The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 03-16-2008, 12:12 PM   #1
My Photos: (0)
Cheap CAN/USB interface
I put together a breadboard with a cheap-ish CAN interface so that I can eventually plug my Mac into a test car, and I am in the process of writing some software for it. Anybody else interested in this kind of thing?
BonyCook is offline   Reply With Quote
Sponsored Links
Old 03-16-2008, 04:56 PM   #2
QCar Creator
Jirka Jirout's CarPC Specs
Jirka Jirout's Avatar
Vehicle: 1993 Tatra 613-4Mi Long
My Photos: (0)
Is this a true USB/CAN interface, or just OBDII adapter? If it is a true USB/CAN, then I might be interested quie a bit (depending on price and other conditions of course). What chip are you using for the USB interface? FTDI? How does the device looks like to the computer - HID, Serial device or something else completely?
Jirka Jirout is offline   Reply With Quote
Old 03-16-2008, 06:20 PM   #3
Vehicle: 2008 Mitsubishi Colt Insport 1.3
My Photos: (0)
Sounds interesting.
What IC's are you using ?
Please come up with some more information, it's what i'm missing for my MacCar installation.
// Per.
zapro is offline   Reply With Quote
Old 03-17-2008, 02:35 AM   #4
My Photos: (0)
It is a real CAN interface. It uses an FT2232 for the USB interface, an SJA1000 CAN controller, and a transceiver chip. As you can see, it's not really complex, and the part cost is managable, too, the most expensive part in this setup being the DLP2232M dev board for the FTDI chip. There is no MCU involved, so the device depends entirely on the host computer, and I'll have to test if this approach is fast enough for high-speed CAN, but it should be.
Unfortunately I haven't been able to test this, yet, as I fried the transceiver IC, and since it's SOIC, I'll have to do some soldering to fit another one to the breadboard.
As for the drivers, using the CAN controller through a serial interface is a bit complex (as you have to control the SJA1000 through the FT2232, so there's 2 ICs to manage), so there will be a higher level library to do stuff, such as a WriteCANMessage() or ReadBuffer() function, etc.
Old 03-17-2008, 03:35 AM   #5
ptk
ptk's CarPC Specs
Vehicle: 2006/VW/GTi
My Photos: (0)
i will be interested too! only thing is, i am on windows.
CarPC Ver 3 near completion.
ptk is offline   Reply With Quote
Old 03-17-2008, 05:45 PM   #6
My Photos: (0)
I have the capabilities to lay out PCB for the parts, fabrication of PCB etc., and could be persuaded to give a hand with development if needed.
Give me a PM if interested, i will need the schematics to make the PCB.
I am not a programmer, just a hardware-guy, so the programming is off my head.
// Per.
Old 03-19-2008, 12:23 PM   #7
My Photos: (0)
Is this is right for land rover discovery 3 (2006)?
Chizh is offline   Reply With Quote
Old 03-21-2008, 11:03 PM   #8
Vehicle: 2001 Audi TT Quattro Coupe
My Photos: (0)
Woot for VAG-Com
TTeuer is offline   Reply With Quote
Old 04-01-2008, 07:24 AM   #9
My Photos: (0)
I have built this device, and despite i have not got my new car yet (will be ready in a few days) it seems to work.
It's a similar construction, and it works perfect. You can see the Documentation for it, it uses an Virtual serial port over USB to communicate - should be pretty easy to program an application for it!
http://www.mictronics.de/?page=can_bus
My friend Henri built the interface, and done some changes, my interface is 100% the same as his, you can have a look here: http://www.skippari.net/projects/can-usb-interface/
Regards, Per.
Old 04-01-2008, 06:15 PM   #10
galvitron's CarPC Specs
galvitron's Avatar
Vehicle: 2006 Evo MR
My Photos: (0)
^^ Looks great! Any plans to sell these things?
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 100%
Installation/Fab/Assembly (Revised):
[----------] 80%
galvitron is offline   Reply With Quote
Sponsored Links
Old 04-11-2008, 09:43 AM   #11
My Photos: (0)
Well, no.
I think that Henri made 2-3 PCB's and i got one of them. I could make PCB's but it's a lot of work to do double sided PCB's by hand.
I'm unsure if the author (Mictronics) is OK with selling devices that use his proprietary code, you will have to ask him if it's OK to make this device and sell it.
Anyway, i have got my car now - It's an Mitsubishi Colt 1,3 '08 with CAN and the board works as it should. The car uses 500 MPBS bitspeed and theres a ****load of data when the ignition is turned on!
// Per.
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
