The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > MacCar
Thread Tools Display Modes
Old 04-27-2008, 12:41 AM   #1
im2fresh's CarPC Specs
My Photos: (0)
Audio Issue
Just installed my mac mini in my car using the P1900. Everything is working fine but the audio. The mac mini is connected to an 4 channel amp going to the car's stock speaker system but the audio sounds muffled. Any suggestions on what may be the problem?
im2fresh is offline   Reply With Quote
Sponsored Links
Old 04-27-2008, 05:12 AM   #2
onepuff's CarPC Specs
onepuff's Avatar
My Photos: (0)
Did you have the amp hooked up in your car before to your cd player or radio? How do you have the amp hooked up to the mini? Dumb question but you do have the system volume turned up on the mini right? I know the volume goes down sometimes when you plug in an audio jack.
onepuff is offline   Reply With Quote
Old 04-27-2008, 11:00 AM   #3
My Photos: (0)
Before everything was stock, the amp was just added when the mac mini was. The amp is hook to the in/out port on the back of the mac mini and channeled to the rear and front door speakers. Yes I checked the volumes controls on mac mini as well. I just seems like something isn't hooked up right. Its sounds like a walkman is hooked up. No clearity at all.
Old 04-27-2008, 11:46 AM   #4
pepsibobby's CarPC Specs
pepsibobby's Avatar
Vehicle: 2006 Saturn Ion2
My Photos: (0)
are you using an 1/8th out the back of the mini split up to the four channels on your amp?
Cant code cause I dont know how, but give me the paint bucket and my eraser and have at you!
pepsibobby is offline   Reply With Quote
Old 04-27-2008, 11:59 AM   #5
My Photos: (0)
No, I dont think so. What is that?
Old 04-27-2008, 01:55 PM   #6
natedawgg's CarPC Specs
Vehicle: 99/pontiac/transAm
My Photos: (0)
one thing you need to check is if your amp has an eq built in, then you need to make sure that every eq in the mini is turned off. if you are using itunes, make sure the eq is off and that in preferences under playback that crossfade, soundcheck, and sound enhancer are not checked. if any of those are checked then it can really hinder the sound when pumped through another amp. it would also help if you got an external sound interface such as this one: http://www.griffintechnology.com/products/imic
natedawgg is offline   Reply With Quote
Old 04-27-2008, 03:49 PM   #7
My Photos: (0)
I unchecked all the EQ setting in iTunes and that helped a little. This is the amp that i have:
http://www.alpine-usa.com/US-en/prod...&lang=en&tab=F
I will have to try using some type of usb audio interface and hopefully that will make a major difference.
Old 04-27-2008, 04:12 PM   #8
My Photos: (0)
yeah the usb audio interface will make the sound signal stronger and clearer, however on second thought, im not sure that is th smartest thing to try yet. with external amps, they take a line in input. typically this comes from the back of a head unit of some sort, that puts out the correct signal strength. external amps dont want a lot of power coming into them. in fact they want the exact opposite. they want a low level stable signal, that they can then amplify correctly. i think some people here have found a "middle man" solution with a head unit that takes the signal from your mini corrects it and then outputs it to your amp. One way of doing this is to get an aftermarket head unit that takes an Auxiliary input put also has pre amp outputs (outputs with the correct signal for your amp). this gives you the benfit of someone else doing all the hard work figuring out the correct signal, but then you have to find a place to mount the extra hardware. also i know there is a specific head unit out there just for this sort of thing. search the forums its in here somewhere i know (just not exactly sure of the exact location). good luck!
Old 04-27-2008, 05:15 PM   #9
My Photos: (0)
Thanks for all the info!
Old 04-28-2008, 09:43 AM   #10
mr2mac's Avatar
Vehicle: Toyota MR2
My Photos: (0)
Hello,
I'd thought i'd give you my solution for sound on my install.
I use a grifin firewave soundcard:
http://www.griffintechnology.com/products/firewave
It has the ability of 5.1 surround, it uses 1/8" or 3.5mm stereo mini jacks, so it can easily be hooked up to your amp by using these:
http://www.maplin.co.uk/Module.aspx?...31700&doy=28m4
The sound quality is good and I have no noise issues.
But the sound card does not remember its settings after a shut down. But I leave it in its default settiing which is good enough for me.
Hopes this helps.
nick
mr2mac is offline   Reply With Quote
Sponsored Links
Old 04-28-2008, 12:46 PM   #11
My Photos: (0)
I already have one of these for a home studio, not sure how well this would work with the amp in my car
http://www.m-audio.com/products/en_u...kPro-main.html
Sponsored Links
vB code is On
Trackbacks are Off
Need help linking alarm to audio system F3RR3T Off Topic 2 04-26-2008 05:30 PM
SD crashes on startup mangus580 StreetDeck 7 10-05-2007 11:14 AM
Audio issue with Intel Mini iamgnat MacCar 25 06-27-2006 07:01 PM
timeouts and bluetooth audio randomness numbers PhoneControl 4 01-09-2006 03:44 PM
Carputer integration with HUGE car audio system, help please septicdeath Newbie 19 12-04-2004 05:37 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
