The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 05-24-2007, 02:43 AM   #1
My Photos: (0)
mac mini with extra battry
hi guys
i have an idea can i use the extra battry that come with laptobs and u can conect it to the car ?(i mean mac min+battry rechargable+cabel conect to the car)
but the the problom that i am facing that the mac mini his power like usb cable
any idea???????
yamin2000 is offline   Reply With Quote
Sponsored Links
Old 05-24-2007, 01:11 PM   #2
Admin
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
I don't know, can you?
1. What is the voltage of the battery? What voltage does the Mini require?
2. How would you charge the laptop battery?
3. What issues are there that you may have to deal with when connecting a battery inline with a car power supply?
4. Why would you want to do this? What advantage do you gain vs. an alternative arrangement? Would you use a tank circuit or would you power the Mini from the battery itself?
Lay out the alternatives and you'll see some of the issues. Hint: search for information on tank circuits. There's even some information in the FAQ to the FAQs in the FAQ Emporium.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 05-24-2007, 02:24 PM   #3
zapwizard's CarPC Specs
zapwizard's Avatar
Vehicle: 2006 PT Cruiser
My Photos: (0)
It is possible, Google around, a MacMini on battery power has been done before. After all the Mac Min is just a powerbook in a different box.
But you will need some electronics skill to do it, you can't just wire batteries to the input socket and expect it to work very long.
The mini uses around 18 volts at the power input, and a typical lithium battery is around 3 volt. So you need at least 6 lithium batteries of a large enough capacity to keep it running for 'x' amount of time.
Also, laptop batteries, like all lithium batteries has a relatively short number of recharge cyles. Depending on the battery between 1000 to 2000 recharge cycles. Since you are not restricted on charging power or on space, a lead acid battery will last much longer.
zapwizard is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
VW Golf IV - Mac Mini install Fuse314 Worklogs 12 02-24-2008 04:25 PM
Installing Mac Mini in My 05 Alti SER Vitulla Newbie 1 05-23-2007 11:55 PM
Mac Mini questions, possible FAQ metalac MacCar 2 09-11-2006 09:37 AM
Mini Mac 4 Porsche 944 4thChild MacCar 13 06-20-2006 07:57 AM
Help Needed: Mac Mini Carputer dazuck MacCar 15 03-12-2005 10:30 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
