The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 04-14-2008, 09:21 AM   #16
atl
atl's CarPC Specs
atl's Avatar
Vehicle: 1995/Audi/A6 & 2003/Audi/A4 Cabrio
My Photos: (1)
Hello bpwned.
Quote: Originally Posted by bpwned View Post
That's how I've configured my Mini! (P2140 sends it to sleep when I turn off ignition, then cuts power after 1h, the Mac automatically saves the session to HDD and starts again where I left off).
That's the same setup, I had running last year. But my/the P2140 has some bugs, so that the power was cutted completely sometimes before the mini was in sleep mode.
What firmware and settings for the P1240 you are using?
ByE...
atl is offline   Reply With Quote
Sponsored Links
Old 04-14-2008, 11:08 AM   #17
bpwned's CarPC Specs
bpwned's Avatar
Vehicle: 2004 Land Rover Freelander
My Photos: (3)
My P2140 has firmware version 1.83 and everything set to standard, except for shutdown lockout. I reduced that to 15secs. That's enough for the Mini to write all the data to the disk.
bpwned is offline   Reply With Quote
Old 04-14-2008, 05:32 PM   #18
atl
atl's CarPC Specs
atl's Avatar
My Photos: (1)
How do you power the LCD screen? From the secondary output of the P2140?
Because I'm using an Indash-LCD, I set the Shutdown-Delay to 15 sec and set the secondary power to follow the shutdown-delay for powering off. This gives the LCD enough time to close and disconnect (USB) before the mini is going to sleep/hibernate. Else the mini would wake up again, if the LCD is disconnect (itself) from USB.
Today again all the settings were gone.
ByE...
Old 04-15-2008, 02:58 AM   #19
bpwned's Avatar
My Photos: (3)
Yes, I power it from the secondary output. It's just that I have a "normal" LCD and thus I don't have to look after it being disconnected at a certain time. I just switch power to everything off after 15s.
You might have more luck asking your question in the carnetix support forum. I'm sure they've already dealt with such issues.
Sponsored Links
vB code is On
Trackbacks are Off
Skin Release: "Simplistique" - download and screenshots lloydy RR Skins 451 07-08-2008 06:39 PM
OBDII Module doesn't work Lok Bug Tracking 18 04-10-2008 03:33 PM
No Data recived from GPS jbird12345 Bug Tracking 4 02-02-2008 06:28 PM
Holux GPS Trouble mangus580 StreetDeck 34 11-26-2007 08:56 PM
Shutdown controller screwc149 Power Supplies 1 11-22-2006 10:38 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
