Yes, I have done this. I am not sure about what you actually want to achieve, so I will stick to your questions:
1. Yes, I did remove the USB header (on the right side of the photo) - no big deal
2. Yes, I did remove the ribbon cable - but *be very careful* as the connector is easy to damage.
3. Yes, I did remove the three screws
If I remember correctly, after you do this, you can remove the top "iPod wheel" (connected using that ribbon cable) and what remains is the PCB on your photograph, with three springs soldered in it. The other end of these springs carries another small board, glued to the rubber ring. If you want to take these two apart, you will need to de-solder the springs, which is quite difficult. I ended up by cutting the springs, because I did not need them.
