The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 03-15-2008, 07:01 PM   #1
Vehicle: 1997/Lincoln/TownCar
My Photos: (0)
Mac Mini Sound Card Opinions?
Hey I just hooked up a mac mini and a Lilliput 7" 619 in my car last night. I got a JL Audio 450/4 amp and have 2 12"'s on the way. Want to see what you guys thought would be the ideal software or sound card (internal/external?) to pump out best sound. Thanks.
BennyBenz is offline   Reply With Quote
Sponsored Links
Old 03-15-2008, 09:28 PM   #2
Area3's Avatar
Vehicle: 2005 Pontiac Grand Am
My Photos: (0)
What Front End Will You be Using?
I am planning a Mac Mini Install In My Car and This is the Sound Card I am Going With...
2 x 8 24-bit/96kHz analog I/O; 192kHz stereo out
2 mic/line ins w/ preamps and phantom power
8 line outs to mixer or direct surround output
S/PDIF digital I/O w/ PCM, AC-3, and DTS support
1 x 1 MIDI I/O
includes Ableton Live Lite music production software, so you can make music right away
http://www.m-audio.com/products/en_u...e410-main.html
Any More Questions Just Ask!
Microsoft Is a Evil Empire that has corrupted a generation!
Thanks - Eric Scott
Area 3 Productions
www.myspace.com/area3
Area3 is offline   Reply With Quote
Old 03-17-2008, 07:06 AM   #3
Machinehead's CarPC Specs
Machinehead's Avatar
My Photos: (0)
Ahhhh, the M-Audio firewire 410, she is lovely isn't she?
Machinehead is offline   Reply With Quote
Old 04-01-2008, 05:47 PM   #4
My Photos: (0)
ive had a mini in my car for a year now and im not convinced im using my speakers and sub to their potential. ive got 2 rear and 2 front JBLs and a JBL sub connected to a 6 channel JL amp. the amp connects to the mini through the headphone jack. will the 410 help get a better sound to the amp? sell me on it
lumansa is offline   Reply With Quote
Old 04-02-2008, 08:09 AM   #5
My Photos: (0)
Well, the Firewire 410 is ASIO plug-in compliant, so you can use software to do tuning. From 31 band eqs on every channel to phase control to time alignment to crossovers.
A little more on ASIO:
ASIO: (Audio Stream Input Output) is a protocol for low-latency digital audio specified by Steinberg.
ASIO provides an interface between an application and the sound card. Whereas Microsoft's DirectSound is typically for stereo input and output for consumers, ASIO provides for the needs of musicians and sound engineers. ASIO offers a relatively simple way of accessing multiple audio inputs and outputs independently. It also provides for the synchronization of input with output in a way that is not possible with DirectSound, allowing recording studios to process their audio via software on the computer instead of using thousands of dollars worth of separate equipment. Its main strength relies in its method of bypassing the inherently high latency of operating system audio mixing kernels, allowing direct, high speed communication with audio hardware.
Old 04-02-2008, 09:52 AM   #6
Area3's Avatar
My Photos: (0)
Shes Ok Nothing Like my SSL at Work
But yes You can use this for Tuning and Stuff!
Thanks - Eric Scott
Area 3 Productions
Old 04-10-2008, 04:35 PM   #7
My Photos: (0)
I went low tech. At first I ran the headphone out directly to the amp, but couldn't get the quality of volume control I needed. Eventually, I re-installed my CD player (Apline CDA-9856 w/ external input and 3 sets of pre-amp outputs). Works excellent now, and even allows friends to plug in their iPod via the Alpine AiNet iPod cable.
if you have space for a head unit, go that route, just make sure it has external inputs in the back. I drive an xB so dash space is not an issue.
blackbox1 is offline   Reply With Quote
Old 06-26-2008, 01:47 AM   #8
samantech's CarPC Specs
samantech's Avatar
Vehicle: 2000/pajero/v6 3500
My Photos: (1)
There are some decent sound cards out there and some are expensive.
Duet
http://www.apogeedigital.com/product...?section=specs
Audio Kontrol 1
http://www.native-instruments.com/in...=audiokontrol1
Though I have not tested them in car environment to withstand elements.
Samantec
at aim dot kom
Pajero/Montero 3500
samantech is offline   Reply With Quote
Old 06-26-2008, 06:32 PM   #9
Vehicle: 2004 Audi A4
My Photos: (0)
I just picked up this fancy little DAC, haven't hooked it up yet, but sound quality should be very good
http://www.mp3car.com/vbulletin/gene...bloat-dac.html
sonneboz is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 11:19 AM
Does sound card quality matter for optical out? PhatMo Car Audio 4 03-22-2007 09:15 AM
Recommended Sound Card - 4 Channel/5.1 efficinet Road Runner 7 02-23-2007 01:49 PM
Mac Mini questions, possible FAQ metalac MacCar 2 09-11-2006 09:37 AM
Mac Mini in a Mazda Protege zapwizard Show off your project 18 08-07-2006 08:18 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
