The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 10-16-2007, 12:55 PM   #1
Vehicle: 2005 Civic LX
My Photos: (3)
Mini Fan Control (XP)
I've been checking the mac forums and they don't have a real solution to this problem.
The fan in my mac mini will not run under XP. I installed a fan control thing in OSX that works great in OSX, and will even crank the fan speed up when you restart into XP, but this only works for the first time. If I restart XP again or hibernate of anything, the fan shuts off again.
My mini has been crashing and restarting (I was thinking it was a hardware issue, but I'm not too sure) so I think it could be the lack of fan.
Have any mini users found a REAL solution to this?
CarPC status:
[XXXXXXXXXX] 100% Complete
[XXXXXXXXXX] 100% Installed
[XXXXXXXXXX] 100% Software
CarPC v1.2 is now in effect. Software updates and hardware additions to come.
KryptonianJorel is offline   Reply With Quote
Sponsored Links
Old 10-16-2007, 01:48 PM   #2
zapwizard's CarPC Specs
zapwizard's Avatar
Vehicle: 2006 PT Cruiser
My Photos: (0)
Speedfan is a program that can take control of fans on normal PC motherboards, it may do the same on a Intel Mini.
zapwizard is offline   Reply With Quote
Old 10-16-2007, 04:42 PM   #3
My Photos: (3)
I tried speedfan. Problem is it doesn't work on the mini (at least not mine). It tells me that there are no fans hooked up.
Well, I dont think the crashing is caused by heat since I left it sit for a few hours and cranked up the temp, and its been running fine.
Thanks anyways!
CarPC status:
Old 10-17-2007, 10:32 AM   #4
My Photos: (0)
try this..it works
http://forum.insanelymac.com/index.php?showforum=78
jackkel is offline   Reply With Quote
Old 11-17-2007, 09:22 AM   #5
My Photos: (0)
I don't know... I never had this problem. I've left my Mini running for several days without any issues. You use Boot Camp, I assume? Then shouldn't that CD you had to write when you first set up Windows have some sort of app to control the fan speed? Or maybe your fan's broken? Or perhaps, if you've ever opened your Mini, you unplugged the fan connector (the little wire in the front), and forgot to plug it in again?
hutacars is offline   Reply With Quote
Old 11-21-2007, 10:52 PM   #6
My Photos: (3)
Its a common problem for all macs. There are no drivers that control mac fans in windows, whether it be a mini or a macbook. they only solution people have is loading OSX first, then restarting into XP to keep the fan going.
Its not a problem that is specific to my Mac Mini
CarPC status:
Old 11-25-2007, 03:47 PM   #7
My Photos: (0)
The Mini will look after itself. By default, it will prefer to run hot and quiet vs. cooler and loud. If it gets hot enough to be worried, regardless of whether it's running Windows or MacOS, it will crank up the fan.
It's not necessary to adjust the fan speed; the Mini knows what it's doing.
= Mike
DrZiplok is offline   Reply With Quote
Old 11-25-2007, 04:06 PM   #8
pepsibobby's CarPC Specs
pepsibobby's Avatar
Vehicle: 2006 Saturn Ion2
My Photos: (0)
LOL i like that description. Live in central Cali never had any problems, car gets up past 130 in summer and ran just fine.
Cant code cause I dont know how, but give me the paint bucket and my eraser and have at you!
pepsibobby is offline   Reply With Quote
Old 04-17-2008, 08:36 AM   #9
My Photos: (0)
Thumbs up
well i have come up with a solution...it works but a bit agracultural....bit fiddly but temps are now perfect.
i bypassed the fan controls etc and directly connected the fan to 5 volts, fan runs very quiet and always runs. you need to be adventurous to do this but works great. there is 5 volts and gnd on the ir receiver board(i recommend using a multi meter to find them but they are the outer spots. i disconnected the fan from the riser that conects the hdd and cdrom and soldered the outer wires of the fan cable to those points on the ir assembly. unfortunately the cables are black but cross wiring isnt a major issue, if it dont run just swap them over. when it runs the core temps hover around 36 to 40 temps under speed fan(used to monitor temps)...now the little beasty dont shut down
elbowt is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Using steering wheel controls to control mini mac? brandondente MacCar 7 05-12-2005 09:50 AM
Low profile AMD XP 2500 heat sink (no fan) Arathranar General Hardware Discussion 4 01-08-2005 04:15 PM
Fan control display more mods General Hardware Discussion 7 08-24-2004 10:08 AM
Thermal Control Fan cadence117 General MP3Car Discussion 0 06-16-2004 03:27 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
