The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 01-15-2008, 02:27 AM   #1
My Photos: (0)
Suspend problem MacMini
Hi,
My config is:
MacMini with windowsXP OS and Centrafuse Frontend, Carnetix P1900 power supply (with mac cable connected to motherboard) and a Liliput 7" touchscreen.
If I turn the ignition of, the carputer stays on for a while but does not go to standby mode. It turns of hard after a few minutes. So somehow it needs a signal to go into standby or better hybernate mode.
Preferably the computer stays on for 5 mins when ignition is turned of and then goes to standby. After an hour or so it should turn to hybernate.
But really anything BUT a hard shutdown would be nice. It must be bad for the Mac and HD and it has to start with disc verification every time. This lasts a couple of minutes. I hate that.
Does anybody have a solution... or actually has it working? What are the hardware and software settings? Thanks.
kingkitesurf is offline   Reply With Quote
Sponsored Links
Old 01-15-2008, 07:19 AM   #2
Machinehead's CarPC Specs
Machinehead's Avatar
My Photos: (0)
The first thing I would check is the power management settings. Under the Control Panel, Power Options, the Advanced tab. There's pull down menu under the heading "When I press the power button on my computer". Set that to Stand by and then hit OK.
The other thing you need to look at is the jumper settings on the P1900. Double check that you have it set right for suspend mode. It's JP1 pins 5-6, and they need to be jumpered for suspend mode.
That should do it.
Machinehead is offline   Reply With Quote
Old 01-15-2008, 04:11 PM   #3
onepuff's CarPC Specs
onepuff's Avatar
My Photos: (0)
do a search for deep sleep. there is a great widget to make osx hibernate.
onepuff is offline   Reply With Quote
Old 01-15-2008, 04:56 PM   #4
My Photos: (0)
Deep Sleep comes up very slow with Parallels or VMWare Fusion. Slower than WinXP hibernate in my experience.
Old 01-15-2008, 10:38 PM   #5
onepuff's Avatar
My Photos: (0)
Still its better than a hard shutdown and startup
Sponsored Links
vB code is On
Trackbacks are Off
Problem with directshow filter and WMP EricE Software & Software Development 0 03-01-2006 10:38 AM
Car Idle - power/amp problem? TheFaze Car Audio 1 12-15-2005 11:10 PM
had an all day (9 hr) problem at work.... wizardPC Off Topic 13 10-20-2005 11:50 AM
Overscan/Underscan when coming out of suspend mode Dan Marsh Power Supplies 0 06-19-2004 12:28 AM
suspend to ram...winamp skips Franko Software & Software Development 4 08-24-2001 02:43 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
