impressed.
Old 04-26-2007, 03:20 PM   #5
My Photos: (0)
Using a power inverter would be neat, since I'm using a laptop, I don't have to care if the inverter can survive crank or not (please correct me).
I could simply get a Belkin PC Anywhere or whatever brand they have out there?
Old 04-26-2007, 04:49 PM   #6
natedawgg's CarPC Specs
Vehicle: 99/pontiac/transAm
My Photos: (0)
if it were me and i was using a laptop instead of desktop, i would go with the dc/ac converter instead of a dc/dc. it would really save on the install time. then all you would have to do is figure out were to keep it in the car. but that is just me.
natedawgg is offline   Reply With Quote
Old 04-26-2007, 06:14 PM   #7
My Photos: (0)
That means i'll have a DC/AC inverter and an amplifier connected to the car battery right?
Old 04-26-2007, 06:38 PM   #8
My Photos: (0)
yeah but that would be the same setup if you had a dc/dc too. either way you have to suck some power from your battery to keep this thing going. the benifits for dc/dc is that it will control the startup/shutdown sequence, but you have to "hack" into the power supply to do this. dc/ac you control the startup/shutdown but all the hadware is left alone. being that you are using a mac putting to and waking from sleep is easy to do
Old 04-26-2007, 10:43 PM   #9
My Photos: (0)
i would use one of these
http://us.kensington.com/html/6328.html
you will probably have to configure the power options to sleep quickly if there is no power input (running on battery)
blown_mx5 is offline   Reply With Quote
Old 04-27-2007, 12:05 PM   #10
My Photos: (0)
Nice find! I think I'll go with this
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Tank battery & ventilation; run lines carrying high voltage PredatorCoder Power Supplies 3 02-13-2006 02:09 PM
Rookie Guide to CarPC's IntellaWorks Newbie 8 09-21-2005 03:43 PM
"Noob Guide to Mp3car.com" or "Search is your friend" kmcniece Newbie 15 07-28-2005 11:03 AM
Question on guide coats and filling/smoothing Moondog51 Fabrication 4 07-15-2005 12:09 PM
once again the lines on screen faheja LCD/Display 33 08-01-2001 03:44 PM
Sponsored Links
Ad Management by RedTyger
