The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 07-13-2007, 04:14 AM   #1
Fallout's CarPC Specs
My Photos: (0)
Xenarc 700tsv help
ok, so this is my first post... didnt think i would need to ask for help since this place is loaded with info. anyways..
so i tried different settings with display config x and i searched all around the AMP forum also for a setting that will allow AMP to work full screen. When I power up, everything works fine, until i start up AMP and the program isn't full screen. AMP sits on the lower left hand side of the screen. When i run a visual on the music screen, the whole screen fills up. is there a way to configure AMP to fill the screen?
Im using a 1.66 intel core duo mac mini.
Fallout is offline   Reply With Quote
Sponsored Links
Old 07-13-2007, 12:27 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
The proper settings using Display Config X are discussed in this thread.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 07-13-2007, 12:39 PM   #3
My Photos: (0)
roger, i tried all of those settings, but i had to tweak them on my own by figuring exactly how display configx worked. thanks.
guess i was just tired!
Old 01-22-2008, 12:34 PM   #4
Bugbyte's Avatar
My Photos: (19)
I think you have to delete all of the other resolutions. Getting it to 'stick' is discussed at the end of this thread
Sponsored Links
vB code is On
Trackbacks are Off
Xenarc 700TSV Doesn't Fit zzzBrett LCD/Display 7 01-30-2007 02:13 AM
Xenarc 700TSV 7'' touch screen krazymarine Classified Archive 3 09-20-2006 10:55 PM
Pandora w/ Xenarc 700TSV and Barrel Connector froalskiner General Hardware Discussion 7 07-20-2006 02:39 AM
Xenarc 700TSV Resolution blackflux LCD/Display 2 05-18-2005 01:51 PM
FS: Xenarc 700TSV touch UXGA capable cproaudio Classified Archive 16 01-20-2003 06:38 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
