The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 07-08-2007, 12:46 PM   #1
Vehicle: Smart Silver Pulse 4/2
My Photos: (0)
Port Mapping....!!!
Right guys....
I'm on a mission, i have an internet connection in my car, and i am looking to do something a bit different, not too sure how it will work, but looking for some advice...!
I am going to run http://www.securityspy.com/ in the car, but i don't understand port mapping...
I am going to set it up on my home network 1st on an iMac...
I run through a BT Home Hub which is connected to an apple extreme and then wireless into the home network. I have got as far as i can do this on the home network between machines, but don't understand the mapping to be able to view over the net...!!!
If i can get this set up at home, then i will run this in the car, so people will be able to view the camera(s) from the car on any mac and see what i see, just a gimmick for some, but it will have 2 cameras, 1 forward facing and 1 into the car itself...
Any help would be appreciated..
CLICK ME
Smart Car due for completion beginning of march....
Log with pictures to go online shortly after.
www.workingcars is offline   Reply With Quote
Sponsored Links
Old 07-09-2007, 04:59 AM   #2
QCar Creator
Jirka Jirout's CarPC Specs
Jirka Jirout's Avatar
Vehicle: 1993 Tatra 613-4Mi Long
My Photos: (0)
The feature you are looking for is also called NAT or address translation. Basically what you need is to tell the router to take incoming connections on its public interface and a certain port and forward it to certain address and port on the internal network.
Jirka Jirout is offline   Reply With Quote
Old 07-09-2007, 09:54 AM   #3
My Photos: (0)
I got that far, but i don't know how to do it... lol
been reading up on it, but i am still a bit confused.
CLICK ME
Old 07-09-2007, 12:42 PM   #4
CarFrontEnd Creator
iamgnat's CarPC Specs
iamgnat's Avatar
Vehicle: 04 Ford Escape
My Photos: (0)
Typically there is a page for it in the Advanced settings for the router. On my SMC, it's a simple form that lets you specify the port as well as the target IP address (I believe some will let you map to a different port too, e.g. port 22 ->192.168.2.100:9999).
-dave
My pathetic worklog.
CarFrontEnd (now it's own sub-forum!!!!)
iamgnat is offline   Reply With Quote
Old 07-09-2007, 06:07 PM   #5
BarryWoods's Avatar
Vehicle: 2005 Honda Element
My Photos: (2)
Who makes your router? IE, (interweb)--->(your cablemodem/dsl modem)-->(your router)--->all the computers on your network. Basically you have to set port 8000 (the default for security spy) to be forwarded to what ever the ip address is on the machine you have it installed on.
Failure is not an option....
It's installed by default on every version of Windows.
BarryWoods is offline   Reply With Quote
Old 07-09-2007, 08:39 PM   #6
Admin
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
Which you can find here....
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 07-10-2007, 06:44 AM   #7
My Photos: (0)
The modem/router is a BT Home Hub (which is disabled for wireless and used as a modem by ethernet to the Apple Extreme router, which IS wireless and has an iMac connected to it and that has the cameras...!
Any machine on the home network can see the cameras using http://192.168.1.274/8000 which is the ip address of the machine they are connected to i assume...
So now i need to work out the rest...
Does that explain it a bit better from my end...?
CLICK ME
Old 07-16-2007, 07:46 PM   #8
KRS_Juan's Avatar
Vehicle: 2004 Infiniti G35 Coupe
My Photos: (20)
In your router, in port mapping/forwarding, tell it to forward all requests on port 8000 to 192.168.1.274.
Now to see the camera's remotely load up http://yourexternalIP:8000
So if your external IP address was 127.0.0.1 it would be http://127.0.0.1:8000
-KRS Juan-
KRS_Juan is offline   Reply With Quote
Old 08-16-2007, 12:25 PM   #9
My Photos: (0)
did you ever get this up and running?
diiirk is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
USB port power dies?! pixelflash General Hardware Discussion 1 10-22-2007 09:26 AM
Opening virtual gps com port. EricE Software & Software Development 1 03-19-2007 12:51 PM
SDK commands over the serial port ???? tolisn Road Runner 4 12-14-2005 12:03 PM
Need help setting port number in the widcomm 4 driver malkalm PhoneControl 4 07-04-2005 04:38 AM
Via Mini-ITX Epia 5000 serial port not working vash General Hardware Discussion 2 08-13-2002 08:48 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
