The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 11-27-2007, 04:40 AM   #1
My Photos: (2)
Help: MAC Mini - Carnetixs P1900 issues
Hey dudes,
I have finally got my Mac in to the car and are having issues with sleep/standby.
I made the mistake of updating to Leopard as I thought that the realease version of Bootcamp would be best, boy was I wrong. With Tiger and the Beta version of Bootcamp, suspend worked >50% of the time. With Leopard it suspends ok and appears to resume Ok but the monitor does not come back on.
So I switched to VMware Fusion and again it suspends ok but then about 40-60 seconds later the Mac wakes up. If I turn the key back on to power the screen, the Mac is up and running and working perfectly. Then about 60 seconds later it suspends again by itself.
Then it seems to suspend perfectly and will resume when I turn the key on.
The other issue I have is that it suspends but if I leave it for a couple of hours I find it has shutdown.
I am not sure if the issue is Fusion, I am testing it by suspending the Virtual System before I suspend that Mac. But I would have thought that the Mac would automatically suspend all apps before going to sleep.
Really is frustrating
The config is VMware Fusion, XP2 Roadrunner, Destinator 6, Radioshark, GPS Mouse, Logitech Wide angle Webcam setup as reverse camera and Digital FX2 skin.
USB Config....
MAC - Port 1 - GPS Mouse
Port 2 - Touchscreen
Port 3 - RadioShark
Port 4 - Powered USB Hub
Second USB Hub is plugged in to the Powered USB Hub.
Power USB - Port 1 - Webcam
Port 2 - empty
Port 3 - USB Extension Cable. For easy connection of
USB Drive, Memory Stick etc
Port 4 - USB Hub (non powered)
Non Powered USB Hub - Port 1 - Mouse
Port 2 - Keyboard
Port 3-4 Empty.
I am looking to connectg the Radioshark and GPS mouse to the two spare ports on the Powered USB as I have heard of USB's causing Mac's to resume.
The other option is to dump Leopard and go back to Tiger to see if that fixes the issue. Overall I am disappointed with Leopard and would not reccommend any one update at this stage.
Any help would be greatly appreciated.
Cheers.
Firebird2 is offline   Reply With Quote
Sponsored Links
Old 11-27-2007, 08:56 AM   #2
CarFrontEnd Creator
iamgnat's CarPC Specs
iamgnat's Avatar
Vehicle: 04 Ford Escape
My Photos: (0)
If I understand your configuration correctly, that it most likely your issue.
What you describe sounds like after going to sleep the Mac is getting a wake signal from a USB device and assuming that your powered USB hub is powered correctly (e.g. it is tied to the ignition) then the GPS Mouse is your most likely culprit (though the touch screen *could* be too).
As far as coming back a few hours later and finding the Mini off, my first guess would be that it is the same problem. Sometime after it goes to sleep, the GPS mouse is waking it up. Then since your car is not on, the P1900 is cutting power to save your battery.
Pull everything that uses bus power off the Mac itself and make sure that it is powered based off the ignition line. Also check your powered hub as most now a days will use bus power if external power isn't present.
-dave
My pathetic worklog.
CarFrontEnd (now it's own sub-forum!!!!)
iamgnat is offline   Reply With Quote
Old 11-27-2007, 11:28 AM   #3
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
Ditto. The Mini wakes up easily from USB devices. Keyboards, mice, anything that might signal activity when the system is asleep. The symptoms you describe are consistent with accidental wakeup.
Take your USB hub off the Mini and try the car with that configuration. Make sure if you still have a mouse or keyboard hooked to the Mini that you don't touch or move them. See if the problem persists. If it does, do as Dave suggests.
Jirka has a good solution - just put tape over the power lead on the hub to prevent it from pulling power from the Mini.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 12-05-2007, 09:23 PM   #4
Vehicle: Honda Civix LX 2000
My Photos: (0)
I'm running leopard on mac mini with XP installed and a P1900. Everything works great.
You need to search for AutoIT and follow the step by step guide on writing "drivers" for your USB devices to automatically disable before standby and then re-enable upon wakeup. This will prevent your mac mini accidentally being woken up by one of your USB devices (plus it helps conserve your car's battery).
Sinabl is offline   Reply With Quote
Old 12-21-2007, 04:21 AM   #5
My Photos: (2)
Hi Sinbal,
Thanks.
Got AutoIT, where do I find the step by step guide. I have looked everywhere on the site and forum but can not find it.
AVAWONDAFULCRISMAS.
Old 12-21-2007, 08:34 AM   #6
Machinehead's CarPC Specs
Machinehead's Avatar
My Photos: (0)
The only down side to pulling power from the GPS receiver is that it will take longer to get a lock once the internal battery runs down. It's a small inconvenience but if you use your GPS a lot, it may be an issue for you.
The FAQ Emporium; http://www.mp3car.com/vbulletin/faq-...de-devcon.html
Machinehead is offline   Reply With Quote
Old 12-21-2007, 04:18 PM   #7
My Photos: (2)
Thanks Machinehead,
Happy to live with delay in GPS start up. Right now 8 of 10 times I have to wait for the system to boot so would rather have to wait for GPS.
I wish you and your family a fantastic Christmas break and a wonderful 2008.
Cheers
Sponsored Links
vB code is On
Trackbacks are Off
VW Golf IV - Mac Mini install Fuse314 Worklogs 12 02-24-2008 04:25 PM
Mac Mini Apple Remote Issues with WinAmp Gurukarma Road Runner 0 07-02-2007 06:37 PM
Installing Mac Mini in My 05 Alti SER Vitulla Newbie 1 05-23-2007 11:55 PM
Carnetix P1900 Ver. 2.2 w/Mac Mini Core Duo - Startup Problems mrclean12 MacCar 13 09-05-2006 11:44 AM
Mini Mac 4 Porsche 944 4thChild MacCar 13 06-20-2006 07:57 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
