The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 02-15-2008, 08:33 AM   #1
My Photos: (0)
Having a shut down problem...
Ok so i posted this up at carnetix.com and so far no one has replied. So i hope someone here can give me idea as to what to do next.
OK so i have everything working correctly except that after i turn the car off and the mac mini goes into sleep mode, about 20 seconds later everything loses power, so i ran the PSUmoni and i realized that the volts stay between 12 and 13 but out of nowhere the amps on the battery drop and when they get to 0 thats when everything turns off. so what do i do about this? thanks in advace for the help.
nnomaeeht is offline   Reply With Quote
Sponsored Links
Old 02-15-2008, 09:04 AM   #2
NeonDev's Avatar
Vehicle: 2005 Saturn Ion
My Photos: (0)
I think we may need more details to help you... what exactly are you using to power your mini? and has it always had this problem or is it new? also you may have more luck posting in the hardware forum as this may not have anything at all to do with it being a mini.
check us out at: www.neonboombox.com
NeonDev is offline   Reply With Quote
Old 02-15-2008, 10:23 AM   #3
My Photos: (0)
yea sorry about that. I have the p2140 from carnetixs and thats what my mac mini and screen run off of. I post here because maybe other mac mini guys have had the problem. The car is a wrx and I'm running osx10.5 i habe also posted this in the hardware sectoon to see what the say and yes I have always had this problem
Old 02-15-2008, 10:39 AM   #4
CarFrontEnd Creator
iamgnat's CarPC Specs
iamgnat's Avatar
Vehicle: 04 Ford Escape
My Photos: (0)
How is it all wired up?
Have you verified all the jumpers and software settings of the P2140 are correct for how you intend to use it?
-dave
My pathetic worklog.
CarFrontEnd (now it's own sub-forum!!!!)
iamgnat is offline   Reply With Quote
Old 02-15-2008, 11:33 AM   #5
My Photos: (0)
yes I have and nothing was set up wrong
Old 02-15-2008, 11:47 AM   #6
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
Does this also happen when you run it in the house?
It sounds to me like you have it configured incorrectly. It's cutting the power after 20 seconds. So....it's KEEPING the power on for 20 seconds after you turn the car off.
I'm not as familiar with the 2140, but many PSU's can be configured to cut all power off after an interval, like a minute, so that the system has a chance to go into hibernation.
For sleep, the system continues to supply power but signals the computer to sleep. That gives me a different thought....does the 2140 cut off power to a sleeping computer if it draws too much power?
If so, are you drawing too much power through the USB port? What is connected to it?
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 02-15-2008, 11:50 AM   #7
NeonDev's Avatar
My Photos: (0)
one other thought is why not simply set the mini to hibernate instead of sleep? i know it takes a bit longer to wake up but it is far less time than booting fresh, and it wouldn't matter if the power was cuz after 20 seconds provided that the mini takes less than 20 seconds to dump ram to disk
Old 02-15-2008, 11:46 PM   #8
My Photos: (0)
I'll see about hibernating, but the point of getting the p2140 was so i could put it to sleep and its only connected to the screen through usb thta the onlything connected. this dosnt hanppen in the house.. thanks for the help so far.
Old 02-16-2008, 12:49 PM   #9
NeonDev's Avatar
My Photos: (0)
there ya go
also read this note from the very first link on google
Quote:
NOTE: *The CNX-P2140 is designed to operate with a “nominal” +12VDC or +24V input from a car battery or alternator. This input voltage can vary significantly from a low of +7.5VDC during engine cranking at cold temperatures, to +34VDC during jump starting or abnormal alternator “spikes”. The CNX-P2140 can operate under full load with an input voltage of less than +10.5VDC for the duration of engine cranking. It is NOT designed to take a continuous input voltage of less than +12VDC for an extended period of time while under heavy load. If the input voltage drops below the nominal low battery threshold (~+10.5VDC) for more than 10 seconds, the CNX-P2140 shutdown controller will go into “Forced Shutdown” mode which will turn off the CarPC after a 30 second delay. Since the user has control over low battery threshold, care must be taken to protect the P2140 from prolonged operation below +10.5V.
Sponsored Links
vB code is On
Trackbacks are Off
pc using a lot of power when shut down Dj-[NRG] Power Supplies 6 08-04-2007 03:50 PM
Not your typical flicker problem JPuma LCD/Display 17 05-30-2007 09:28 AM
Xenarc Problem or Polarity Problem? mbkowns LCD/Display 1 01-06-2007 08:57 PM
Shut down/Start up problem campusmischief Power Supplies 4 08-11-2005 10:54 PM
YAOP (yet another Opus problem) Frankino Power Supplies 14 06-19-2005 11:17 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
