The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 01-31-2008, 03:08 AM   #1
kshin86's CarPC Specs
kshin86's Avatar
Vehicle: 1986 Toyota Corolla GT-S
My Photos: (0)
Mac Mini: connect antenna to internal airport card?
I just opened my Intel 1.66Ghz Mac Mini and I'm trying to figure out what kind of connector I can use to hook the internal airport extreme card to an external antenna.
There is a product on www.macwireless.com that has images of the connector and it looks like an mcx or mmcx male.
http://www.macwireless.com/downloads...e/Ant_Mini.pdf
I'm not sure if the pictures are for an intel mac mini or not. Can anyone confirm what type of connector is in the Intel Mac Minis?
kshin86 is offline   Reply With Quote
Sponsored Links
Old 01-31-2008, 02:19 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
Couldn't tell you. All of the web pics I see don't show enough detail.
Have you had trouble with the range? I've found it to be quite sensitive even with it buried in the dash.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 02-04-2008, 01:28 PM   #3
kshin86's Avatar
My Photos: (0)
Just trying to do some planning as I bought the rooftop antenna from mp3car.com
I'll try and open it up to post a pic. So far someone's told me it's an IPEX connector.
The rooftop GPS uses an FME Female connector.
Old 02-08-2008, 02:06 AM   #4
kshin86's Avatar
My Photos: (0)
Here is a detailed pic of the inside of my Intel 1.66Ghz Mac Mini.
The big silver card is the airport card. At the top right of the card is a screw and right below it is what I believe is an IPEX or u.fl connector. It seems that IPEX, u.fl, etc are different names for the same connector.
If you look closely there is a loose cable with a gold end just above close to where I disconnected the wireless antenna from. If you tilt your head to the right, you can see just beside it the female connector is labeled "MAIN". If you notice just below it there is also another female connector that looks exactly the same and is labeled "AUX".
There was nothing connected to the AUX so I'm assuming I could attatch 2 antennas to this thing? I'm going to test this out. I'm going to head to my local electronics store to get some kind of IPEX female to FME male to attatch to my sharkfin antenna i got from the mp3car store.
what do you think?
Old 02-08-2008, 07:55 AM   #5
Bugbyte's Avatar
My Photos: (19)
Logically, you would think that AUX would mean an AUX antenna :-P
It certainly won't hurt anything to try it out. Do you have any way of measuring the difference with/without the antenna or with just the shark fin antenna alone?
Old 02-08-2008, 09:04 AM   #6
ptk
ptk's CarPC Specs
Vehicle: 2006/VW/GTi
My Photos: (0)
It will work fine connecting to only one external antenna.
I use senao 56G which is essentially a mini-PCI atheros chipset. I hooked it up with external roof top antenna (the one sold here at mp3car.com). You need to custom make the IPEX - FME male connection.
or you can do what i do, I run the IPEX out with IPEX-SMA (to standardised with the rest of the connections), then run a SMA - FME.
I find that for UTMS (cellular broadband) even without antenna you can make connection. For WLAN, you probably can't detect anything beyond your car. As for GPs, goes without saying that without antennae you can't see anything).
CarPC Ver 3 near completion.
ptk is offline   Reply With Quote
Old 02-11-2008, 11:35 AM   #7
kshin86's Avatar
My Photos: (0)
I guess I'll have to try both of them out! I'm going to be using iStumbler (http://www.istumbler.net/) to check signal strength.
Sorry for the late reply, I still haven't gotten the connectors sorted out yet. I have found a local electronics store that stocks them though.
Old 02-11-2008, 11:41 AM   #8
kshin86's Avatar
My Photos: (0)
I think I'm just going to make an IPEX - FME for the airport card and a MMCX - FME for the GPS. Nothing hooked up to the GSM antenna.
Although, I do have a question ptk. Total shot in the dark and I thought I'd give it a try. Can I use the GSM antenna to connec to the AM/FM connection on my car stereo? will this create any problems for me? I want to delete this ugly old school antenna off my fender because the hole is creating rust.
Here's the car! 1986 Corollla GT-S
Old 02-11-2008, 09:40 PM   #9
My Photos: (0)
kshin86, you are correct. U.fl and ipex are the same thing. There was another post on the boards where a guy was trying to find a U.FL to FME pigail for the sharkfin antenna from the MP3car store. He wound up getting a U.FL to SMA female pigtail and an SMA male to FME male adapter.
As for making the adapters yourself, let us know what you come up with. I've never successfully made a pigtail like that, but you may have more luck than me. If it doesn't work, I'm sure you could find a local shop to make the pigtail. Let us know how it goes.
justin_watts is offline   Reply With Quote
Old 02-19-2008, 07:15 PM   #10
mr2mac's Avatar
Vehicle: Toyota MR2
My Photos: (0)
I found this while surfing:
http://www.hfield.com/wifire.htm
mr2mac is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
A Great Idea for the Mac Mini In the car ametalix MacCar 2 07-13-2007 12:11 AM
For Sale: Intel Mac Mini w/ CNX-P1900 (MacPac), pre-wired, PowerMate, and much more! timothyadam Classified Archive 0 02-08-2007 07:47 PM
Mac Mini in a Mazda Protege zapwizard Show off your project 18 08-07-2006 08:18 AM
mac mini core solo enough for bootcamp? replicant MacCar 6 06-26-2006 11:49 PM
FS: Mac Mini CarPC Package/Parts LOADED! markcc01 Classified Archive 1 01-03-2006 10:47 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
