05-02-2008, 05:08 PM
#16
Vehicle: 99/pontiac/transAm
that last bug i believe is just flash player because im just using standard flex created buttons. i think that something is going awry with the double click functionality for the folder selection. somehow it is not firing off correctly to create the xml file. like i said i will check it out tonight and i dont think that it is a big problem to fix. i will let you all know as soon as i get it up and working
05-02-2008, 05:15 PM
#17
Vehicle: 96' Mercedes SLK 230 Kompressor
I suggest that instead of using a dbl click create a button..
btw, when dbl click it only shows the folder structure that is in that folder..
about the coverflow button:
it's just that button that react like that, the others are "normal"
96' SLK 230 Kompressor
HR sprigs -> Done
19' wheels -> Done
Projector headlights -> Done
Carpc -> 85%
05-02-2008, 05:58 PM
#18
Since I haven't got the chance to test it yet, I'm instead going to make some suggestions on things to do.. *lol*
It could be that this alredy are, but on the last image I saw it was not.
Added "artist name" and "album name" in coverflow window, and "now playing" + "next song" below the coverflow window:
Next, added a "track list" button, that when trigged shows a window with the track playing and so on. It has buttons so that you can step up and down on list, and it shows album art on images on track list (in this example it plays a certain album, if shuffle it would of course show the shuffle list with cover art showing on each song):
Maybe, there should have been a "page down" and a "page up" arrow buttons there as well.
Sorry to do this in the middle of the bug fixing but this is things that I really miss in itunes, and that would make the cover flow experience a lot better and user friendly..
btw, do play button change to "pause" if the player plays a song? that would be a must.. (or a separate button for that)
HR sprigs -> Done
19' wheels -> Done
Carpc -> 85%
05-02-2008, 08:47 PM
#19
thanks for the input and ideas. most of the features you are asking for are currently present in one form or another. there are now the album names in cover flow. if you select an album to play via coverflow you can click the coverFlow button which would have changed to "list view" to view the current album's list of songs with the current song playing. when a song is playing the name of the song will display along with the artist who sings it. play button does change to pause. i am planning to implement these and other features as time goes, but obviously first i will get the stupid thing actually working for everybody.
once again thanks for the input. i would love to eventually implement them all in some way, until then i will be bug fixing.
05-03-2008, 02:20 PM
#20
just letting everybody know that there is a new version ready to be downloaded. this version makes the app usable on a windows machine. it also improves reliablity for the mac platform, so all users should download the new version.
05-09-2008, 03:09 PM
#21
Issues/bugs/thoughts:
1) playlist support? I find this crucial, I have driving playlists, softer music playlists, favorites, etc.
2) Ok, I selected an artist, album, song. It played about ten seconds of it (until the progress bar was full) then skipped to the next song, ten seconds, next, ten seconds. random clicking got me back to the first song, and the progress bar moved PAST the box and moved all the way across the screen... while playing the song in full. A third attempt to play the song resulted in a normally paced progress bar, and playing the whole song. This seems to be an issue with using the "NEXT" button. Yep, I was able to reliably reproduce these by using the "NEXT" button.
3) A second press of ATT does not return the volume to normal. VERY thoughtful feature btw imho ftw
4) Is it a limitation of AIR that holding "vol up" will not cause a continuous press? That would be nice, too.
5) Shuffle: functional in this version? I couldn't tell what/if it shuffled. An indicator of it being on or off would be nice.
6) Ability to sort by artist/genre/title/album would be cool but not nescessary.
So far, though, it kicks donkey. Can't wait for the next update.
2005 MK IV Jetta GLI
Planning 75% complete
Purchasing 5% complete
Building 0% complete
Installing 0% complete
Convincing my wonderful fiancé that I NEED to spend on this instead of putting it away for the wedding .0002% complete
05-09-2008, 03:46 PM
#22
this will be implemented in the very near future. i am considering 2 things in this area. the first is being able to make a playlist from within the app (very simple to implement on my side). second importing playlists from itunes or whatever other program a playlist is made in (much harder for me to implement, although not impossible by any means)
what would you guys like? i am assuming both, so that is what direction i am heading at the moment
this is a known bug that i have been running into. it is caused by the way flash player 9 handles music. there is one way to play a .mp3 file and whole other way to play something like a .m4a file. very weird and it has been causing some real issues for me. the other part of the issue for the progress bar is caused because it takes a moment for flash to get the length of the song from the id3 tag and so it screws up the progress bar. i have pretty much already fixed that bug and that will be in the next update.
speaking of update. air provides a nice auto-update feature that will allow the app (when connected to the internet) to check and see if it is current and if not it will automatically download and install the newest version. I am going to implement this for the next beta release.
this was a speed to release problem. i was coding to fast to stop and think of basic functionality. this also will be fixed in the next release
im not sure if that is an air problem or not. i honestly never thought of that, but i will look into it further, the must be a way. and honestly the volume controls are only for the flash player and not the actual system (os volume). i am not 100% sure but i dont think air can give access to system info such as volume. it was designed to have the system volume at 100% and then control the music inside flash.
shuffle has not been implemented yet. the button is just a place holder until i can acutally implement that feature
i agree and it should not be too difficult to add, however it will rely completely on the individual file's meta data or id3 tag. the problem that i am running into is getting the metadata from a .aac, m4a song. .mp3 work fine however. i will look into this more but it will take some time.
05-09-2008, 04:11 PM
#23
Correct me if I'm wrong, but most people using your app will be using it with an independent computer system hooked up to their car, and not using it with iTunes very much. Therefore, I think the ability to create and save playlists instantly from within the app would be much more useful than integrating it with iTunes, where any changes to the playlist would be done on the iTunes side then ported to your front end.
Auto-update is King.
No worries. That's why you have beta-testers like us to do your proofreading. You do your thing, we'll do ours. You code, we'll check. You're doing an awesome job imho.
I don't mind leaving the system volume at a constant 100% and using the flash player's volume control. I was turning up the volume after the ATT button, and discovered that I needed to click a whole bunch of times to raise the volume.
I think most (not including me) people will also be considering an external control knob for volume on their systems.
That's ok. That would probably come at the same time as the playlists (to shuffle within a playlist/artist, etc.) Don't forget repeat modes: repeat one, repeat disk/playlist/artist, repeat all.
No worries. I think playlists would be priority over this, so take your time.
Also, I know this is thinking really far ahead, but does AIR support smooth and nice animations such as a "ripple" animation if you click on the screen? Eventually it'd be nice to have customizable skins or background pics and cool little animations.
ACTUALLY that brings up a good point: visualizers/slideshows? I know you're focusing on the audio app right now, but have you given any thought into being able to throw up a visualizer or slideshow while your music is playing? Just a thought.
05-09-2008, 04:17 PM
#24
Oh, I did notice the smooth slide-down effect you put on the opening "select library" screen... nice touch. Just wanted to point it out so that you didn't think it went unnoticed.
05-09-2008, 05:02 PM
#25
Vehicle: 2005 Saturn Ion
it would be nice to be able to turn off the button rollover so that people with a touch screen don't always have a lit button after poking a said button. not a big deal tho
I don't know if all touch screens move the mouse when you click but the ones here sure do (all running windows)
05-09-2008, 07:11 PM
#26
LOL- that's a "feature". It helpfully informs you what the last button you pressed was by leaving it highlighted.
Good point to bring up though. I'm going to have to find a script that turns the cursor off when the front end software is running... so I can use the CarMac and the front end without a dangling cursor.
05-10-2008, 12:32 AM
#27
That was my thought process as well, so i will deff implement the creation of playlists within the app.
yes air does support animations and lots of them. these are the goodies that i want to add in the near future, but was unable to earlier just because i wanted the app to actually work before i made it super pretty. Since air(and subsequently adobe Flex) are using flash player, it supports any custom animation you can think of, and then actually create. every action that can be performed in Flex can have some kind of animation applied to it. this can be a bad thing given that people can be animation crazy and end up with an unusable ugly distracting app. in my case i can promise you that that will not happen. I assure you however that things will be much more smooth looking in the near future.
yes. i have actually been giving that a lot of thought. i havent given the slideshow idea much thought just because i personally don't keep pics on my car pc, but it is very doable. as far as visualizations go, i am working out the algorithms to make those a reality. air gives me good acces to the sound spectrum while playing a sound, so that should make visualizers much easier to create
thank you, although as much as i would like to take credit for that, i can't. that effect comes built into the file system display component. somebody else did the legwork, i just benifited from it. glad you like it though, because i will be adding more animations to the rest of the app shortly
thanks for bringing that to my attention. currently my mini has a fried logic board (consequently if anybody knows where i can get a logic board for a 1.66ghz mini on the cheap i would really appreciate it) , so i am unable to test in the actual car enviorment (hence the reliance on you kind folks) with a touch screen. the problem seems evident enough though and easy to fix. the buttons are just standard issue buttons given in the flex ide. they come with standard states (i.e. up, over, down, hit) with each having its own look. i will just go in and make the "over" state look just like the "up" state since with a touch screen there never really is a "over" state anyway. will be fixed in next update
thank you guys for your sharp eyes. please dont hesitate to bring a like/dislike/idea to my attention, it helps everybody in the long run!
| Thread Tools |
| Display Modes |
Linear Mode
