Go Back   MP3Car.com > Mp3Car Technical > MacCar
Old 04-06-2008, 11:26 AM   #1
Red_Beard's Avatar
Get rid of compression noise
In my mac car I can hear the compression of mp3's and its really distracting. Songs that come through fine in the house sound distorted sometimes beyond listening in the car. Anyway to get rid of the compression noise?
Red_Beard is offline   Reply With Quote
Old 04-06-2008, 11:59 AM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
I doubt it is the Mac. What is the bit rate? You need a minimum of 192 for it to sound decent.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 04-06-2008, 04:51 PM   #3
Red_Beard's Avatar
yeah, I know its not the mac. But is there like some kind of pre-amp sort of software to put that noise down? The bitrate does suck for most of my songs. The ones I personally ripped off CD's sound real good. But I just wish the other ones were as seemless as they are when played inside or off an ipod.
Old 04-06-2008, 10:04 PM   #4
NeonDev's Avatar
well what software are you using for playback?
check us out at: www.neonboombox.com
NeonDev is offline   Reply With Quote
Old 04-07-2008, 08:59 AM   #5
This is why all my music is lossless, WMA Pro9...
WuNgUn is online now   Reply With Quote
Old 04-07-2008, 09:19 PM   #6
Red_Beard's Avatar
Do you think the GLI could have something have something to do with it? I've been planning to go with a REAL amp and get rid of the GLI with the new amp.. because I think my current amp is NOT grounded.. I feel like the GLI is emphasizing the noise.
I'm using iTunes with CarFrontEnd..
Is there a way to set the equalizer to get rid of it?
Old 04-07-2008, 11:49 PM   #7
Bugbyte's Avatar
I know GLI's can affect the frequencies and act as a filter sometimes.
How does it sound if you plug headphones directly into the Mini? If it still sounds bad, that would tell you something.
Old 04-08-2008, 12:08 AM   #8
i had a similar problem, turned out what happened was i had an eq running on the mac and then had another eq running in the audio system in my car. having the two running at the same time really jacked up my sound. turning off all eq settings on the mac fixed the problem
natedawgg is offline   Reply With Quote
FAQ: Getting Rid of that Whine or Buzzing Noise in Your Speakers Bugbyte The FAQ Emporium 34 06-18-2008 10:39 AM
Alternator Whine Only With Carputer tbird2340 Car Audio 25 06-29-2007 02:36 AM
Bloomin' alternator whine Vodkapete Car Audio 4 05-03-2007 05:25 PM
Got rid of BUZZ noise!! bleunetizen General Hardware Discussion 3 10-30-2005 07:20 PM
Troubleshooting: NOISE RedGTiVR6 Car Audio FAQ 0 03-26-2005 10:31 AM
