The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 01-21-2008, 01:53 PM   #1
My Photos: (0)
Mac Mini not saving display settings
I'm hooking up my Mac Mini to a television in my house to do some testing, but I can't get it to save the display settings on reboot. I can't even tell what it's defaulting to because as soon as I boot it up the screen flickers and bounces all over the place. I've been somehow managing to hit the display icon on the menu bar and stumble upon resolutions that work. But once I do a reboot or shutdown the computer ignores the change I made.
Is this an issue with Panther? I just installed DisplayConfigX and I'm thinking if maybe I only install one resolution that works that maybe it will be forced to load that one. But in the meantime any ideas? I'm fairly newb to Macs so hopefully it is just something I'm not doing correctly.
I also can't seem to find a place where you select what type of monitor your using. I know this was easy enough to do in Windows, but does this option exist on Panther?
Thanks!
ladams02 is offline   Reply With Quote
Sponsored Links
Old 01-21-2008, 05:15 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
I'm confused. What kind of TV are you hooking it up to? Are you using some kind scan converter or does your television have DVI or VGA input? What type of signal are you trying to use to view on the television -video, S-Video, VGA, DVI, or some other type of signal?
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 01-21-2008, 09:22 PM   #3
My Photos: (0)
Wow, didn't give much details did I? Oops..
I'm hooking up the mini to a standard television using the Apple DVI -> S-Video converter. It's odd because the first time I hooked it up it was working fine, but I went in and started choosing different resolutions and refresh rates and then all the sudden every reboot would result in a fuzzy, flickering screen.
So very strategically I was able to find my way to the display properties and select different resolutions and get the screen back to normal. It seemed to like 640x480 @ 60Mhz refresh and a few other random resolutions of 480 vertical. But once I got one that looked good, I'd shutdown or restart and then it would revert back to the bad setting. Even a Log Off User X would lose the setting.
I tried using DisplayConfigX, but even when I installed the few resolutions that I know worked, it would still list like 15 other ones that were bad and bootup with one of those.
Sponsored Links
vB code is On
Trackbacks are Off
Newbie Set on Mac Install The_Blade MacCar 5 06-12-2008 02:16 AM
Holux GPS Trouble mangus580 StreetDeck 34 11-26-2007 08:56 PM
Overheating your Mac Mini - No problem! Bugbyte MacCar 14 12-08-2006 09:46 PM
P1900 alternative power supply for Mac Mini johnsin MacCar 25 12-07-2006 09:05 AM
Mac Mini in a Mazda Protege zapwizard Show off your project 18 08-07-2006 08:18 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
