Go Back   MP3Car.com > Mp3Car Technical > MacCar
Old 04-19-2008, 07:26 AM   #1
My proposed system- input/help?
I originally posted this in the technical discussions, but I was redirected to post it here where more Mac-centric folks dwell...
I have been researching this for years and I'm finally getting a car I will be proud enough to put a CarPC in. I'm a Mac user so (for better or for worse) I have decided to go OSX. I'll be installing into the double-din of a 2005 Jetta GLI and I want it to look clean... no pop-out displays, no extraneous modifications to the car.
Now, this is what I've decided on so far:
*Xenarc 700 or 705 TSV
*Apple 12" late model powerbook OR early macbook (possibly with broken display for less $)
*A PCMIA or ExpressCard sound card (for better than than 2-channel output)
*Keyspan RF remote if PB, Apple remote if MB.
*Bluetooth keyboard/mouse
*GPS antenna
*HD radio antenna (i wouldn't ever use satellite...)
*Naturally, a power supply, but I would tie it to the ignition.
Essentially, I want a full featured mac running at bare bones for speed, Front Row, access to iTunes and GPS applications, access to HD radio. The advantage for me in using a laptop is 1) slim form factor and 2) power management.
I would want the car-pc in an always-on or always-ready state to keep from having boot times before I can play music. I want to be able to "go into Starbucks" and jump right back into music playing when I get back. Therefore, the power supply would power off with the ignition, but the laptop would run on battery. When the laptop detects that the power supply isn't supplying, it waits one minute and then puts on the screen saver. Five minutes later, it powers off the screen. Thirty minutes later, laptop goes into sleep mode. When the battery is close to death, it hibernates.
The other advantage to a late 2006 or newer Apple laptop is the hard disk protection... it senses the laptop's sudden accelerations and removes the needle from the HDD, something that I think would help reliability over speedbumps. A laptop is built more for movement and would be able to fit in a smaller space (provided I ventilate it)
I know that HDD stability hasn't seemed to be an issue, but it's peace of mind for me... that and the battery are what have swayed me against a Mac Mini (Sorry!)
Ideally, I would use the touchscreen to navigate the computer and Front Row. I would also want to use the keyspan/apple remote. I would probably run the laptop normally but in 800x600 vga resolution. There are no front-end systems that I can see myself using for the mac (yeah, a drawback to OSX). On the plus side, I can wirelessly back up my system to a Time Capsule at home when I park.
So, what do you think? Do you see any problems or issues that I haven't thought of? questions?
For those of you with Xenarcs, does your finger work as well as a stylus, or do you need the 5-wire sensitivity for that?
Oh, and the install would have everything but the touchscreen hidden from sight and access... I'll use a software app if possible to bring up an onscreen keyboard, etc.
All this of course until the iPhone/iPod interface is stolen for CarPC's. Until this is built, I'll be using my Touch with the DLO Ventmount @ http://www.dlo.com
Thanks, look forward to working with the community...
Mobiuslogic is offline   Reply With Quote
Old 04-19-2008, 08:57 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Think simpler with the screen. Wire the screen to your car accessory switch and have it turn on and off with the key. Why waste power and attract onlookers with the screen on in the car while you are away from it?
Which HD radio interface are you using? The only one I know that works for the Mac is the RadioShark, and that's not HD.
Also, I think you can use your iPhone as a remote for the PB using RemoteBuddy.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 04-19-2008, 10:08 PM   #3
12" Powerbooks and Macbooks do not have any PCMCIA/Express Card slots.
TTeuer is offline   Reply With Quote
Old 04-20-2008, 04:28 AM   #4
Point. I'm getting too fancy in my enthusiasm. I have to remember that it's a DRIVING car before it's a show car. Then I revise to the SCREEN turns off with the ignition, but the laptop remains ready to run. I only hope the issue that others are having with "USB keyboard disconnected" on hard power-offs of the touchscreen will either be fixed or not an issue for me.
Which HD radio interface are you using? The only one I know that works for the Mac is the RadioShark, and that's not HD. Also, I think you can use your iPhone as a remote for the PB using RemoteBuddy.
I love RemoteBuddy! As for HD radio, I casually assumed I would find an HD radio dongle for the Mac... a quick internet search reveals that you are correct. I will probably use a RadioShark2 with a modified antenna (read that in another forum). ACTUALLY, if I'm really brave, I'll see about modding the RS2 with this HD reciever http://www.hdradio.com/buyers_guide....uideController
BTW, nice to make your acquaintance. You were specifically mentioned as a very knowledgeable and helpful guy by the poster that directed me to this forum.
Old 04-20-2008, 04:31 AM   #5
Very true. I will either suffer with 2-channel or use a USB dongle then. I'll research that in the other forums. Thanks for the heads-up!
I love this community. I'm the type that feels I need to be absolutely certain before I commit, and then change my ideas mid-process. Your helpfulness is completely awesome!
Old 04-20-2008, 03:14 PM   #6
I just got done with my MacBook setup and posted some information. Not sure what information might be of help, but here is the link:
http://www.mp3car.com/vbulletin/macc...-complete.html
skizot is offline   Reply With Quote
New EWF + MinLogon and CF instructions SFiorito WinNT Based 291 09-09-2008 11:09 AM
2001 C5 Corvette Car Computer/Audio System modena0 Show off your project 5 09-07-2006 09:18 AM
BUIDING VOLVO RTI NAVIGATION SYSTEM into VW AndyB General Hardware Discussion 6 08-31-2006 04:09 PM
Ground audio system to battery?? eddie Car Audio 7 05-30-2006 02:34 PM
Honda Accord System Theory GeoLogic General MP3Car Discussion 10 04-03-2006 12:43 PM
