The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 06-09-2007, 08:01 AM   #1
My Photos: (0)
help! no audio in bootcamp
I'm working with a mac mini 1.66 duo
when i used parallels, windows and road runner worked fine, but slow. then i switched to bootcamp and windows cannot detect any audio hardware. I have my speakers plugged into the headphone port on the mac.
should i buy a USB sound-card adapter? is there a driver i need? (i already downloaded a few, intel, realtek, systwhatever)
thanks for the help!
evankuhl is offline   Reply With Quote
Sponsored Links
Old 06-09-2007, 08:06 PM   #2
My Photos: (0)
You should have created a drivers CD as part of the Bootcamp process. You create the CD under Mac OS. After you install and boot Windows you use the driver disk to install drivers for sound, network, etc.
Go to the Device Manager and check to see if your sound card is installed.
There are tons of people using these things under Windows and the sound works just fine.
timeshifter is offline   Reply With Quote
Old 06-17-2007, 02:38 PM   #3
My Photos: (0)
windows never detected the speakers or audio out device
i couldn't figure it out so i just went back to using parallels
Old 06-18-2007, 10:42 PM   #4
Mac Car Moderator
kandyman676's Avatar
Vehicle: 2008 Nissan Altima Sedan 3.5 SL
My Photos: (1)
As timeshifter said, bootcamp prompts you to create a driver disk for Windows. If you forgot to create it, you can recreate it if you re-run bootcamp in MacOSX under Utilities. These same drivers also work for vista.
"If it works this good why F with it?" -KMFDM "Intro"
Strive for ethical wardriving: http://faq.wardrive.net/
My CarCPUs: v1 - 2000 | v2 - 2004
Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
kandyman676 is offline   Reply With Quote
Old 06-19-2007, 11:12 AM   #5
natedawgg's CarPC Specs
Vehicle: 99/pontiac/transAm
My Photos: (0)
you might also want to re-download bootcamp since they just released ver 1.3. this version has more and much better drivers in it. just re-download it, install it and burn another drivers cd, reboot into windows and insert the cd and install! hopefully that should help
natedawgg is offline   Reply With Quote
Old 06-24-2007, 09:56 PM   #6
My Photos: (0)
I'm going to go back to bootcamp tonight and try again. i did do a driver CD but it still didn't work so i never figured out what the problem was
Old 06-25-2007, 09:18 AM   #7
My Photos: (0)
did you download the newest version? if you did and that doesnt work, then what i would do is return the harddrive to one partition and start over reinstalling windows. i had lots of problems on my first bootcamp install and when unistalled it all (returning everything to a single partition) and then reinstalled it, everything worked perfect
Old 06-25-2007, 03:21 PM   #8
My Photos: (0)
i just did, I reinstalled OSX, installed the newest bootcamp, then installed XP.
I still don't have any audio devices. When i go to the control panel>sound I cannot click on anything on the first tab because it says there is no audio device.
I have it plugged into speakers and I have installed the bootcamp drivers (twice). What else can I try? Could it be a corrupted XP version?
Old 06-25-2007, 03:36 PM   #9
My Photos: (0)
WOOT! just figured it out.
I went to Device Manager. The PCI driver had a yellow caution sign. When I double clicked it I just reinstalled the driver and BOOM! all of a sudden hardware started appearing out of thin air and the computer went crazy with balloons telling me that new hardware was installed!
I followed this,
http://discussions.apple.com/thread....21952&tstart=0
which i found via google
I hope that helps if anyone else has problems with Bootcamp installs.
Sponsored Links
vB code is On
Trackbacks are Off
Outputting from car audio head unit to home theater receiver mach5 General MP3Car Discussion 9 05-31-2007 11:20 AM
2005 BMW E46 CarX audio hook-up question? reggs Hardware Development 0 09-24-2005 03:06 PM
CarPC audio problems aal2000 Car Audio 2 09-07-2005 08:40 PM
Carputer integration with HUGE car audio system, help please septicdeath Newbie 19 12-04-2004 05:37 PM
Seperate VGA and S-Video with Audio Fox_Mulder General Hardware Discussion 7 07-01-2004 01:44 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
