The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 12-12-2007, 10:17 PM   #1
My Photos: (7)
Mac front end controlling elec servos and all temp controls?
I was thinking today, I'd like to try and build a Mac carputer that does the following:
1. Runs software to tune my MegaSquirt EFI system (5.0 TT Thunderbird)
2. Handles all entertainment
3. GPS with voice activation (i tell it what to do) and turn-by-turn guidance
4. Edge internet VIA bluetooth
5. Bluetooth phone with in dash address book/control and perhaps steering wheel button control
6. Complete touch screen control of temperature control system using electric servos to remotely control my rotary heater controls (which would be hidden in the dash). This would require software that can be programed to know when a given servo is at max cool, 75% toward heat, on a/c, max a/c, vent, or any other position on the three rotary knobs. Also, I'd want it to be all contained in one software (besides the megasquirt tuning) much like a lexus would be (no fumbling around with one program for heat, one for gpw, etc...)
I'm guessing it's a pipe dream (espeically since I can't program it myself) but does anyone have any input on this. I'm totally in for developing the mechanical portions if it'd hep others... I just want a totally integrated solution...on a MAC!
PS. the plan is to have a 7 inch touch screen, a track pad and button on the center console and a stowaway keyboard...
booksix is offline   Reply With Quote
Sponsored Links
Old 12-13-2007, 03:51 AM   #2
QCar Creator
Jirka Jirout's CarPC Specs
Jirka Jirout's Avatar
Vehicle: 1993 Tatra 613-4Mi Long
My Photos: (0)
No big deal. Whatever QuickTime can play you get for free. If you want more, MPlayer and VLC are both Open Source so you can use the code to implement what you want. The only bigger issue for entertainment is a bit weird support for multi-channel sound.
Unless you have a very quiet car, voice activation is going to be a problem. We have it for a few things in QCar, but it is not really usable as a primary input/control method. As for navigation, at the moment, the only solution you can buy is Routebuddy. We do have navigation for QCar, but we need to sort our business issues with TeleAtlas before we can offer it.
Again, no big deal, just some legwork if you want it "clean" i. e. without annoying system error/aler dialog windows etc.
No problem - a phone can be controlled using standard AT commands, steering wheel buttons are usually easy to handle using Phidgets interace boards. If you want talk-thru (using your Mac's microphone and speaker for phone), BluePhone Elite does that rather well.
Again - doable with Phidgets or similar interface board. I would personally not connect the servo to the original rotary controls, but directly to the elements they are supposed to move, but that's a detail.
It is not a pipe dream, almost everything you describe can be done - most of it rather easily.
Jirka Jirout is offline   Reply With Quote
Old 12-13-2007, 05:10 AM   #3
My Photos: (7)
Well, right... I would bypass the knob all together when possible. But as far as at least one knob goes, it is an electrical switch that also handles vacuum routing so having the servo act on this knob itself may be ideal. Where is the best place I can read up on outboard gear and programming for something like this? Also, who makes software to operate a climate control system like this?
And the other thing that you didn't touch on was integration of the whole package. My main hope was that I could integrate DVD's, mp3's, GPS, phone, and climate control into one program where each function was accessed in a different page (just like you'd switch between radio, dvd, gps, etc... by hitting a button within an eclipse nav unit for example). I don't really want to be switching between several actual programs to access everything...
Anyway, thanks for your response. It was a huge help already!
Old 12-13-2007, 08:09 AM   #4
CarFrontEnd Creator
iamgnat's CarPC Specs
iamgnat's Avatar
Vehicle: 04 Ford Escape
My Photos: (0)
Ahh. Ford controls. They suck
I'm actually seriously considering starting this process myself, but it will be awhile before I have anything to show for it. The vent/ac selector is the biggest pain. BTW, if your T-Bird is anything like my Escape getting to the actual hardware that adjusts your temp is a PITA. You'll be better off working with the cables.
As far as software, for the Mac it doesn't exist. It will have to be custom.
Both QCar (Jirka) and CarFrontEnd (me) do some of what you want (QCar more than CFE right now) and both are built with adding new features in mind. If you have the ability it's relatively simple to build a new plugin for either interface to add new features.
-dave
My pathetic worklog.
CarFrontEnd (now it's own sub-forum!!!!)
iamgnat is offline   Reply With Quote
Old 12-13-2007, 08:44 AM   #5
CarFrontEnd Creator
iamgnat's Avatar
My Photos: (0)
Sorry, forgot to reply to this part.
I would suggest taking a look at (probably in simplest to hardest):
Phidgets - Simple-ish to program, has a selection of pre-built parts, and has an OSX library ready to integrate into your App.
Arduino - Simple-ish to program (based off Wiring), has a selection of pre-built parts, has a few board options, uses basic Serial I/O for communication which makes it easy to use with any language.
Wiring.org - An open source project that Arduino is based off of, uses the Atmel ATMega128 rather than the smaller chip that Arduino favors (more ports, more memory, etc..), has an additional serial port (compared to the Arduino), can do everything the Arduino can plus a bit more.
AVRFreaks - A great forum if you want to get down and dirty and build/write it all from scratch. Also might be useful when working with Wiring.org based boards since they are based off the Atmel ATmega chips.
-dave
Old 12-13-2007, 01:36 PM   #6
My Photos: (7)
Could you explain this a bit more?
As for programming, I know nothing about it but I'm sure I could learn... I usually teach myself this stuff anyway. Problem is I can't design the art for the user interface...?
Also, besides the climate control, do either QCar or CFE integrate everything else I listed?
Old 12-13-2007, 01:41 PM   #7
My Photos: (7)
Another thing is... the only cable I have on the system is for temp and connects directly to the airbox. No reason to keep it as I could easily mount a servo right on the airbox.. this is actually the easiest part of the climate control system...
Old 12-13-2007, 02:37 PM   #8
CarFrontEnd Creator
iamgnat's Avatar
My Photos: (0)
If your T-Bird is like my Escape, then the temp is done by mixing cold and hot air and the cables move the door that controls how much of each type of air is getting into the system. The housing of that unit is buried up in the dash where you can't (at least in the Escape) see it without first removing the dash. That is not an undertaking i'm up for (and I ripped out the rest of the interior to lay sound deadening mat down...).
The simple answer is to have a motor drive the existing cable system, but it will need to have some decent torque to it.
That is where an interface like QCar or CFE will help. You will need to only focus on the parts you care about rather than the whole app and Interface Builder helps a lot too. The rule of thumb to go by for an in car interface is that if it requires attention to use, it will likely contribute to your user killing themselves
Before trying to do anything fancy, I would suggest that you play with writing a few standalone apps (not related to the car at all) to get used to XCode, IB, Cocoa, etc.. rather than jumping right it and really confusing yourself
I haven't looked at QCar's feature list in awhile, but CFE only has a music player right. I mentioned them both as they both offer a robust interface to extend them if there are features that you think they are missing (e.g. if you ask me, Nav and Video playback is NOT "missing" from CFE ). Some things are of course easier to implement than others though.
-dave
Old 12-13-2007, 04:38 PM   #9
h3rk's CarPC Specs
Vehicle: 2006 Nissan Altima
My Photos: (0)
There is a vacuum manifold that can easily be used to individually send vacuum to 5 different vacuum actuators. It's a delco part, I've got it shown on my Automatic Climate Control thread in the fusion brain forum. each solenoid is powered by +12v with a common out.
There are servos that will do the job for the heat door, take a look at the box, where the heat door swivels and see if there's room for a servo. The servo's should have potentiometer position feedback, or be stepper motors that can be tracked by pulse counting. You just have to be sure you have room for one.
There's a lot you would be bypassing by controlling the actuators directly and reading the inputs directly. This is most true with automatic HVAC control in mind.
I'm not a Mac guy, so I'm not much help, I know. But I am developing software for PC to do that (slowly, as I'm a beginner), and using the Fusion Brain's very diverse and robust skinning language to allow the same through their software (which will likely be done much sooner).
There is a lot of the mech engineering/process control to be included. I'd say I'm about 60% on it.
Temperature blend door and fan control are much harder than mode control, imho.
h3rk is offline   Reply With Quote
Old 12-13-2007, 09:01 PM   #10
My Photos: (7)
All I have to do to access the temp blend door is pull my glovebox out and yes, there's plenty of room for a motor. I've been wanting it for a long time so I know this already. Would a simple RC type servo work? Or what servo's would be the type listed? What's the difference?
And what would I be bypassing? Maybe I'm missing something in there with my thinking...
Sponsored Links
Old 12-13-2007, 09:18 PM   #11
h3rk's CarPC Specs
My Photos: (0)
Well, a DC stepper motor would work. The important thing is to ensure that the software stays informed or otherwise accurately knows the current position of the temperature door. Most automotive manufacturers use servos fitted with potentiometer position feedback for this purpose. You will find that analog output or PWM output is not very readily available for computer IO devices. There is one upcoming option that I know of. Many automotive HVAC servos use discrete levels of voltage to drive the servo in a given direction or hold the servo stationary. The servo I'm using requires 5v to open, 2.5v to hold and 0v to close. That's a bit easier to control than analog or stepper.
As far as bypassing... are you looking to have your system maintain a user selected temperature, and behave something like a factory automatic HVAC system?
Old 12-14-2007, 03:02 AM   #12
ClaZ's CarPC Specs
ClaZ's Avatar
Vehicle: 98 Audi A6 Avant Quattro 2.8 V6
My Photos: (0)
-dave
Any motor used in a automatic climation system have the right torque.
If you see on eBay in Motor section, you find easily this part. The price is very low (60 euro a new part in Audi Enviroment) 10-20 euro as used part.
This motor is a 12V coil and a 5 or 10Kohm for the potenziometer as feedback in 5 total independent wire. With some little electronic you can interface this motor to the Phidget.
Normally the total run of this actuator is a rotation of the arm of 90°...
The total current at the end of the run (and under full torque) is 200 mA....
ClaZ is offline   Reply With Quote
Old 12-14-2007, 08:24 AM   #13
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
Yes, a regular RC servo will work. You can get 90 degrees out of them. As far as how much torque you need from the servo, move the actuator with your hand. If it is reasonably easy to move, a standard servo will work. If you want to be sure, buy a high torque servo. Prices range from $20-$60 for a servo. Here's a link
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
