The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 12-04-2007, 03:11 PM   #1
My Photos: (0)
phidget programming?
I have a 4 servomotor controller and need help writing code so that I can use it to left my monitor. Can anyone here help me here.
Paul
tang is offline   Reply With Quote
Sponsored Links
Old 12-04-2007, 10:43 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
Can't you use applescript with phidgets?
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 12-05-2007, 04:54 AM   #3
My Photos: (0)
I have not been able to get it to work.
Used the following code
tell application "Phidget Servo Controller"
activate
delay 2
end tell
tell application "System Events"
tell process "Phidget Servo Controller"
set value of slider 1 of window "Phidget Servo Controller" to 65
end tell
end tell
it will start the phidget servo controller but then I get this error message
System Events got an error: Can’t get slider 1 of window "Phidget Servo Controller" of process "Phidget Servo Controller". Invalid index.
Old 12-05-2007, 07:22 AM   #4
QCar Creator
Jirka Jirout's CarPC Specs
Jirka Jirout's Avatar
Vehicle: 1993 Tatra 613-4Mi Long
My Photos: (0)
What environment and language are you using for the development? Controlling Phidgets from C or ObjC/Cocoa is trivial (except for few issues if you go for multithreading). There are quite a few sample on the disk image the Phidgets driver is distributed on.
Jirka Jirout is offline   Reply With Quote
Old 12-05-2007, 01:33 PM   #5
My Photos: (0)
I looked at there examples. I have xcode install and was going to use that and thought I might be able to play around with it and understand what they are doing. I have limited programming skills. I did some visual basic about 5 years ago and just in a school enviorment then I switch to Macs and don't know the languge here.
Paul
Old 12-05-2007, 10:18 PM   #6
Bugbyte's Avatar
My Photos: (19)
You are trying to script the user interface, which is different than phidgets support applescript. The likely problem is that you either have the name of that slider incorrect, or the application isn't active/the slider is greyed out when you call it.
Did you know that automator in Leopard has a function called 'watch me do' that will record what you do and allow you to examine the script? That might be the easiest way to figure it out for you.
Otherwise, try using Xcode and the examples. It may not be as hard to modify an example as you think.
Old 12-06-2007, 01:19 PM   #7
My Photos: (0)
Well then I don't thing phidget is applescritable then or least it is not listed on there website. I will look at your other options as well.
Thanks for your sugestions
Old 12-07-2007, 08:15 AM   #8
Bugbyte's Avatar
My Photos: (19)
I haven't done too much GUI scripting, but just looking at your code, it looks like you have too many tells in there. Try something simpler like this:
activate
delay 2
end tell
I think the reason it was bombing was that you were telling System events something. Since it didn't bomb when you first told the Phidget Servo controller application to activate, that means you were able to contact the program. I think you can simply continue that and set the value of the slider directly.
Not sure why you need to use the term 'process' rather than application. If the code above bombs, maybe you need to use that instead.
Perhaps you'll have to go back to your original code and write it like this:
end tell
end tell
...but I have a feeling that what is going on is that AS is talking to the System Events app and NOT to Phidget Servo Controller app. I don't think you need to use that tell for System Events.
AS is notoriously finicky about the exact syntax and it isn't always clear how you write the code. It takes some messing around with.
Old 12-07-2007, 03:41 PM   #9
My Photos: (0)
Thanks I will keep playing around with as i would like to learn applescript. I will be looking for a good book on the matter. Non of the suggestions worked (appreciated anyway). Yes I tried the record with automater but when came to the slide it did not actually move them, It selected the one and stopped short of moving.
I will keep working with my options
Paul
Old 12-07-2007, 06:27 PM   #10
Bugbyte's Avatar
My Photos: (19)
Well....if it selected the right one, then use that code and then insert the AS code that actually sets the slider to the value you want.
This is THE book for applescript. You can go a really long ways with it.
Here's a good start on how to GUI script.
Also, you need UI Element inspector to allow you to tell what the name of the control is. It's here.
Sponsored Links
vB code is On
Trackbacks are Off
Phidget Encoder Plug-in Doesn't Stay Enabled - 1.0.6.3+ BlueF StreetDeck Bug Reports 2 08-06-2007 09:41 PM
A successful noob's advice on programming PIC microcontrollers gadgetlust Newbie 0 07-03-2007 01:04 PM
EMS programming questions 94legend Engine Management, OBD-II, Engine Diagnostics, etc. 0 05-27-2007 12:13 PM
Wanting to learn some programming, help me pick a language! RS3RS Software & Software Development 32 10-15-2004 04:38 PM
C++: GUI Programming with >NET Framework [iG] Software & Software Development 3 05-24-2004 06:57 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
