The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 05-24-2007, 02:11 PM   #1
gthing's CarPC Specs
My Photos: (1)
Weird Wake-Up Problem
I have my mini running off of a P1900 Carnetix power supply. I have the button press simulation cable unplugged, so I am manually turning on and off the mini.
Turning off works as expected. I either hit the button or select sleep from the shutdown menu. No problem.
The computer wakes up by itself when I turn the car on. I have checked the power settings and made sure that "restart automatically after a power failure" is not checked.
Shortly after it wakes itself up, it just dies, as in turns off. Then I have to manually restart it.
I have an independently powered (off the 1900) USB hub.
When I plug the power button pusher cable thingy back in, I imagine it's just going to wake up by itself still and the power button press the 1900 does is going to put it right back to sleep.
gthing is offline   Reply With Quote
Sponsored Links
Old 05-24-2007, 02:32 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
Disconnect the hub, see if the problem occurs then.
If not, It could be the voltage fluctuation on the line that wakes up the Mini.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 05-24-2007, 02:58 PM   #3
CarFrontEnd Creator
iamgnat's CarPC Specs
iamgnat's Avatar
Vehicle: 04 Ford Escape
My Photos: (0)
It's your Hub or something attached to it that is causing it to wake up.
As for the "crash". Is it really crashing (check the console and system logs), or is the P1900 killing the power? Since you don't have the power button line connected, if the P1900 is still configured to sleep the Mini it could be getting out of sync and thinking it needs to kill the power when it should be supplying it instead.
-dave
My pathetic worklog.
CarFrontEnd (now it's own sub-forum!!!!)
iamgnat is offline   Reply With Quote
Old 05-25-2007, 01:04 PM   #4
Bugbyte's Avatar
My Photos: (19)
That's kind of what I was thinking, Dave. The P1900 is out of synch with the start/stop cycle of the Mini and on wakeup it's killing the power after the time out.
Sponsored Links
vB code is On
Trackbacks are Off
Night mode causing weird screen problem slffl MediaCar 15 11-21-2007 08:57 AM
Weird software problem Cutrara General MP3Car Discussion 1 11-07-2007 09:11 AM
amp/pc remote wire doesn't work, weird problem... thorolf15 Car Audio 1 04-05-2007 07:29 AM
Weird problem.... Jorge18 LCD/Display 1 02-23-2007 05:58 AM
not enough power? weird problem HELp please :-D xdjxklusivex Power Supplies 3 02-28-2005 04:23 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
